C++語言編寫的Calculator計算器源程序
howardlu11
2019-6-26 13:45
這是一個非常實用的計算器
想要看密碼就請用Notepad打開C語言文件 然后有一行注釋行://mima...
mima后面的一串數字即為密碼
#include<cstdlib>
#include<iostream>
#include<iomanip>
#include<cmath>
#include<windows.h>
using namespace std;
#define size 100
int a[size+1],n,d,i=0,j;
//mima267398323513
main(){
int sf;
long long mima;
cout<<"======================================================="<<endl;
cout<<"| Calculator 2019 |"<<endl;
cout<<"| Version 3.98 |"<<endl;
cout<<"| |"<<endl;
cout<<"| |"<<endl;
cout<<"| Adminstrator |"<<endl;
cout<<"| Welcome to Calculator_64 Professional |"<<endl;
cout<<"| Update 1907 Professional |"<<endl;
cout<<"| Designed by Howard Lu |"<<endl;
cout<<"| |"<<endl;
cout<<"| |"<<endl;
cout<<"| C-2019-2021 |"<<endl;
cout<<"Adminstrator,請輸入密碼"<<endl;
cout<<"密碼:";
cin>>mima;
if(mima==267398323513){
system("cls");
cout<<"Initialization";
for(int i=1;i<=3;i++){
Sleep(1000);
cout<<".";
Sleep(1000);
system("cls");
Sleep(1000);
cout<<".";
Sleep(1000);
system("cls");
cout<<"C";Sleep(100);
cout<<"a";Sleep(100);
cout<<"l";Sleep(100);
cout<<"c";Sleep(100);
cout<<"u";Sleep(100);
cout<<"t";Sleep(100);
cout<<"o";Sleep(100);
cout<<"r";Sleep(100);
cout<<"_";Sleep(100);
cout<<"6";Sleep(100);
cout<<"4";Sleep(100);
cout<<" ";Sleep(100);
cout<<"2";Sleep(100);
cout<<"0";Sleep(100);
//cout<<"0";Sleep(100);
//cout<<".";Sleep(100);
cout<<"1";Sleep(100);
cout<<"9";Sleep(100);
cout<<"P";Sleep(100);
cout<<"R";Sleep(100);
cout<<"O";Sleep(100);
cout<<endl;
do{
cout<<"================================================================="<<endl;
cout<<"| |"<<endl;
cout<<"| 微型電子計算器 |"<<endl;
cout<<"| |"<<endl;
cout<<"| |"<<endl;
cout<<"| 請選擇: |"<<endl;
cout<<"| 1. 如果想計算加減乘除,請輸入1 |"<<endl;
cout<<"| 2. 如果想計算開方,請輸入2 |"<<endl;
cout<<"| 3. 如果想轉換進制數,請輸入3 |"<<endl;
cout<<"| 4. 如果想要算次方,請輸入4 |"<<endl;
cout<<"| 5. 如果想要算階乘,請輸入5 |"<<endl;
cout<<"| 6. 如果想顯示π,請輸入6 |"<<endl;
cout<<"| 7. 如果想做加法統計,請輸入7 |"<<endl;
cout<<"| 8. 想知道這一天是星期幾,請輸入8 |"<<endl;
cout<<"| 9. 想知道從1年1月1日到某年某月月底有幾天,請輸入9 |"<<endl;
cout<<"| 10.想計算斐波那契數列,請輸入10 |"<<endl;
cout<<"| 11.關閉程序,請按11 |"<<endl;
cout<<"| 12.像顯示關于Calculator 請輸入12 |"<<endl;
cout<<"| 若想進行如1×2+3×4-5+6之類的多項表達式運算,請打開棧計算器 |"<<endl;
cout<<"| 若想進行24點計算,請打開24點計算器 |"<<endl;
cout<<"| |"<<endl;
cout<<"| |"<<endl;
int ds,x,y;
cin>>ds;
if(ds==1){
char x;
double a,b;int c,d;
cout<<"請輸入+,-,*,/,%(求余,兩數不可為小數)中的一個運算符號:";cin>>x;
