標題: 單片機16*16點陣滾動顯示Proteus仿真+代碼 [打印本頁]
作者: hyjxxy    時間: 2019-5-31 16:54
16*16點陣滾動顯示制作出來的實物圖如下:
  1. //宏定義
  3. #define uint unsigned int
  4. #define zishu 10        //漢字數,兩個字符是一個漢字,如果有單個字符,那么就加0.5
  5. //包含頭文件
  6. #include <reg51.h>
  7. #include <intrins.h>
  8. //管腳定義
  9. //154
  10. sbit A_=P0^0;                   //74HC154的A
  11. sbit B_=P0^1;                   //74HC154的B
  12. sbit C_=P0^2;                   //74HC154的C
  13. sbit D_=P0^3;                   //74HC154的D
  14. sbit G2=P0^7;                //74HC154的使能        低電平有效
  15. //595
  16. sbit SI=P0^6;//數據腳
  17. sbit SCK=P0^5;//上升沿時數據寄存器的數據移位。QA-->QB-->QC-->...-->QH;下降沿移位寄存器數據不變
  18. sbit RCK=P0^4;//上升沿時移位寄存器的數據進入數據存儲寄存器,下降沿時存儲寄存器數據不變。通常我將
  19.                                   //RCK置為低電平,當移位結束后,在RCK端產生一個正脈沖(5V時,大于幾十納秒就行了。我
  20.                                   //通常都選微秒級),更新顯示數據。
  21. //函數聲明
  22. void Init595();
  23. void Write_byte595(uchar temp);
  24. void WriteS(uchar data1,uchar data2);
  25. void Wei_154(uchar W);
  26. void delay(uint z);
  27. //漢字數組
  28. uchar code HanZi[]=
  29. {
  30. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  31. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/         //這兩行不要動改字時保留
  32. 0xFF,0xFF,0x80,0x00,0xBF,0xFF,0xB7,0xFF,0xB6,0x07,0xB6,0xEF,0xB6,0xEF,0xB6,0xEF,
  33. 0xB6,0xEF,0xB6,0xEF,0xB6,0x07,0xB7,0xFD,0xBF,0xFE,0x80,0x01,0xFF,0xFF,0xFF,0xFF,/*"同",0*/
  34. 0xFF,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,
  35. 0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFC,0xFF,0xFE,0xFF,0xFF,0xFF,/*"一",1*/
  36. 0xFF,0xFF,0xFE,0xFF,0xFE,0xFF,0xFD,0xFF,0xFB,0xFF,0xF7,0xFF,0xCF,0xFF,0x38,0x01,
  37. 0xDF,0xFF,0xEF,0xFF,0xF7,0xFF,0xFB,0xFF,0xF9,0xFF,0xFC,0xFF,0xFD,0xFF,0xFF,0xFF,/*"個",2*/
  38. 0xFB,0xFF,0xFB,0xFF,0xFB,0xFF,0x80,0x03,0xFB,0xFB,0xFB,0xFB,0x80,0x1B,0xFB,0xBB,
  39. 0xFB,0xBB,0xFB,0xBB,0xFB,0xBB,0x80,0x1B,0xFB,0xF3,0xFB,0xFB,0xFB,0xFF,0xFF,0xFF,/*"世",3*/
  40. 0xFF,0xFF,0xFF,0xEF,0xFF,0xEF,0x00,0xDE,0x6D,0xDD,0x6D,0xBB,0x6D,0x47,0x00,0xFF,
  41. 0x6C,0xFF,0x6D,0x40,0x6D,0xBF,0x6D,0xBF,0x00,0xDF,0xFF,0xCF,0xFF,0xDF,0xFF,0xFF,/*"界",4*/
  42. 0xFF,0xFF,0x80,0x00,0xBF,0xFF,0xB7,0xFF,0xB6,0x07,0xB6,0xEF,0xB6,0xEF,0xB6,0xEF,
  43. 0xB6,0xEF,0xB6,0xEF,0xB6,0x07,0xB7,0xFD,0xBF,0xFE,0x80,0x01,0xFF,0xFF,0xFF,0xFF,/*"同",5*/
  44. 0xFF,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,
  45. 0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFC,0xFF,0xFE,0xFF,0xFF,0xFF,/*"一",6*/
  46. 0xFF,0xFF,0xFE,0xFF,0xFE,0xFF,0xFD,0xFF,0xFB,0xFF,0xF7,0xFF,0xCF,0xFF,0x38,0x01,
  47. 0xDF,0xFF,0xEF,0xFF,0xF7,0xFF,0xFB,0xFF,0xF9,0xFF,0xFC,0xFF,0xFD,0xFF,0xFF,0xFF,/*"個",7*/
  48. 0xFD,0xFF,0xDD,0xFE,0xDB,0xEE,0xD7,0xEE,0x00,0x9D,0xD6,0x5D,0xD9,0x6B,0xFD,0x73,
  49. 0xDB,0x77,0xD7,0x6F,0x00,0x5F,0xCF,0x3F,0xD3,0x7F,0xD9,0xFF,0xDB,0xFF,0xFF,0xFF,/*"夢",8*/
  50. 0xEF,0x7F,0xEC,0xFD,0xE3,0xF1,0x00,0x7F,0xE7,0xE3,0xE9,0xFD,0xEF,0xFD,0xFF,0xDD,
  51. 0x80,0x65,0xAB,0x7D,0xAB,0x7D,0xAB,0x79,0xAB,0x7F,0x80,0x6F,0xFF,0xF3,0xFF,0xFF,/*"想",9*/
  52. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",10*/
  53. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",11*/                //這兩行不要動改字時保留
  54. };
  55. //主函數
  56. void main()
  57. {
  58.         uchar i=1,j=0;
  59.         uint X=0;
  60.         //595c初始化
  61.         Init595();
  62.         //循環演示
  63.         while(1)          //循環
  64.         {
  65.                 for(j=0;j<10;j++)        //更改j<10為j<5,可以加速
  66.                 {
  67.                         for(i=1;i<17;i++)        //一個for循環,分別選中16個列
  68.                         {
  69.                                 WriteS(0xff,0xff);        //消影
  70.                                 Wei_154(i);        //選中列數據
  71.                                 WriteS(HanZi[i*2-2+2*X],HanZi[i*2-1+2*X]);                        //顯示內容
  72.                                 Wei_154(i);        //再選中列數據
  73.                                 delay(7);        //延時的時間就是顯示的時間
  74.                                 G2=0;        //打開列選
  75.                         }
  76.                 }
  77.                 X++;        //顯示左移
  78.                 if(X==8*((zishu+1)*2))        //左移到最后一個字--更改字時,8*n中的n的取值為:字符數+2(一個漢字=兩個字符,字母數字為1個字符)
  79.                         X=0;        //重頭開始
  80.         }
  81. }
  82. //初始化595
  83. void Init595()
  84. {
  85.         SI=1;
  86.         SCK=0;
  87.         RCK=0;
  88. }
  89. void Write_byte595(uchar temp)                //寫數據到595
  90. {
  91.         uchar i,data_=temp;
  92.         G2=1;                                                        //關閉列選
  93.         for(i=0;i<8;i++)                                //傳值8位
  94.         {
  95.                 if(data_&0x01==0x01)                //判斷低位為1
  96.                 {
  97.                         SI=1;                                        //數據腳就寫入1
