標題: 關于單片機呼吸燈具體是如何實現的?占空比如何調整 [打印本頁]
作者: lar.ton    時間: 2019-5-15 23:14
下面代碼,我有一個問題一直困擾我沒有解決,所以來51hei論壇跟大家請教。
定時器中斷1,用一個數組調整占空比。那么這個值,是怎么傳遞并替換掉ConfigPWM(100, 90)中的90的呀?
我理解是定時器1每50ms進入一次,調整一次占空比。可定時器0,進入后,也會把占空比調整成90呀?
我問的問題不知道大家能否明白,希望高手解答,謝謝!
這個程序在開發板上跑過,能夠實現呼吸燈效果,所以程序邏輯和語法都是正確的。
#include <reg52.h>
sbit PWMOUT = P0^0;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned long PeriodCnt = 0;  //PWM周期計數值
unsigned char HighRH = 0;  //高電平重載值的高字節
unsigned char HighRL = 0;  //高電平重載值的低字節
unsigned char LowRH  = 0;  //低電平重載值的高字節
unsigned char LowRL  = 0;  //低電平重載值的低字節
unsigned char T1RH = 0;    //T1重載值的高字節
unsigned char T1RL = 0;    //T1重載值的低字節
void ConfigTimer1(unsigned int ms);
void ConfigPWM(unsigned int fr, unsigned char dc);
    EA = 1;     //開總中斷
    ENLED = 0;  //使能獨立LED
    ADDR3 = 1;
    ADDR2 = 1;
    ADDR1 = 1;
    ADDR0 = 0;
    ConfigPWM(100, 90);  //配置并啟動PWM
    ConfigTimer1(50);    //用T1定時調整占空比
    while (1);
/* 配置并啟動T1,ms-定時時間 */
    unsigned long tmp;  //臨時變量
    tmp = 11059200 / 12;      //定時器計數頻率
    tmp = (tmp * ms) / 1000;  //計算所需的計數值
    tmp = 65536 - tmp;        //計算定時器重載值
    tmp = tmp + 12;           //補償中斷響應延時造成的誤差
    T1RH = (unsigned char)(tmp>>8);  //定時器重載值拆分為高低字節
    T1RL = (unsigned char)tmp;
    TMOD &= 0x0F;   //清零T1的控制位
    TMOD |= 0x10;   //配置T1為模式1
    TH1 = T1RH;     //加載T1重載值
    TL1 = T1RL;
    ET1 = 1;        //使能T1中斷
    TR1 = 1;        //啟動T1
/* 配置并啟動PWM,fr-頻率,dc-占空比 */
    unsigned int high, low;
    PeriodCnt = (11059200/12) / fr; //計算一個周期所需的計數值
    high = (PeriodCnt*dc) / 100;    //計算高電平所需的計數值
    low  = PeriodCnt - high;        //計算低電平所需的計數值
    high = 65536 - high + 12;       //計算高電平的定時器重載值并補償中斷延時
    low  = 65536 - low  + 12;       //計算低電平的定時器重載值并補償中斷延時
    HighRH = (unsigned char)(high>>8); //高電平重載值拆分為高低字節
    HighRL = (unsigned char)high;
    LowRH  = (unsigned char)(low>>8);  //低電平重載值拆分為高低字節
    LowRL  = (unsigned char)low;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = HighRH;   //加載T0重載值
    TL0 = HighRL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動T0
    PWMOUT = 1;     //輸出高電平
/* 占空比調整函數,頻率不變只調整占空比 */
void AdjustDutyCycle(unsigned char dc)
/* T0中斷服務函數,產生PWM輸出 */
void InterruptTimer0() interrupt 1
    if (PWMOUT == 1)  //當前輸出為高電平時,裝載低電平值并輸出低電平
        TH0 = LowRH;
        TL0 = LowRL;
        PWMOUT = 0;
    else              //當前輸出為低電平時,裝載高電平值并輸出高電平
        TH0 = HighRH;
        TL0 = HighRL;
        PWMOUT = 1;
/* T1中斷服務函數,定時動態調整占空比 */
void InterruptTimer1() interrupt 3
    static bit dir = 0;
    static unsigned char index = 0;
    unsigned char code table[13] = {  //占空比調整表
        5, 18, 30, 41, 51, 60, 68, 75, 81, 86, 90, 93, 95
    TH1 = T1RH;  //重新加載T1重載值
    TL1 = T1RL;
    AdjustDutyCycle(table[index]); //調整PWM的占空比
    if (dir == 0)  //逐步增大占空比
        index++;
        if (index >= 12)
            dir = 1;
    else          //逐步減小占空比
        index--;
        if (index == 0)
            dir = 0;
作者: lele5211314    時間: 2019-5-16 17:34
首先你要了解PWM與方波的聯系和區別,寫程序的時候頭腦中一定要對PWM的占空比,還有周期清晰,二者缺一不可實現呼吸燈,如果你用的簡單的51單片機,可以利用定時器實現,如果用的STC12,15系列的單片機,本身就自帶了PWM功能,就需要簡單的設置就可以了
作者: lar.ton    時間: 2019-5-16 21:49
lele5211314 發表于 2019-5-16 17:34
首先你要了解PWM與方波的聯系和區別,寫程序的時候頭腦中一定要對PWM的占空比,還有周期清晰,二者缺一不可 ...
給講講上面代碼
作者: 三感    時間: 2019-5-18 13:29
#include <STC15.h>#include <INTRINS.h>typedef unsigned char u8;   //êyÖμ·¶Î§(0~255) typedef unsigned int  u32;  //êyÖμ·¶Î§(0~4294967295) typedef unsigned long ulong;//êyÖμ·¶Î§(0~4294967295)  void innt()//éèÖÃ׼˫Ïò¿ú {         P0M1=0x00;P0M0=0x00;         P1M1=0x00;P1M0=0x00;         P2M1=0x00;P2M0=0x00;         P3M1=0x00;P3M0=0x00;         P4M1=0x00;P4M0=0x00;         P5M1=0x00;P5M0=0x00; }void Delay(u32 t); void Breathe_LED(u32 t);  void main() {         innt();         while(1)         {                 Breathe_LED(1000);         } } u8 LED_Value=0x7F; void Breathe_LED(u32 t) {                  u32 i;         for(i=0;i<t;i++)         {                 P1=LED_Value;                 Delay(i);                 P1=0xFF;                 Delay(t-i);         }         for(i=t;i>0;i--)         {                 P1=LED_Value;                 Delay(i);                 P1=0xFF;                 Delay(t-i);         }         LED_Value>>=1; }  void Delay(u32 t) {         while(t--); }
作者: 牡丹亭    時間: 2019-5-18 14:36
PWM與方波的聯系密不可分,周期要搞清楚。
