關(guān)于stm32f103c8t6控制舵機(jī)的問題
xiaozhong1314
2019-7-13 10:48
想問一下為什么信號線只能接PB13 改了也沒用,要怎么改各位大佬,求解
/***************STM32F103C8T6**********************
* 文件名 :main.c
* 描述 : 舵機(jī)測試
* 實(shí)驗(yàn)平臺:STM32F103C8T6
* 備注 :使用定時器來產(chǎn)生pwm波,控制舵機(jī)動作
* 接口 :TIM1, CH1-PB13, CH2-PB14, CH3-PB15
****************STM32F103C8T6**********************/
#include "pwm_output.h"
/* 配置TIM1復(fù)用輸出PWM時用到的I/O */
static void TIM1_GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//定時器1時鐘使能
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//GPIOB時鐘使能
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//復(fù)用推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/*配置TIM1輸出的PWM信號的模式,如周期、極性、占空比 */
static void TIM1_Mode_Config(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
/* PWM信號電平跳變值 */
u16 CCR1_Val = 0;
u16 CCR2_Val = 0;
//u16 CCR3_Val = 50000;
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 20000 - 1;//定時器周期,20ms
TIM_TimeBaseStructure.TIM_Prescaler = 72 - 1;//時鐘預(yù)分頻
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//計(jì)數(shù)方式:向上計(jì)數(shù)
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
/* PWM1 Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;//選擇定時器模式:tim脈寬調(diào)制2
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//比較輸出使能
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//極性
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;//開反向通道
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
/* PWM1 Mode configuration: Channel2 */
TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
TIM_OC2Init(TIM1, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM1, ENABLE);
/* TIM1 enable counter */
TIM_Cmd(TIM1, ENABLE);
TIM_CtrlPWMOutputs(TIM1, ENABLE);
/*配置和初始化TIM1 */
void TIM1_PWM_Init(void)
TIM1_GPIO_Config();
TIM1_Mode_Config();
admin520
2019-7-13 12:23
我也遇到這問題了,希望大佬出手解決
三千
2019-7-13 22:19
admin520 發(fā)表于 2019-7-13 12:23
我也遇到這問題了,希望大佬出手解決
我也是這個問題
