標(biāo)題: 1寸數(shù)碼管時(shí)鐘(單片機(jī)程序)帶溫度計(jì)顯示的想修改為不帶時(shí)鐘 [打印本頁]
作者: ll13536121668    時(shí)間: 2019-5-13 16:36
本帖最后由 ll13536121668 于 2019-5-21 11:00 編輯
各位師博幫忙看看這個(gè)源碼,修改成單獨(dú)顯示溫度計(jì)可以嗎?上傳看看謝謝
能否可以修改成不帶時(shí)鐘  開機(jī)就是顯示溫度
#include <reg51.h>
#include <math.h>
#include "ADC.H"
#include "ds1302.h"
bit flag, Bell_Swh=1,Hourb,Minb,Kgb,flag_read,dot_Bell=1,Bell_Swh1=1;//鬧鐘調(diào)時(shí)閃爍標(biāo)志位
bit sec=0,min=0,hour=0,year=0,mon=0,day=0,weekk=0,hour_Bell=0,min_Bell=0,hour_time=0,min_time=0;flag_bell=0,bell_bug = 0; //閃爍標(biāo)志位
unsigned char id,id2,d,e,S_1302,S1_1302,H_1302,H_Bell,S_Bell,H_time,S_time; //
unsigned char disbuff[4]        ={0};
unsigned char time=0;
unsigned int temp[1];
unsigned int temp_num = 0;
unsigned char code LEDData1 [ ] = {  0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff }; //正0-9LED數(shù)值
unsigned char code LEDData2 [ ] = {  0xc0,0xcf,0xA4,0x86,0x8B,0x92,0x90,0xc7,0x80,0x82,0xff }; //反0-9LED數(shù)值
void Delayms(unsigned int di) //延時(shí)
        unsigned int da,db;
         for(da=0;da<di;da++)
                   for(db=0;db<10;db++);
void Display(void)  //掃描方式led1~led4循環(huán)點(diǎn)亮
   time++;
   if(time==1)
           if(dot_Bell)
       P2=LEDData1[disbuff[0]]&0x7f;// 0x7F點(diǎn)亮DP小數(shù)點(diǎn)
       LED1=0; LED4=1;
       P2=LEDData1[disbuff[0]];
       LED1=0; LED4=1;
   if(time==2)
      if(id>=3)
           P2=(LEDData2[disbuff[1]])&0x7F;
       LED1=1; LED2=0;
      if(flag)
       LED1=1; LED2=0;
           P2=LEDData2[disbuff[1]];
       LED1=1; LED2=0;
   if(time==3)
     if(id>=3)
         P2=LEDData1[disbuff[2]]&0x7f;
         LED2=1; LED3=0;
      if(flag)
         LED2=1; LED3=0;
         P2=LEDData1[disbuff[2]];
         LED2=1; LED3=0;
   if(time==4)
     time=0;
     if(disbuff[3]==0)
      P2=LEDData1[10];
      LED3=1; LED4=0;
                P2=LEDData1[disbuff[3]];
        LED3=1; LED4=0;
void Disp(void)//顯示和閃爍函數(shù)
        unsigned int i=0;
        unsigned char a=0,b=0,c=0,f=0;
        if(hour==1)  //小時(shí)閃爍標(biāo)志位
            if(flag==1)
                        b=read_clock(0x85);//讀小時(shí)
                 a=b;
                b=b>>4;
                a=a&0x0f;
                    disbuff[3]=b;
                    disbuff[2]=a;
                   disbuff[2]=10;
                   disbuff[3]=10;
            if(flag_read==1)//250MS 讀一次
                         H_1302=read_clock(0x85);//讀小時(shí)
                 a=b;
                b=b>>4;
                a=a&0x0f;
                    disbuff[3]=b;
                    disbuff[2]=a;
        if(min==1)  //分鐘閃爍標(biāo)志位
            if(flag==1)
                   d=read_clock(0x83);//讀分鐘
               e=d;
               d=d>>4;
               e=e&0x0f;
                   disbuff[1]=d;
                      disbuff[0]=e;
                 disbuff[1]=10;
                   disbuff[0]=10;
           if(flag_read==1)        //250MS讀寫一次
                 S1_1302=read_clock(0x81);//讀秒
             S_1302=read_clock(0x83);//讀分鐘
             e=d;
             d=d>>4;
              e=e&0x0f;
                 disbuff[1]=d;
                 disbuff[0]=e;
void Disp2(void)//顯示和閃爍函數(shù)
        unsigned int i=0;
        if(hour_Bell==1)  //小時(shí)閃爍標(biāo)志位
            if(flag==1)
                        b=read_clock(0xc3);//讀小時(shí)
                 a=b;
                b=b>>4;
                a=a&0x0f;
                    disbuff[3]=b;
                    disbuff[2]=a;
                   disbuff[2]=10;
                   disbuff[3]=10;