cout<<"請輸入A數:";cin>>a;
cout<<"請輸入B數:";cin>>b;
if(x=='/'){
cout<<"請問,你想保留幾位小數?:";cin>>c;
switch(x){
case '+':cout<<a+b<<endl;break;
case '-':cout<<a-b<<endl;break;
case '*':cout<<a*b<<endl;break;
case '/':if(b!=0) cout<<fixed<<setprecision(c)<<(double)a/b<<endl;else cout<<"Divided by zero!"<<endl;break;
case '%':c=a;d=b;
cout<<c%d<<endl;break;
default:cout<<"Invalid operator!"<<endl;
system("pause");
if(ds==2){
cout<<"請輸入一個你想開方的數:";cin>>x;
cout<<"請輸入你想保留幾位小數:";cin>>y;
cout<<fixed<<setprecision(y)<<sqrt(x)<<endl;
system("pause");
if(ds==3){
//cout<<"Please Enter a number(N) base 10:";cin>>n;
cout<<"輸入一個十進制數:";cin>>n;
//cout<<"Please Enter a number(d):";cin>>d;
cout<<"輸入你想把這個數轉化成的進制數(幾進制):";cin>>d;
do{
a[++i]=n%d;
n=n/d;
}while(n!=0);
for(j=i;j>=1;j--)cout<<a[j];
cout<<endl;
system("pause");
if(ds==4){
float a,b,c;
cout<<"請輸入底數:";cin>>a;
cout<<"請輸入指數:";cin>>b;
cout<<"請問你想保留幾位小數:";cin>>c;
cout<<fixed<<setprecision(c)<<(double)pow(a,b)<<endl;
system("pause");
if(ds==5){
int t,s;
s=0;
int a,b,c;
cout<<"請輸入你想算的階乘的數1:";cin>>a;
cout<<"請輸入你想算的階乘的數2:";cin>>b;
cout<<"我們將幫你累加從數1的階乘到數2的階乘"<<endl;
Sleep(1000);
for(int i=a;i<=b;++i)
t=1;
for (int j=1;j<=i;++j) //求i!
t*=j;
s+=t; //累加i!
cout<<s<<endl;;
system("pause");
if(ds==6){
cout<<"π=3.1415926535897932384626433872395"<<endl;
system("pause");
if(ds==7){
int a,b,sum=0;
cout<<"請輸入你要統計數的個數:";
cin>>a;
for(int i=1;i<=a;i++){
cin>>b;
sum=sum+b;
cout<<"Sum="<<sum<<endl;
system("pause");
if(ds==8){
int day,year,month,day2,date,allday;
cout<<"請輸入年月日 例 2018 12 31:";
cin>>year>>month>>date;
day=year/4-year/100+year/400;
if (year%400==0) day2=29+31+30+31+30+31+31+30+31+30+31;
else if (year%100==0) day2=28+31+30+31+30+31+31+30+31+30+31;
else if (year%4==0) day2=29+31+30+31+30+31+31+30+31+30+31;
else day2=28+31+30+31+30+31+31+30+31+30+31;
switch(month){
case 1:day2=day2+31;break;
case 2:day2=30+31+30+31+30+31+31+30+31+30+31;break;
case 3:day2=31+30+31+30+31+31+30+31+30+31;break;
case 4:day2=30+31+30+31+31+30+31+30+31;break;
case 5:day2=31+30+31+31+30+31+30+31;break;
case 6:day2=30+31+31+30+31+30+31;break;
case 7:day2=31+31+30+31+30+31;break;
case 8:day2=31+30+31+30+31;break;
case 9:day2=30+31+30+31;break;
case 10:day2=31+30+31;break;
case 11:day2=30+31;break;
case 12:day2=31;break;
allday=366*day+365*(year-day)-day2+date;
if(allday%7==1) cout<<"星期一"<<endl;
if(allday%7==2) cout<<"星期二"<<endl;
