51智能小車超聲波測距l(xiāng)cd顯示源碼
徐天贊
2019-3-20 09:15
#include <reg52.h>
#include <intrins.h>
#include "lcd.h"
sbit ENA = P1^6; //定義ENA為P1^1端口
sbit ENB = P1^7;
sbit IN1 = P1^2;
sbit IN2 = P1^3;
sbit IN3 = P1^4;
sbit IN4 = P1^5;
sbit Trig = P2^1;
sbit Echo = P2^0;
sbit left_1_led = P3^4; //宏定義左避障模塊為p3^6口
sbit right_1_led = P3^5;//宏定義右避障模塊為p3^7口
sbit left_x = P3^7;
sbit right_x = P3^6;
unsigned char pwm_t = 0; //定義周期
unsigned char Disp[]=" 4:XU:TIAN:ZAN ";
unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
unsigned char left_pwm_val = 100,right_pwm_val = 100; //左右電機占空比值
static unsigned char DisNum = 0; //顯示用指針
unsigned int time=0;
unsigned long S=0;
bit flag =0;
unsigned char disbuff[4] ={ 0,0,0,0,};
void Conut(void)
time=TH1*256+TL1;
TH1=0;
TL1=0;
S=(time*1.7)/100; //算出來是CM
if((S>=700)||flag==1) //超出測量范圍顯示“-”
flag=0;
DisplayOneChar(0, 1, ASCII[11]);
DisplayOneChar(1, 1, ASCII[10]); //顯示點
DisplayOneChar(2, 1, ASCII[11]);
DisplayOneChar(3, 1, ASCII[11]);
DisplayOneChar(4, 1, ASCII[12]); //顯示M
disbuff[0]=S%1000/100;
disbuff[1]=S%1000%100/10;
disbuff[2]=S%1000%10 %10;
DisplayOneChar(0, 1, ASCII[disbuff[0]]);
DisplayOneChar(2, 1, ASCII[disbuff[1]]);
DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void zd0() interrupt 3 //T0中斷用來計數(shù)器溢出,超過測距范圍
flag=1; //中斷溢出標志
void StartModule() //啟動模塊
Trig=1; //啟動一次模塊
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
Trig=0;
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
void run() //小車前進函數(shù)
IN1 = 1; //左電機前進
IN2 = 0;
IN3 = 1; //右電機前進
IN4 = 0;
//左轉(zhuǎn)
void leftrun(void)
IN1 = 0;
IN2 = 0;
IN3 = 1;
IN4 = 0;
//右轉(zhuǎn)
void rightrun(void)
IN1 = 1;
IN2 = 0;
IN3 = 0;
IN4 = 0;
//停止
void stop(void)
IN1 = 0;
IN2 = 0;
IN3 = 0;
IN4 = 0;
void bi(void) //小車避障函數(shù)
//有信號為0 無信號為1
if(left_1_led == 1 && right_1_led == 1)
run();
if(left_1_led == 1 && right_1_led == 0)
stop();
if(left_1_led == 0 && right_1_led == 1)
stop();
if(left_1_led == 0 && right_1_led == 0)
stop();
void timer0(void) interrupt 1 //定時器中斷服務(wù)程序
pwm_t++;
if(pwm_t == 255) //周期最大值時 清零
pwm_t = ENA = ENB = 0;
if(left_pwm_val == pwm_t) //左電機占空比等于周期時
ENA = 1; //使能ENA
if(right_pwm_val == pwm_t) //右電機占空比等于周期時
ENB = 1; //使能ENB
void Time0Config()
TMOD|= 0x02; //八位自動重裝模式
TH0= 220; //1ms定時
TL0= 220;
ET0 = 1; //允許定時器0中斷
EA = 1; //開啟總中斷
TR0 = 1; //開啟定時器0
void Time1Config()
TMOD=0x10; //設(shè)T0為方式1,GATE=1;
TH1=0;
TL1=0;
ET1=1; //允許T1中斷
EA=1; //開啟總中斷
void main(void)
LcdInit();
LcdShowStr(0,0,Disp);
Time1Config();
Time0Config(); //定時器函數(shù)
while(1) //無限循環(huán)
StartModule();
