51單片機 簡單計算器
2901672092
2019-7-15 15:33
51單片機 簡單計算器
代碼:
#include <reg51.h>
#include <stdio.h>
unsigned char table[]={0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
unsigned char pos[]={0x00, 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01};
uint num[10];
uint cnt,flag,num1,num2,op,st;
unsigned long res;
uint col,row;
/*--------------?óê±10ms×ó3ìDò---------*/
void delay10ms(void)
unsigned int TempCyc = 5552*2;
while(TempCyc--);
void update()
cnt = 1;
num[cnt] = res % 10;
for (;;)
if (res>10)
res = res/10;
cnt++;
break;
st = 1;
void delay(unsigned int k)
unsigned int j;
for (j=0; j<k; j++)
void main(void)
uchar keyval;
uint i;
cnt = 0;
flag = 0;
num1 = 0;
num2 = 0;
op = 0;
st = 0;
for (;;)
P1 = 0xf0;
keyval = 0xf0;
if ((P1&0xf0) != 0xf0)
if (st != 0)
st = 0;
cnt = 0;
keyval = P1^0xf0;
switch (keyval) //col
case (0x10):
col = 1;
break;
case (0x20):
col = 2;
break;
case (0x40):
col = 3;
break;
case (0x80):
col = 4;
break;
delay10ms();
P1 = 0x0f;
keyval = P1^0x0f;
switch (keyval)
case (0x01):
row = 1;
break;
case (0x02):
row = 2;
break;
case (0x04):
row = 3;
break;
case (0x08):
row = 4;
break;
if ((col<4 && row<4)) //1~9
cnt++;
if (flag == 0)
num1 = num1*10 + 9 - 3*row + col;
num[cnt] = 9 - 3*row + col;
num2 = num2*10 + 9 - 3*row + col;
if (row == 4 && col == 1) //0
if (cnt!=0)
cnt++;
if (flag == 0)
num1 = num1*10;
if (cnt != 0)
num[cnt] = 0;
num2 = num2*10;
if (cnt != 0)
num[cnt] = 0;
if (row == 4 && col == 2) //C
cnt = 0;
flag = 0;
num1 = 0;
num2 = 0;
op = 0;
if (col == 4) //option
flag = 1;
cnt = 0;
op = row;
if (row == 4 && col == 3) //=
switch (op)
case (1):
res = num1+num2;
update();
break;
case (2):
res = num1-num2;
update();
break;
case (3):
res = num1*num2;
update();
break;
case (4):
res = (num1*10/num2+5)/10;
update();
break;
flag = 0;
num1 = 0;
num2 = 0;
op = 0;
P1 = 0xf0;
while((P1&0xf0)!=0xf0);
P2 = 0x00;
for (i = 1; i <=cnt; i++)
P2 = pos[i];
if (st == 0)
P0 = table[num[cnt-i+1]];
P0 = table[num[i]];
delay(300);
while (1)
(174.35 KB, 下載次數(shù): 23)
2019-7-15 15:32 上傳
原理圖
b1gfish
2019-7-21 11:19
正好需要,謝謝分享