            if(flag_read==1)
                    H_Bell=read_clock(0xc3);//讀取鬧鐘的時(shí)
                S_Bell=read_clock(0xc5);//讀取鬧鐘的分
                 a=b;
                b=b>>4;
                a=a&0x0f;
                    disbuff[3]=b;
                    disbuff[2]=a;
        if(min_Bell==1)  //分鐘閃爍標(biāo)志位
            if(flag==1)
                   d=read_clock(0xc5);//讀分鐘
               e=d;
               d=d>>4;
               e=e&0x0f;
                   disbuff[1]=d;
                      disbuff[0]=e;
                 disbuff[1]=10;
                   disbuff[0]=10;
             e=d;
             d=d>>4;
              e=e&0x0f;
                 disbuff[1]=d;
                 disbuff[0]=e;
void Disp3(void)//顯示和閃爍函數(shù)
        unsigned int i=0;
        if(hour_time==1)  //小時(shí)閃爍標(biāo)志位
            if(flag==1)
                        b=read_clock(0xc7);//讀小時(shí)
                 a=b;
                b=b>>4;
                a=a&0x0f;
                    disbuff[3]=b;
                    disbuff[2]=a;
                   disbuff[2]=10;
                   disbuff[3]=10;
            if(flag_read==1)
                    H_time=read_clock(0xc7);//讀取鬧鐘的時(shí)
                S_time=read_clock(0xc9);//讀取鬧鐘的分
                        if(H_time>S_time)
                        unsigned char i;
                        i=H_time;
                        H_time=S_time;
                        S_time=i;
                 a=b;
                b=b>>4;
                a=a&0x0f;
                    disbuff[3]=b;
                    disbuff[2]=a;
        if(min_time==1)  //分鐘閃爍標(biāo)志位
            if(flag==1)
                   d=read_clock(0xc9);//讀分鐘
               e=d;
               d=d>>4;
               e=e&0x0f;
                   disbuff[1]=d;
                      disbuff[0]=e;
                 disbuff[1]=10;
                   disbuff[0]=10;
             e=d;
             d=d>>4;
              e=e&0x0f;
                 disbuff[1]=d;
                 disbuff[0]=e;
        void id_case1_key(void)//id為1時(shí)的下一級選擇
        if(Add_Key == 0) //增加
            Delay(4000);
               if(Add_Key == 0) {while(Add_Key ==0); Set_time(id,0); }
         //調(diào)用Set_time函數(shù)
void id_case2_key(void)//id為1時(shí)的下一級選擇
            Delay(4000);
               if(Add_Key == 0) {while(Add_Key ==0); Set_Bell(id,0);}
                   //        Set_Bell(id,0);  //調(diào)用Set_Bell函數(shù)
                        //while(Add_Key ==0);
void id_AD_scan_key(void)
        if(Add_Key == 0)
                Delay(4000);
                if(Add_Key == 0)
                        ET1 = 0;
                        id = 0;
                        ET0 = 1;
                //        return;
void id_case3_key(void)//id為1時(shí)的下一級選擇
            Delay(300);
               if(Add_Key == 0)
                  dot_Bell=~dot_Bell;
              Bell_Swh=dot_Bell;
              write_clock(0x8e,0x00);//允許寫操作
                  write_clock(0xc8,Bell_Swh);
          write_clock(0x8e,0x80);//寫保護(hù),禁止寫操作
                  while(Add_Key ==0);
void Set_Bell(unsigned char sel, bit sel_1)//根據(jù)選擇調(diào)整相應(yīng)項(xiàng)目
  signed char address,item;
  signed char max,mini;
  //if(sel==4)  {address=0xc6; max=59;mini=0;}    //秒
  if(sel==4)  {address=0xc2; max=23; mini=0;}   //時(shí)
  if(sel==5)  {address=0xc4; max=59;mini=0;}    //分
  if(sel==6)        //標(biāo)志位
//          address=0xc8;//for read
//        if(Add_Key ==0 || Dec_Key ==0)
//        Bell_Swh=~Bell_Swh;
//        write_clock(address,Bell_Swh);
