stm32f10x 移植contiki源程序
kaihua.yang
2019-7-8 22:07
1.使用std庫
2.移植了contiki
3.運行兩個thread正常
#include "contiki.h"
unsigned int idle_count = 0;
static struct etimer et_on;
PROCESS(led_on, "led_on");
PROCESS_THREAD(led_on, ev, data)
static int on = 0;
PROCESS_BEGIN();
on++;
etimer_set(&et_on, CLOCK_SECOND); // etimer溢出時間為5s
PROCESS_WAIT_EVENT_UNTIL(etimer_expired(&et_on)); // 等待定時器溢出
PROCESS_END();
static struct etimer et_off;
PROCESS(led_off, "led_off");
PROCESS_THREAD(led_off, ev, data)
static int off = 0;
PROCESS_BEGIN();
off++;
etimer_set(&et_off, CLOCK_SECOND); // etimer溢出時間為5s
PROCESS_WAIT_EVENT_UNTIL(etimer_expired(&et_off)); // 等待定時器溢出
PROCESS_END();
AUTOSTART_PROCESSES(&led_on,&led_off);
int main(void*arg)
clock_init();
process_init();
process_start(&etimer_process,NULL);
autostart_start(autostart_processes);
while(1){
while(process_run()> 0);
idle_count++;
stm32-contiki-master.zip
(350.96 KB, 下載次數: 11)
2019-7-8 22:06 上傳
