標題: 關于步進電機的hal庫例程,可按鍵調速,附加oled和MPU6050 [打印本頁]
作者: 磊雷雷    時間: 2019-7-12 10:15
  /* USER CODE BEGIN 3 */
/*按鍵判斷函數,flag_shu在程序下面有*/
                flag = flag_shu();
                switch(flag)
                        case 1:
                                flag_key = 1;
                          break;
                        case 2:
                                flag_key = 2;
                          break;
                        case 3:
                                flag_key = 3;
                          break;
                        case 4:
                                flag_key = 4;
                          break;
                        case 5:
                                flag_key = 5;
                                break;
                        case 6:
                                flag_key = 6;
                                break;
                        case 7:
                                flag_key = 7;
                                break;
                        case 8:
                                flag_key = 8;
                                break;
/*陀螺儀工作模式*/
                if(flag_key==1)
                                OLED_Clear();
                                sprintf(str,"gyroscope");
                                OLED_ShowString(0,0,str);
                                MPU6050ReadGyro(Gyro);
                                sprintf(str,"tuo:  %4d",Gyro[0]);
                                OLED_ShowString(0,2,str);
                                sprintf(str,"tuo: %4d",Gyro[1]);
                                OLED_ShowString(0,4,str);
                                sprintf(str,"tuo: %4d",Gyro[2]);
                                OLED_ShowString(0,6,str);
                                delay_ms(100);
                if(flag_key==2)
                                OLED_Clear();
                                sprintf(str,"accelerate");
                                MPU6050ReadGyro(Accel);
                                sprintf(str,"a1: %4d",Accel[0]);
                                sprintf(str,"a2: %4d",Accel[1]);
                                sprintf(str,"a3: %4d",Accel[2]);
                                delay_ms(100);
                if(flag_key==3)
                                OLED_Clear();
                                sprintf(str,"tempture");
                                MPU6050_ReturnTemp(&Temp);
                                sprintf(str,"t:%d C",Temp);
                                delay_ms(100);
/*電機控制模式*/
    if(flag_key==4)
                          if(HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_13) == GPIO_PIN_SET)
                                        OLED_Clear();
                                        sprintf(str,"Sevor");
                                        cnt = ((float)(ZhuPin))/((float)(Fenpin))/((float)(ZhouQi))/((float)(Dianji_Fenpin));
                                        sprintf(str,"n: %.3f r/s",cnt);
                                        sprintf(str,"FX:shunshizhen");
                                if(HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_13) == GPIO_PIN_RESET)
                                        OLED_Clear();
                                        sprintf(str,"FX:nishizhen");
                                delay_ms(100);
                if(flag_key==5)
                        OLED_Clear();
                        sprintf(str,"SevorMoshiTiaoZheng");
                        GPIO_SetBits(GPIOB,GPIO_PIN_13);
                        delay_ms(200);
                if(flag_key==6)
                        OLED_Clear();
                        sprintf(str,"SevorMoshi");
                        GPIO_ResetBits(GPIOB,GPIO_PIN_13);
                        delay_ms(200);
                if(flag_key==7)
                        OLED_Clear();
                        delay_ms(100);
                if(flag_key==8)
                        OLED_Clear();
                        delay_ms(100);
全部資料51hei下載地址:
c8按鍵控制步進電機+陀螺儀.7z (3.02 MB, 下載次數: 41)
