51單片機驅動NRF24l01程序卡在IRQ一直高電平
smileto
2019-5-12 21:46
用普中的51開發板,用的代碼如下: 卡死在while(IRQ);上:
#include <reg51.h>
#define TX_ADR_WIDTH 5 // 5字節寬度的發送/接收地址
#define TX_PLOAD_WIDTH 4 // 數據通道有效數據寬度
sbit LED = P2^7;
sbit KEY1 = P3^0;
sbit KEY2 = P3^1;
//uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // 定義一個靜態發送地址
uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x11,0x22,0x33,0x44,0x55}; // 定義一個靜態發送地址
uchar RX_BUF[TX_PLOAD_WIDTH];
uchar TX_BUF[TX_PLOAD_WIDTH];
uchar flag;
uchar DATA = 0x01;
uchar bdata sta;
sbit RX_DR = sta^6;
sbit TX_DS = sta^5;
sbit MAX_RT = sta^4;
sbit CE = P1^0;
sbit CSN= P3^7;
sbit SCK= P3^6;
sbit MOSI= P2^2;
sbit MISO= P2^0;
sbit IRQ = P3^3;
// SPI(nRF24L01) commands
#define READ_REG 0x00 // Define read command to register
#define WRITE_REG 0x20 // Define write command to register
#define RD_RX_PLOAD 0x61 // Define RX payload register address
#define WR_TX_PLOAD 0xA0 // Define TX payload register address
#define FLUSH_TX 0xE1 // Define flush TX register command
#define FLUSH_RX 0xE2 // Define flush RX register command
#define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
#define NOP 0xFF // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG 0x00 // 'Config' register address
#define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
#define SETUP_AW 0x03 // 'Setup address width' register address
#define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
#define RF_CH 0x05 // 'RF channel' register address
#define RF_SETUP 0x06 // 'RF setup' register address
#define STATUS 0x07 // 'Status' register address
#define OBSERVE_TX 0x08 // 'Observe TX' register address
#define CD 0x09 // 'Carrier Detect' register address
#define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
#define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
#define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
#define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
#define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
#define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
#define TX_ADDR 0x10 // 'TX address' register address
#define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
#define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
#define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
#define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
#define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
#define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
void blink(char i);
函數: init_io()
描述:
初始化IO
void init_io(void)
CE = 0; // 待機
CSN = 1; // SPI禁止
SCK = 0; // SPI時鐘置低
IRQ = 1; // 中斷復位
LED = 1; // 關閉指示燈
函數:delay_ms()
描述:
延遲x毫秒
void delay_ms(uchar x)
uchar i, j;
i = 0;
for(i=0; i<x; i++)
j = 250;
while(--j);
j = 250;
while(--j);
函數:SPI_RW()
描述:
根據SPI協議,寫一字節數據到nRF24L01,同時從nRF24L01
讀出一字節
uchar SPI_RW(uchar byte)
uchar i;
for(i=0; i<8; i++) // 循環8次
MOSI = (byte & 0x80); // byte最高位輸出到MOSI
byte <<= 1; // 低一位移位到最高位
SCK = 1; // 拉高SCK,nRF24L01從MOSI讀入1位數據,同時從MISO輸出1位數據
byte |= MISO; // 讀MISO到byte最低位
SCK = 0; // SCK置低
return(byte); // 返回讀出的一字節
函數:SPI_RW_Reg()
描述:
寫數據value到reg寄存器
uchar SPI_RW_Reg(uchar reg, uchar value)
uchar status;
