標題: STM32 AD采集電壓 顯示屏顯示程序 [打印本頁]
作者: D不愛吃魚zzZ    時間: 2019-7-13 14:00
這是我自己寫的AD采集電壓顯示
親測好用
  1. #include "stm32f10x.h"
  2. #include "core_cm3.h"
  3. #include "system.h"
  4. #include "delay.h"
  5. #include "nokia_5110.h"
  6. #include "adc.h"
  7. int main(void)
  8. {
  9.
  10.         float temp;
  11.         u16 adcx;
  12.         u8 num = 0;
  13.
  14.
  15.         delay_init(72);
  16.         delayms(500);
  17.         LCD_init(); //初始化液晶
  18.         LCD_clear();
  19.         Adc_Init();
  20.         //PC13置零 LED亮
  21.         RCC ->APB2ENR |= 1 << 4;                        //使能PC時鐘
  22.         GPIOC -> CRH &= 0xFF0FFFFF;                //清除PC13設置
  23.         GPIOC -> CRH |= 0x00300000;                //通用推挽輸出,50MHz
  24.         GPIOC -> BRR = 1<< 13;
  25.
  26.         while(1)
  27.         {
  28.
  29.
  30.
  31.                 adcx=Get_Adc_Average(ADC_Channel_9,20);//adc通道9,取20個ADC計算平均值
  32.                 LCD_write_english_string(0,0,"ADC:");//顯示ADC
  33.                 LCD_set_XY(24,0);
  34.                 LCD_write_char(adcx/1000%10 + '0');
  35.                 LCD_set_XY(30,0);
  36.                 LCD_write_char(adcx/100%10 + '0');
  37.                 LCD_set_XY(36,0);
  38.                 LCD_write_char(adcx/10%10 + '0');
  39.                 LCD_set_XY(42,0);
  40.                 LCD_write_char(adcx%10 + '0');
  41.                 temp=(float)adcx*(3.3/4096);//adc12位
  42.                 adcx=temp;
  43.                 LCD_set_XY(0,3);
  44.                 LCD_write_char(adcx%10 + '0');//顯示電壓值1.0
  45.
  46.                 temp-=adcx;
  47.                 temp*=1000;
  48.
  49.                 adcx=temp;
  50.         LCD_set_XY(13,3);
  51.                 LCD_write_char(adcx/100%10 + '0');//顯示電壓值0.1
  52.                 LCD_set_XY(19,3);
  53.                 LCD_write_char(adcx/10%10 + '0');//顯示電壓值0.01
  54.                 LCD_set_XY(25,3);
  55.                 LCD_write_char(adcx%10 + '0');//顯示電壓值0.001
  56.                 delayms(50);
  57.                 LCD_write_english_string(7,3,".");
  58.                 LCD_write_english_string(31,3,"V");
  59.         LCD_write_chinese_string(0,1,14,4,0,2);
  60.         }
  61. }
ADC LCD.7z (187.77 KB, 下載次數: 40)
作者: admin    時間: 2019-7-14 03:11
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
