標題: 基于51單片機鬧鈴程序 [打印本頁]
作者: 51小白冬    時間: 2019-6-4 23:37
標題: 基于51單片機鬧鈴程序
#include "reg52.h"
#include"intrins.h"
typedef unsigned int u16;
typedef unsigned char u8;
char code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
u16 i,n,k,miao,fen,hour,feng,fens,hourg,hours,feng1,fens1,hourg1,hours1;
sbit flag=P1^0;
sbit flag1=P1^1;
sbit s1=P1^7;
sbit s11=P1^3;
sbit s2=P1^6;
sbit led=P2^0;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit k1=P3^0;
sbit k2=P3^1;
sbit k3=P3^2;
sbit k4=P3^3;
sbit led6=P0^6;
sbit led7=P0^7;
sbit beep=P1^5;
void delay70ms(void)  //??????70ms
    unsigned char a,b;
    for(b=158;b>0;b--)
        for(a=220;a>0;a--);
    _nop_();
void delay(u16 u)
    u--;
void turntime()  //??????亯??
if(k2==0)    //С???λ
  delay70ms();
   if(k2 == 0)
   { miao = 0;
    hours++;
    hours = hours%3;
delay70ms();
   while(!k2);
   if(k1 == 0)   //С??λ
   delay70ms();
   if(k1 == 0)
   { miao = 0;
    hourg++;
    hourg = hourg%10;
delay70ms();
   while(!k1);
    if(k3 == 0)     //?????λ
   delay70ms();
   if(k3 == 0)
   { miao = 0;
    fens++;
    fens=fens%6;
delay70ms();
   while(!k3);
    if(k4 == 0)      //?????λ
   delay70ms();
   if(k4 == 0)
   { miao = 0;
    feng++;
    feng = feng%10;
    delay70ms();
   while(!k4);
void turnclock()  //???????????
if(k2==0)    //С???λ
  delay70ms();
   if(k2 == 0)
   { miao = 0;
    hours1++;
    hours1 = hours1%3;
delay70ms();
   while(!k2);
   if(k1 == 0)   //С??λ
   delay70ms();
   if(k1 == 0)
   { miao = 0;
    hourg1++;
    hourg1 = hourg1%10;
delay70ms();
   while(!k1);
   delay70ms();
   if(k3 == 0)
   { miao = 0;
    fens1++;
    fens1=fens1%6;
delay70ms();
   while(!k3);
   delay70ms();
   if(k4 == 0)
   { miao = 0;
    feng1++;
    feng1 = feng1%10;
    delay70ms();
   while(!k4);
void InitTimer0(void)
    TMOD = 0x01;
    TH0 = (65535-10000)/256;
    TL0 = (65535-10000)%256;  //10ms
    EA = 1;
    ET0 = 1;
    TR0 = 1;
void Timer0Interrupt(void) interrupt 1
    i++;k++;
   if(k == 50)       //????
   {led =~led; k = 0;}
      if(i == 100)
   {i = 0; miao++;}
   if(miao == 60)   //????
   {miao = 0;feng++;}
   if(feng == 10)
   {feng=0;fens++;}
   if(fens == 6)    //С?
   {fens=0;hourg++;}
   if(hourg == 10)
   {hourg=0;hours++;}
   if(hours == 2&&hourg == 4) //????
   {hours=0;hourg=0;}
void select()   //?????
if(s1==0)
     delay70ms();
  if(s1==0)
  flag=~flag;
  delay70ms();
  while(!s1);
void openclock()   //??????????
  if(s2==0)
     delay70ms();
  if(s2==0)
  flag1=~flag1;
  delay70ms();
  while(!s2);
void DigDisplay()       //???????????????
  LSA=0;LSB=0;LSC=0;P0=smgduan[feng];delay(100);P0=0x00;
  LSA=1;LSB=0;LSC=0;P0=smgduan[fens];delay(100);P0=0x00;
  if(led==1)
  {LSA=0;LSB=1;LSC=0;led6=1;delay(100);P0=0x00;
  LSA=1;LSB=1;LSC=0;led6=1;delay(100);P0=0x00;}
  LSA=0;LSB=0;LSC=1;P0=smgduan[hourg];delay(100);P0=0x00;
  LSA=1;LSB=0;LSC=1;P0=smgduan[hours];delay(100);P0=0x00;
  if(flag1==0)
  {LSA=1;LSB=1;LSC=1;led7=smgduan[flag1];delay(100);P0=0x00;}
void DigDisplay1()       //????????????????
  LSA=0;LSB=0;LSC=0;P0=smgduan[feng1];delay(100);P0=0x00;
  LSA=1;LSB=0;LSC=0;P0=smgduan[fens1];delay(100);P0=0x00;
  LSA=0;LSB=0;LSC=1;P0=smgduan[hourg1];delay(100);P0=0x00;
  LSA=1;LSB=0;LSC=1;P0=smgduan[hours1];delay(100);P0=0x00;
  LSA=1;LSB=1;LSC=1;s1=smgduan[flag1];delay(100);P0=0x00;
void alarmclock()  //???????ú???
  turnclock();
  DigDisplay1();
void clocking()      //??????к???
     openclock();
  if((feng1==feng)&&(fens1==fens)&&(flag1==0))
  if((hourg1==hourg)&&(hours1==hours))
   while(!flag1)
      openclock();
      beep=~beep;
      delay(10);
   DigDisplay();
void main(void)
    s11=0;
    InitTimer0();
select();
clocking();
if(flag==1)
{DigDisplay();turntime();}
if(flag==0)
{DigDisplay1();alarmclock();}
正常模式下  k1 k2 k3 k4  分別為 小時十位 個位    分鐘 十位  個位調整函數
作者: admin    時間: 2019-6-5 06:39
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