while(!Echo); //當(dāng)RX為零時等待
TR1=1; //開啟計數(shù)
while(Echo); //當(dāng)RX為1計數(shù)并等待
TR1=0; //關(guān)閉計數(shù)
Conut(); //計算
delayms(10);
if((left_x!=1)||(right_x!=1))
if((left_x==1)&&(right_x==0))
bi();
leftrun();
if((left_x==0)&&(right_x==1))
bi();
rightrun();
if((left_x==0)&&(right_x==0))
bi();
run();
if((left_x==1)&&(right_x==1))
stop();
lcd顯示
#include "lcd.h"
* 函 數(shù) 名 : Lcd1602_Delay1ms
* 函數(shù)功能 : 延時函數(shù),延時1ms
* 輸 入 : c
* 輸 出 : 無
* 說 名 : 該函數(shù)是在12MHZ晶振下,12分頻單片機的延時。
void Lcd1602_Delay1ms(uint c) //誤差 0us
uchar a,b;
for (; c>0; c--)
for (b=199;b>0;b--)
for(a=1;a>0;a--);
* 函 數(shù) 名 : LcdWriteCom
* 函數(shù)功能 : 向LCD寫入一個字節(jié)的命令
* 輸 入 : com
* 輸 出 : 無
#ifndef LCD1602_4PINS //當(dāng)沒有定義這個LCD1602_4PINS時
void LcdWriteCom(uchar com) //寫入命令
LCD1602_E = 0; //使能
LCD1602_RS = 0; //選擇發(fā)送命令
LCD1602_RW = 0; //選擇寫入
LCD1602_DATAPINS = com; //放入命令
Lcd1602_Delay1ms(1); //等待數(shù)據(jù)穩(wěn)定
LCD1602_E = 1; //寫入時序
Lcd1602_Delay1ms(5); //保持時間
LCD1602_E = 0;
#else
LCD1602_E = 0; //使能清零
LCD1602_RS = 0; //選擇寫入命令
LCD1602_DATAPINS = com; //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
LCD1602_E = 0;
LCD1602_DATAPINS = com << 4; //發(fā)送低四位
LCD1602_E = 0;
#endif
* 函 數(shù) 名 : LcdWriteData
* 函數(shù)功能 : 向LCD寫入一個字節(jié)的數(shù)據(jù)
* 輸 入 : dat
* 輸 出 : 無
void LcdWriteData(uchar dat) //寫入數(shù)據(jù)
LCD1602_RS = 1; //選擇輸入數(shù)據(jù)
LCD1602_DATAPINS = dat; //寫入數(shù)據(jù)
LCD1602_E = 0;
#else
LCD1602_RS = 1; //選擇寫入數(shù)據(jù)
LCD1602_DATAPINS = dat; //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
LCD1602_E = 0;
LCD1602_DATAPINS = dat << 4; //寫入低四位
LCD1602_E = 0;
#endif
* 函 數(shù) 名 : LcdInit()
* 函數(shù)功能 : 初始化LCD屏
* 輸 入 : 無
* 輸 出 : 無
void LcdInit() //LCD初始化子程序
LcdWriteCom(0x38); //開顯示
LcdWriteCom(0x0c); //開顯示不顯示光標
LcdWriteCom(0x06); //寫一個指針加1
LcdWriteCom(0x01); //清屏
LcdWriteCom(0x80); //設(shè)置數(shù)據(jù)指針起點
#else
LcdWriteCom(0x32); //將8位總線轉(zhuǎn)為4位總線
LcdWriteCom(0x28); //在四位線下的初始化
#endif
void LcdSetCursor(unsigned char x,unsigned char y) //坐標顯示
unsigned char addr;
if(y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
LcdWriteCom(addr|0x80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str) //顯示字符串
LcdSetCursor(x,y); //當(dāng)前字符的坐標
while(*str != '\0')
LcdWriteData(*str++);
//按指定位置顯示一個字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當(dāng)要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
LcdWriteCom(X); //發(fā)命令字
LcdWriteData(DData); //發(fā)數(shù)據(jù)
admin
2019-3-20 18:23
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
