前幾天做51單片機16X16點陣仿真程序
13118302007
2019-4-30 23:03
前幾天幫人做的設(shè)計--51單片機16X16點陣,直接上圖,勿噴!
(144.63 KB, 下載次數(shù): 57)
2019-4-30 23:02 上傳
附件是所有資料,有需要的隨便下載就行了!
/* 作品名稱:基于51單片機的16*16點陣設(shè)計
/* 時 間 :2019年4月11日晚
#include <reg51.h>
char code table[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",12*/
0x80,0x00,0x90,0x80,0x8C,0x80,0x84,0x84,0x84,0x46,0x84,0x49,0xF5,0x28,0x86,0x10,
0x84,0x10,0x84,0x2C,0x84,0x23,0x84,0x40,0x94,0x80,0x8C,0x00,0x80,0x00,0x00,0x00,//安,0
0x20,0x10,0x18,0x08,0x08,0x04,0x08,0x02,0x08,0xFF,0xC8,0x40,0x38,0x20,0xCF,0x00,
0x08,0x03,0x08,0x04,0x08,0x0A,0x08,0x11,0xA8,0x20,0x18,0x40,0x00,0x40,0x00,0x00,//農(nóng),1
0x20,0x22,0x30,0x67,0xAC,0x22,0x63,0x12,0x20,0x12,0x18,0x12,0x80,0x40,0x82,0x42,
0x42,0x42,0x22,0x42,0x12,0x7E,0x1A,0x42,0x26,0x42,0x42,0x42,0x80,0x40,0x00,0x00,//經(jīng),2
0x00,0x00,0x00,0x00,0xF8,0x1F,0x88,0x08,0x88,0x08,0x88,0x08,0x88,0x08,0xFF,0x7F,
0x88,0x88,0x88,0x88,0x88,0x88,0x88,0x88,0xF8,0x9F,0x00,0x80,0x00,0xF0,0x00,0x00,//電,3
0x20,0x00,0x10,0x00,0x4C,0x00,0x47,0x00,0x54,0x00,0x54,0x00,0x54,0x00,0x54,0x00,
0x54,0x00,0x54,0x00,0x54,0x00,0xD4,0x0F,0x04,0x30,0x04,0x40,0x00,0xF0,0x00,0x00,//氣,4
0x00,0x10,0x00,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,
0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x00,0x10,0x00,0x10,0x00,0x00,//二,5
0x84,0x10,0x84,0x30,0xFC,0x1F,0x84,0x08,0x84,0x88,0x00,0x42,0xF8,0x21,0x00,0x18,
0xFF,0x07,0x00,0x00,0x84,0x20,0x84,0x20,0xFC,0x3F,0x84,0x20,0x84,0x20,0x00,0x00,//班,6
//0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//0x00,0x00,0xE0,0x00,0xF0,0x01,0xF8,0x03,0xFC,0x07,0xFC,0x0F,0xF8,0x1F,0xF0,0x3F,
//0xF8,0x1F,0xFC,0x0F,0xFC,0x07,0xF8,0x03,0xF0,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,
void delay(int c)
int i,j;
for(i=0;i<c;i++)
for(j=0;j<10;j++)
unsigned char i,j;
unsigned int b=0;
unsigned char a;
j=0;
if(a>80)
a=0;
b+=32;
if(b>=512-64-6*32)
b=0;
P3=1;
for(i=0;i<16;i++)
P1=i;
P0=table[j+b];
P2=table[j+b+1];
delay(10);
P0=0x00;
P2=0x00;
j+=2;
P3=0;
for(i=0;i<16;i++)
P1=i;
P0=table[j+b];
P2=table[j+b+1];
delay(10);
P0=0x00;
P2=0x00;
j+=2;
a++;
16-16點陣.zip
(59.17 KB, 下載次數(shù): 118)
2019-4-30 23:01 上傳
laoqian
2019-5-12 22:52
第8行和第9行是什么意思啊,我弄的LED一直顯示亂碼
xianyu1979
2019-5-13 08:13
新手學(xué)習(xí)了,謝謝
追求吖
2019-6-5 01:33
你這個P代表的是行,K代表的是列對吧?
nutbrain
2020-1-7 15:36
請問是什么仿真軟件?proteus嗎?
HONG_ye
2020-3-8 19:11
小哥,代做16*16點陣滾動漢字嗎,原理和你的這個差不多一樣,就是protues里面用到的不是595,而是574,價錢可以商量哈
169146145
2020-12-16 09:10
你這個P代表的是行,K代表的是列對吧?
田園diy
2021-1-29 21:35
能介紹一下,程序中變量 i,j ,b,a,都是什么意思嗎?謝謝了