CSN = 0; // CSN置低,開始傳輸數據
status = SPI_RW(reg); // 選擇寄存器,同時返回狀態字
SPI_RW(value); // 然后寫數據到該寄存器
CSN = 1; // CSN拉高,結束數據傳輸
return(status); // 返回狀態寄存器
函數:SPI_Read()
描述:
從reg寄存器讀一字節
uchar SPI_Read(uchar reg)
uchar reg_val;
reg_val = SPI_RW(0); // 然后從該寄存器讀數據
return(reg_val); // 返回寄存器數據
函數:SPI_Read_Buf()
描述:
從reg寄存器讀出bytes個字節,通常用來讀取接收通道
數據或接收/發送地址
uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
uchar status, i;
for(i=0; i<bytes; i++)
pBuf[i] = SPI_RW(0); // 逐個字節從nRF24L01讀出
函數:SPI_Write_Buf()
描述:
把pBuf緩存中的數據寫入到nRF24L01,通常用來寫入發
射通道數據或接收/發送地址
uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
uchar status, i;
SPI_RW(pBuf[i]); // 逐個字節寫入nRF24L01
函數:RX_Mode()
描述:
這個函數設置nRF24L01為接收模式,等待接收發送設備的數據包
void RX_Mode(void)
CE = 0;
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 接收設備接收通道0使用和發送設備相同的發送地址
SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 使能接收通道0自動應答
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 使能接收通道0
SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 選擇射頻通道0x40
SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // 接收通道0選擇和發送通道相同有效數據寬度
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x0f); // 數據傳輸率1Mbps,發射功率0dBm,低噪聲放大器增益
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // CRC使能,16位CRC校驗,上電,接收模式
delay_ms(150);
CE = 1; // 拉高CE啟動接收設備
函數:TX_Mode()
描述:
這個函數設置nRF24L01為發送模式,(CE=1持續至少10us),
130us后啟動發射,數據發送結束后,發送模塊自動轉入接收
模式等待應答信號。
void TX_Mode(uchar * BUF)
CE = 0;
SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 寫入發送地址
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 為了應答接收設備,接收通道0地址和發送地址相同
SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH); // 寫數據包到TX FIFO
SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a); // 自動重發延時等待250us+86us,自動重發10次
SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 選擇射頻通道0x40
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // 數據傳輸率1Mbps,發射功率0dBm,低噪聲放大器增益
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // CRC使能,16位CRC校驗,上電
delay_ms(150);
CE = 1;
函數:Check_ACK()
描述:
檢查接收設備有無接收到數據包,設定沒有收到應答信
號是否重發
uchar Check_ACK(bit clear)
LED = 0;
//delay_ms(200);
while(IRQ);
LED = 1;
sta = SPI_RW(NOP); // 返回狀態寄存器
if(TX_DS)
blink(3);
//blink(5);
if(MAX_RT)
if(clear) // 是否清除TX FIFO,沒有清除在復位MAX_RT中斷標志后重發
SPI_RW(FLUSH_TX);
SPI_RW_Reg(WRITE_REG + STATUS, sta); // 清除TX_DS或MAX_RT中斷標志
IRQ = 1;
if(TX_DS)
return(0x00);
return(0xff);
函數:CheckButtons()
描述:
檢查按鍵是否按下,按下則發送一字節數據
void CheckButtons()
if(KEY1 == 0)
delay_ms(20);
if(KEY1 == 0)
TX_BUF[0] = 1; // 數據送到緩存
//TX_BUF[0] = 0xff; // 數據送到緩存
TX_Mode(TX_BUF); // 把nRF24L01設置為發送模式并發送數據
//LED = ~DATA; // 數據送到LED顯示
Check_ACK(0); // 等待發送完畢,清除TX FIFO
delay_ms(250);
delay_ms(250);
blink(2);
if(KEY2 == 0)
delay_ms(20);
if(KEY2 == 0)
TX_BUF[0] = 2; // 數據送到緩存
delay_ms(250);
delay_ms(250);
blink(3);
void blink(char i)
while(i--)
LED = 1;
delay_ms(500);
LED = 0;
delay_ms(500);
函數:main()
描述:
主函數
void main(void)
init_io(); // 初始化IO
CheckButtons(); // 按鍵掃描
allen98
2024-4-25 12:33
你好,請問一下你這個問題解決了嗎
fosu頑童
2024-4-25 14:27
函數:TX_Mode()
描述:
130us后啟動發射,
數據發送結束后,發送模塊自動轉入接收
模式等待應答信號。
CE = 0;
使能接收通道0自動應答
0x0e
delay_ms(150);
CE = 1;
這里還沒配置完就發送數據了,明顯是有誤。
是需要配置完才執行發送數據的命令,發送數據包的命令最好跟判斷是否發送完成放在同一個子函數。