if(allday%7==3) cout<<"星期三"<<endl;
if(allday%7==4) cout<<"星期四"<<endl;
if(allday%7==5) cout<<"星期五"<<endl;
if(allday%7==6) cout<<"星期六"<<endl;
if(allday%7==0) cout<<"星期日"<<endl;
system("pause");
if(ds==9){
int day,year,month,day2;
cout<<"請輸入年月,例:2018 12:";
cin>>year>>month;
switch(month){
case 1:day2=day2;break;
case 2:day2=31+30+31+30+31+31+30+31+30+31;break;
case 3:day2=30+31+30+31+31+30+31+30+31;break;
case 4:day2=31+30+31+31+30+31+30+31;break;
case 5:day2=30+31+31+30+31+30+31;break;
case 6:day2=31+31+30+31+30+31;break;
case 7:day2=31+30+31+30+31;break;
case 8:day2=30+31+30+31;break;
case 9:day2=31+30+31;break;
case 10:day2=30+31;break;
case 11:day2=31;break;
case 12:day2=0;break;
cout<<366*day+365*(year-day)-day2<<endl;
system("pause");
if(ds==10){
cout<<"先輸入一個數(第幾項):";int n,n2;cin>>n;
cout<<"是想輸出從第一項到第"<<n<<"項的所有數,選1"<<endl;
cout<<"是想輸出從第一項到第"<<n<<"項的所有數的和,選2"<<endl;
cin>>n2;
if(n2==1){
int a,b,tmp,i;
a = 0;
b = 1;
for(i=0;i<n;i++)
printf("%d\n",b);
tmp = b;
b = a + b;
a = tmp;
system("pause");
if(n2==2){
int a,b,tmp,i,sum=0;
a = 0;
b = 1;
for(i=0;i<n;i++)
tmp = b;
sum=sum+tmp;
cout<<sum<<endl;
b = a + b;
a = tmp;
system("pause");
if(ds==11) return 0;
if(ds==12) {
system("cls");
cout<<"下面是您的賬戶信息:"<<endl;
cout<<"Adminstrator"<<endl;
cout<<"管理員"<<endl;
cout<<"創建時間:2019/7/29"<<endl;
cout<<"激活狀態:已激活"<<endl;
cout<<"激活時間:2019/7/31"<<endl;
cout<<"管理員認證號:2019-07-29-0001-ASDFG-CLOA-CAL-A0001"<<endl;
cout<<"信用狀態:未違反任何版權約定,您可以繼續使用"<<endl;
cout<<"是否想要繼續:是1,否2, 發送錯誤信息并關閉程序3:";cin>>sf;
Sleep(100);
system("cls");
if(sf==3){
cout<<"Sending Messages";
cout<<".";
Sleep(500);
cout<<".";
Sleep(500);
cout<<".";
Sleep(500);
system("cls");
cout<<".";
Sleep(500);
cout<<".";
Sleep(500);
cout<<".";
Sleep(500);
system("cls");
//do{
//cout<<"是否想要繼續:是1,否2, 發送錯誤信息3:";cin>>sf;
//Sleep(100);
//system("cls");
//if(sf==3){
// cout<<"正在使用高速通道發送錯誤信息";
// cout<<".";
// Sleep(500);
// cout<<".";
// Sleep(500);
// cout<<".";
// Sleep(500);
// system("cls");
// cout<<".";
// Sleep(500);
// cout<<".";
// Sleep(500);
// cout<<".";
// Sleep(500);
// system("cls");
//}while(sf==3);
}while(sf==1);
else cout<<"Sorry, invaliable password"<<endl;
(5.39 KB, 下載次數: 57)
2019-6-27 02:04 上傳
Calculator.rar
(382.79 KB, 下載次數: 13)
2019-6-26 13:45 上傳
howardlu11
2019-6-26 13:51
順便在說一句,如果有什么問題提出哦,還有,軟件的密碼這里我說一下吧:267398323513
本帖最后由 howardlu11 于 2019-6-26 14:04 編輯
