FPGA流水燈設計vhdl源程序
柏林
2019-7-3 11:42
FPGA流水燈設計vhdl源程序
自己做的FPGA流水燈設計
(7.72 KB, 下載次數: 62)
2019-7-5 00:16 上傳
vhdl源程序如下:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned .all;
entity liushuideng is
port(clk:in std_logic;
led:out std_logic_vector(7 downto 0));
end entity;
architecture bhv of liushuideng is
signal clk1:std_logic;
begin
process(clk)
variable num:integer range 1 to 25000000;
begin
if rising_edge (clk)then
if num=25000000 then num:=1;clk1<=not clk1;
else num:=num+1;
end if;
end if;
end process;
process(clk1)
variable n:integer range 0 to 3;
begin
if rising_edge (clk1) then
if n=3 then n:=0;
else n:=n+1;
end if ;
end if;
case n is
when 0=>led<="10001000";
when 1=>led<="01000100";
when 2=>led<="00100010";
when 3=>led<="00010001";
when others=>led<="00000000";
end case;
end process;
end bhv;
liushuideng.zip
(7.42 MB, 下載次數: 40)
2019-7-3 11:41 上傳
