標(biāo)題: 高中生,研究了大半個月的成果,51單片機(jī)lcd顯示溫度計(jì) [打印本頁]
作者: 加賀恭一郎    時間: 2019-7-4 10:45
#include"reg52.h"
#include "temp.h"
#include"xianshi.h"
#include "fmq.h"
typedef unsigned int u16;
typedef unsigned char u8;
u8 DisPlayDate[8];
void datapros(int temp)
        float tp;
        if(temp<0)
                DisPlayDate[0] = '-';
                temp = temp-1;
                temp=~temp;
                tp =temp;
                temp = tp*0.0625*100+0.5;//100為了保留兩位小數(shù)
                DisPlayDate[0] = '+';
                tp = temp;
        DisPlayDate[1] = temp/10000;
        DisPlayDate[2] = temp%10000/1000;
        DisPlayDate[3] = temp%1000/100;
        DisPlayDate[4] = temp%100/10;
        DisPlayDate[5] = temp%10;
        if(temp/100>32)
                beep();
        lcd_w_cmd(0x82);
        lcd_w_dat('0'+DisPlayDate[1]);
        lcd_w_cmd(0x83);
        lcd_w_dat('0'+DisPlayDate[2]);
        lcd_w_cmd(0x84);
        lcd_w_dat('0'+DisPlayDate[3]);
        lcd_w_cmd(0x85);
        lcd_w_dat('.');
        lcd_w_cmd(0x86);
        lcd_w_dat('0'+DisPlayDate[4]);
        lcd_w_cmd(0x87);
        lcd_w_dat('0'+DisPlayDate[5]);
        init();
        lcd_w_cmd(0x88);
        lcd_w_dat('c');
                datapros(ds18b20readtemp());
#include "temp.h"
void delay1ms(uint y)
        uint x;
        for(;y>0;y--)
                for(x=100;x>0;x--);
uchar DS18B20init()
        uchar i=0;
        DSPORT = 0;
        i=70;
        while(i--);//642us        480~960之間
        DSPORT = 1;
        i = 0;
        while(DSPORT)
                delay1ms(1);
                i++;
                if(i>5)
                        return 0;
        return 1;//1為初始化成功,0為初始化失敗
void ds18b20_write(uchar dat)        //寫字節(jié)函數(shù)
        uchar i,j;
        for(j=0;j<8;j++)
                DSPORT = 0;
                i++;
                DSPORT = dat&0x01;
                i=6;
                while(i--);//大約68us
                DSPORT = 1;
                dat>>=1;
uchar ds18b20_read()
        uint i,j;
        uchar bi,byte;
        for(j=8;j>0;j--)
                DSPORT = 0;
                i++;
                DSPORT = 1;
                i++;
                i++;
                bi = DSPORT;
                byte = (byte>>1)|(bi<<7);
                i = 4;
                while(i--);
        return byte;
void ds18b20change()
        DS18B20init();
        delay1ms(1);
        ds18b20_write(0xcc);
        ds18b20_write(0x44);
void ds18b20ReadTempCom()//發(fā)送溫度轉(zhuǎn)化
        DS18B20init();
        delay1ms(1);
        ds18b20_write(0xbe);
int ds18b20readtemp()
        int temp=0;
        uchar tmh,tml;
        ds18b20change();
        ds18b20ReadTempCom();
        tml = ds18b20_read();
        tmh        = ds18b20_read();
        temp = tmh;
        temp<<=8;
        temp |=        tml;
        return temp;
#ifndef _TEMP_H
#define _TEMP_H
#include<reg52.h>
#ifndef uchar
#endif
#ifndef uint
#define uint unsigned char
#endif
sbit DSPORT = P3^7;
int ds18b20readtemp();
#endif
#include"xianshi.h"
void delay(unsigned int k)
        while(k--);
unsigned char lcd_r_start()
        unsigned char s;
        RW = 1;
        delay(2);
        RS = 0;
        delay(2);
        EN = 1;
        delay(2);
        s = P0;
        delay(2);
        EN = 0;
        delay(2);
        return s;
void lcd_w_cmd(unsigned char com)
        unsigned char i;
        do
                i=lcd_r_start();
                i&=0x80;
                delay(2);
        }while(i!=0);
        RW = 0;
        delay(2);
        RS = 0;
        delay(2);
        EN = 1;
        delay(2);
        P0 = com;
        delay(2);
        EN = 0;
        delay(2);
void lcd_w_dat(unsigned char dat)
        unsigned char i;
        do
                i=lcd_r_start();
                i&=0x80;
                delay(2);
        }while(i!=0);
        RW = 0;
        delay(2);
        RS = 1;
        delay(2);
        EN = 1;
        delay(2);
        P0 = dat;
        delay(2);
        EN = 0;
        delay(2);
void init()
        lcd_w_cmd(0x38);
        lcd_w_cmd(0x0c);
        lcd_w_cmd(0x01);
        lcd_w_cmd(0x06);
        lcd_w_cmd(0x80);
#ifndef _XIANSHI_H
#define _XIANSHI_H
#include"reg52.h"
sbit RS=P2^6;
sbit RW=P2^5;
sbit EN=P2^7;
void init();
unsigned char lcd_r_start();
void lcd_w_cmd(unsigned char com);
void lcd_w_dat(unsigned char dat);
void delay(unsigned int k);
#endif
#include"fmq.h"
void delayws(unsigned int k)
        while(k--);
void beep()
        unsigned int i,j;
        for(i=0;i<250;i++)
                bp=0;
                delayws(150);
                bp=1;
                delayws(150);
        for(j=0;j<100;j++)
                bp=0;
                delayws(300);
                bp=1;
                delayws(300);
#ifndef _FMQ_H
#define _FMQ_H
#include"reg52.h"
sbit bp=P1^5;
void beep();
#endif
作者: 1336785720    時間: 2019-12-31 15:00
沒有圖呀
作者: da莫寒    時間: 2020-3-9 15:13
同是高中生,為何你如此突出