          //address=0xc8;
          dot_Bell=~dot_Bell;
              Bell_Swh=dot_Bell;
                  write_clock(0xca,Bell_Swh);
  }    //開關(guān)
  if(sel==7)  {address=0xc6; max=23;mini=0;}    //分
  if(sel==8)  {address=0xc8; max=23; mini=0;}   //時(shí)
    if(sel==9)        //標(biāo)志位
          //address=0xc8;
          dot_Bell=~dot_Bell;
              Bell_Swh1=dot_Bell;
                  write_clock(0xcc,Bell_Swh1);
  }    //開關(guān)
  item=((read_clock(address+1))/16)*10 + (read_clock(address+1))%16;
  if(sel_1==0)
          item++;
          item--;
  if(item>max) item=mini;
  if(item<mini) item=max;
  write_clock(address,(item/10)*16+item%10);//轉(zhuǎn)換成16進(jìn)制寫入1302
void Timer0_Init(void)//定時(shí)器0初始化
        AUXR &= 0x7F;                //定時(shí)器時(shí)鐘12T模式
        TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
        TL0 = 0x18;                //設(shè)置定時(shí)初值
        TH0 = 0xFC;                //設(shè)置定時(shí)初值
        TF0 = 0;                //清除TF0標(biāo)志
        TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
        ET0=  1;*/
//2毫秒@6.000MHz
        AUXR |= 0x80;                //定時(shí)器時(shí)鐘1T模式
        TL0 = 0x20;                //設(shè)置定時(shí)初值
        TH0 = 0xD1;                //設(shè)置定時(shí)初值
        ET0 = 1; //enable timer0 interrupt*/
//2毫秒@12.000MHz
        TL0 = 0x40;                //設(shè)置定時(shí)初值
        TH0 = 0xA2;                //設(shè)置定時(shí)初值
void Timer1Init(void)                //20毫秒@12.000MHz
        AUXR &= 0xBF;                //定時(shí)器時(shí)鐘12T模式
        TMOD &= 0x0F;                //設(shè)置定時(shí)器模式
        TL1 = 0xE0;                //設(shè)置定時(shí)初值
        TH1 = 0xB1;                //設(shè)置定時(shí)初值
        TF1 = 0;                //清除TF1標(biāo)志
        TR1 = 1;                //定時(shí)器1開始計(jì)時(shí)
void Timer0(void) interrupt 1 using 1//中斷入口,冒號閃爍
        static unsigned char timecount = 0;//
          timecount++;
        if(timecount > 125)
                 flag_read = ~flag_read;
  if(timecount > 250)//500MS
            timecount = 0;
            flag = ~flag;
        Display();
void Timer1(void) interrupt 3 using 1
        temp_num++;
        if(temp_num > 40)
                temp_num = 0;
void ADC_convert(void)
        //EA = 0;//關(guān)中斷
        ET0 = 0;
        if(temp_num == 0)
                GetADCResult(6,&temp[0]);
          //temp[0] = (unsigned int) ( ( 3950.0 / ( 11.33657 + log( 6.04 * (float)temp[0] / ( 1024.0 - (float)temp[0] ) ) ) - 273.15 ) * 100 );
          temp[0]=(unsigned int) ((1/(log(((float)temp[0]*4700/(1024-(float)temp[0]))/10000)/3950+1/298.15)-273.15)*100);
                temp_num = 1;
        P2 = LEDData1[temp[0]/1000]; //千位
        LED4 = 0;
        Delayms(50);
        LED4 = 1;
        P2 = (LEDData1[temp[0]%1000/100])&0x7F;//百位
        LED3 = 0;
        Delayms(50);
        LED3 = 1;
        P2 = LEDData2[temp[0]%1000%100/10];//十位
        LED2 = 0;
        Delayms(50);
        LED2 = 1;
        P2 = 0xa7;//c
        LED1 = 0;
  Delayms(50);
        LED1 = 1;
//        id = 0;
        ET1 = 1;//啟動(dòng)定時(shí)器1
void main(void)//主函數(shù)
  P3M1=0x00;
        P3M0=0x08;
                                dot_Bell= Bell_Swh;
        InitADC(); //初始化ADC
        Timer0_Init();//定時(shí)器T0初始化
        Timer1Init();
        EA=1;
        while(1)//主循環(huán)
                //設(shè)置時(shí)鐘的初始值,顯示14年4月5號11:59:55
          if(OK_Key == 0 && Add_Key == 0)
                        Delay(1000);
                            while(OK_Key == 0);//等待鍵松開
