標題: STM32使用ADC1采集通道3和4的電壓,但只輸出一個通道的值。問一下這是什么原因 [打印本頁]
作者: zxcv陌路    時間: 2019-5-25 08:54
采用一個例程改了一下,從PA3和PA4讀取電壓值,但只輸出了一個數(shù)據(jù),請問一下是不是配置什么的有問題?
#include "adc.h"
#include "SysTick.h"
#define ADC1_DR_Address ((u32)0x40012400+0x4c)
// #define ADC1_DR_Address    ((uint32_t)0x4001244C)
//u16 AD_Value[3];
uint16_t ADC_ConvertedValue[3];
* 函 數(shù) 名         : ADCx_Init
* 函數(shù)功能                     : ADC初始化
* 輸    入         : 無
* 輸    出         : 無
void ADCx_Init(void)
        GPIO_InitTypeDef GPIO_InitStructure; //定義結構體變量
        ADC_InitTypeDef  ADC_InitStructure;
        DMA_InitTypeDef DMA_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOA|RCC_APB2Periph_ADC1|RCC_APB2Periph_AFIO,ENABLE);
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);//設置ADC分頻因子6 72M/6=12,ADC最大時間不能超過14M
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStructure.DMA_PeripheralBaseAddr =(u32)&ADC1->DR;
        DMA_InitStructure.DMA_MemoryBaseAddr =(u32)&ADC_ConvertedValue;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 2;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);
        DMA_Cmd(DMA1_Channel1, ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3;//ADC
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;        //模擬輸入
//        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4;//ADC
        ADC_DeInit(ADC1);//?? ADC1,?? ADC1,
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
        ADC_InitStructure.ADC_ScanConvMode = ENABLE;//掃描模式
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//開啟連續(xù)轉換
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//禁止觸發(fā)檢測,使用軟件觸發(fā)
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右對齊
        ADC_InitStructure.ADC_NbrOfChannel = 2;//1個轉換在規(guī)則序列中 也就是只轉換規(guī)則序列1
        ADC_Init(ADC1, &ADC_InitStructure);//ADC初始化
        ADC_DMACmd(ADC1, ENABLE);
        ADC_Cmd(ADC1, ENABLE);//開啟AD轉換器
        ADC_ResetCalibration(ADC1);//重置指定的ADC的校準寄存器
        while(ADC_GetResetCalibrationStatus(ADC1));//獲取ADC重置校準寄存器的狀態(tài)
        ADC_StartCalibration(ADC1);//開始指定ADC的校準狀態(tài)
        while(ADC_GetCalibrationStatus(ADC1));//獲取指定ADC的校準程序
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能或者失能指定的ADC的軟件轉換啟動功能
* 函 數(shù) 名         : Get_ADC_Value
* 函數(shù)功能                   : 獲取通道ch的轉換值,取times次,然后平均
* 輸    入         : ch:通道編號
                                         times:獲取次數(shù)
* 輸    出         : 通道ch的times次轉換結果平均值
u16 Get_ADC_Value(u8 ch,u8 times)
        u32 temp_val=0;
        u8 t;
        //設置指定ADC的規(guī)則組通道,一個序列,采樣時間
        ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5);        //ADC1,ADC通道,239.5個周期,提高采樣時間可以提高精確度
        for(t=0;t<times;t++)
//                ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能指定的ADC1的軟件轉換啟動功能
                while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待轉換結束
                //temp_val+=ADC_GetConversionValue(ADC1);
                temp_val+=ADC_ConvertedValue[0];
//                temp_val+=AD_Value[0];
                delay_ms(5);
        return temp_val/times;
u16 Get_ADC1_Value(u8 ch,u8 times)
        u32 temp_val=0;
        u8 t;
        ADC_RegularChannelConfig(ADC1, ch, 2, ADC_SampleTime_239Cycles5);        //ADC1,ADC通道,239.5個周期,提高采樣時間可以提高精確度
                temp_val+=ADC_ConvertedValue[1];
//                temp_val+=AD_Value[1];
                delay_ms(5);
作者: zxcv陌路    時間: 2019-5-25 09:14
調用 我是在兩個函數(shù)里分別調用Get_ADC_value和Get_ADC1_value,這個會有影響嗎?
作者: zxcv陌路    時間: 2019-5-25 09:26
呃,找到原因了,不能使用兩個函數(shù)分別讀取Get_ADC_Value和Get_ADC1_Value的數(shù)據(jù),同時放在一個函數(shù)里,就可以了。。