  98.                 }
  99.                 else                                                 //判斷低位為0
  100.                 {
  101.                         SI=0;                                        //數據腳寫入0
  102.                 }
  103.                 //產生一個上升沿
  104.                 SCK=0;
  105.                 SCK=1;
  106.                 SCK=0;
  107.                 data_>>=1;                                        //將要寫入的數據右移一位
  108.         }
  109.         RCK=0;//顯示數據
  110.         RCK=1;
  111.         RCK=0;
  112. }
  113. //595寫入一行的字節
  114. void WriteS(uchar data1,uchar data2)
  115. {
  116.         Write_byte595(data2);                        //寫入高8位數據
  117.         Write_byte595(data1);                        //寫入低8位數據                 一共是一行16個數據
  118. }
  119. //154位選驅動
  120. void Wei_154(uchar W)
  121. {
  122.         G2=0;//使能
  123.         switch(W)                //判斷W的值,選中不同的列線
  124.         {
  125.                 case 16:        //如果W=16
  126.                 {
  127.                         A_=1;
  128.                         B_=1;
  129.                         C_=1;
  130.                         D_=1;        //1111:選中第16列
  131.                         break;
  132.                 }
  133.                 case 15:
  134.                 {
  135.                         A_=0;
  136.                         B_=1;
  137.                         C_=1;
  138.                         D_=1;        //1110:選中第15列
  139.                         break;
  140.                 }
  141.                 case 14:
  142.                 {
  143.                         A_=1;
  144.                         B_=0;
  145.                         C_=1;
  146.                         D_=1;        //1101:選中第14列
  147.                         break;
  148.                 }
  149.                 case 13:
  150.                 {
  151.                         A_=0;
  152.                         B_=0;
  153.                         C_=1;
  154.                         D_=1;        //1100:選中第13列
  155.                         break;
  156.                 }
  157.                 case 12:
  158.                 {
  159.                         A_=1;
  160.                         B_=1;
  161.                         C_=0;
  162.                         D_=1;        //1011:選中第12列
  163.                         break;
  164.                 }
  165.                 case 11:
  166.                 {
  167.                         A_=0;
  168.                         B_=1;
  169.                         C_=0;
  170.                         D_=1;        //1010:選中第11列
  171.                         break;
  172.                 }
  173.                 case 10:
  174.                 {
  175.                         A_=1;
  176.                         B_=0;
  177.                         C_=0;
  178.                         D_=1;        //1001:選中第10列
  179.                         break;
  180.                 }
  181.                 case 9:
  182.                 {
  183.                         A_=0;
  184.                         B_=0;
  185.                         C_=0;
  186.                         D_=1;        //1000:選中第9列
  187.                         break;
  188.                 }
  189.                 case 8:
  190.                 {
  191.                         A_=1;
  192.                         B_=1;
  193.                         C_=1;
  194.                         D_=0;        //0111:選中第8列
  195.                         break;
  196.                 }
  197.                 case 7:
  198.                 {
  199.                         A_=0;
  200.                         B_=1;
  201.                         C_=1;
  202.                         D_=0;        //0110:選中第7列
  203.                         break;
  204.                 }
  205.                 case 6:
  206.                 {
  207.                         A_=1;
  208.                         B_=0;
  209.                         C_=1;
  210.                         D_=0;        //0101:選中第6列
  211.                         break;
  212.                 }
  213.                 case 5:
  214.                 {
  215.                         A_=0;
  216.                         B_=0;
  217.                         C_=1;
  218.                         D_=0;        //0100:選中第5列
  219.                         break;
  220.                 }
  221.                 case 4:
  222.                 {
  223.                         A_=1;
  224.                         B_=1;
  225.                         C_=0;
  226.                         D_=0;        //0011:選中第4列
  227.                         break;
  228.                 }
  229.                 case 3:
  230.                 {
  231. ……………………
  232. …………限于本文篇幅 余下代碼請從51黑下載附件…………
42-16乘16點陣滾動顯示.7z (1.04 MB, 下載次數: 70)