                                Init_1302();
                                dot_Bell= Bell_Swh;
//                MF:   //返回主界面
                if (OK_Key == 0) // 設(shè)置和選擇項(xiàng)目鍵
                       Delay(1000);
               if(OK_Key == 0)
                                  id++;
                                        if(id == 2)
                                                ET1 = 0;
                                                ET0 = 1;
                                  if(id>9)id=0;
             switch( id )
                       case 0:hour=0;min=0;Disp( );                         dot_Bell= Bell_Swh;break;//正常顯示
                                        case 1:hour=0;min=0;ADC_convert();id_AD_scan_key();  dot_Bell= Bell_Swh;break;//顯示溫度
                 case 2:hour=1;id_case1_key();Disp();                 dot_Bell=0;break;  //小時(shí)
                            case 3:hour=0;min=1;id_case1_key();Disp();           dot_Bell=0;break; //分鐘
          case 4:hour_Bell=1;id_case2_key();Disp2();           dot_Bell= Bell_Swh;break;
                 case 5:hour_Bell=0;min_Bell=1;id_case2_key();Disp2();dot_Bell= Bell_Swh;break;
                 case 6:hour_Bell=0;min_Bell=0;id_case2_key();Disp2();dot_Bell= Bell_Swh;break;
                       case 7:hour_time=1;id_case2_key();Disp3();           dot_Bell= Bell_Swh1;break;
                       case 8:hour_time=0;min_time=1;id_case2_key();Disp3();dot_Bell= Bell_Swh1;break;
                            case 9:hour_time=0;min_time=0;id_case2_key();Disp3();dot_Bell= Bell_Swh1;break;
                 default:break;
                        if(Bell_Swh == 1)//鬧鐘為開
                        if(H_Bell == H_1302)
                                if(S_Bell == S_1302)        //分相等
                                   if(S1_1302==0)        //秒等于0才開鬧鐘
                                      flag_bell=1;
                                   if(Add_Key ==0 )//按加退出
                                            flag_bell=0;
                        flag_bell=0;
                }//if
/*                                if(Bell_Swh1 == 1)//整點(diǎn)報(bào)
                        if((H_1302 >=H_time )&&(H_1302<=S_time))
                                if( S_1302 == 0 )        //分相等
                                                if(id != 2)
                                     if(S1_1302==0x00)        //秒等于0才開鬧鐘
                                            flag_bell=1;
                                                  bell_bug++;        //
                                                         if(bell_bug == 2)  //整點(diǎn)報(bào)時(shí)bug修正小函數(shù)
        bell_bug = 0;   //
        flag_bell = 0;   //
                                            flag_bell=0;
                }//if  */
                                if( (S_1302 == 0) && ((S1_1302==0x00)) )        //分相等  //秒等于0才開鬧鐘
                                                if(id != 2)
                                                        if(id != 3)
                                            flag_bell=1;
                                                  bell_bug++;        //
        bell_bug = 0;   //
        flag_bell = 0;   //
        flag_bell=0;
                                             flag_bell=0;
                                                flag_bell = 0;
                                flag_bell = 0;
                }//if
                if(flag_bell)  //
                 Bell();
        }//while
}//main
1寸大鐘1_ok(程序).rar
90.58 KB, 下載次數(shù): 31
