標題: 大家幫看一下,PIC單片機程序為什么得不到正確的返回值? [打印本頁]
作者: gravedigger    時間: 2019-3-19 12:07
MCU是PIC12F675
#include<pic.h>
#include <xc.h>
#pragma config FOSC = INTRCIO   // Oscillator Selection bits (INTOSC oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-Up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF      // GP3/MCLR pin function select (GP3/MCLR pin function is digital I/O, MCLR internally tied to VDD)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config CP = OFF         // Code Protection bit (Program Memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
#define ad GP2
#define led1 GP4//??
#define led2 GP5//??
uchar adnum1;
uchar adnum2;
uchar i;
uint get_ad();
void delay(void)
    unsigned int i;
    for(i=0;i<20000;i++);
void display(uchar adnum1,uchar adnum2)
        for(i=0;i<adnum1;i++)
        led1=0;led2=0;delay();//開燈GP4低電平有效,GP5高電平有效
        led1=1;led2=0; delay();//關燈
    delay();
    for(i=0;i<adnum2;i++)
        led1=1;led2=1;delay();
uint get_ad()
    uint adval;//=0;
    adval=0b1000101100;
    return(adval);
void advalue()
    uint adnum;
    uint advin;
    float vin;
        //advin=get_ad;//用這得不到正確的get_ad返回值
       advin=0b1000101100;//用這驗證是OK的
        vin=(4.6*advin)/1023;
        adnum=vin*1000;
        adnum1=adnum/1000;
        adnum2=adnum%1000/100;
        display(adnum1,adnum2);
        delay();
void init()
    OSCCAL=0b00000000;//????
    TRISIO=0b00001111;//????
    OPTION_REG=0b10000000;//??????
    ADCON0=0b00001011;//
    ANSEL=0b00110100;//
    ADFM=0;
    delay();
    init();
        advalue();
作者: gravedigger    時間: 2019-3-21 09:19
有朋友看到了嗎
作者: zjjhtony    時間: 2019-3-21 13:33
uint get_ad()
    uint adval;//=0;
    adval=0b1000101100;
    return(adval);
這個AD采集肯定不行的。
正確的方法是:
1)寫入通道選擇CHS1:CHS0;
2)左右對齊選擇ADFM;
3)開啟AD(ADON=1);
4)延時50us;
5)設置GO/DONE位開啟AD檢測;
6)while(ADCON0bits.GO);判斷GO是否為0,即AD轉換結束。
7)讀取ADRESH:ADRESL,
8)AD結束。
作者: gravedigger    時間: 2019-3-23 09:20
zjjhtony 發表于 2019-3-21 13:33
uint get_ad()
    uint adval;//=0;
我知道不是這么寫 在測試現在是數據都不能返回過去
作者: gravedigger    時間: 2019-3-25 18:26
為什么這么少人看到,還沒解決這個問題啊
作者: zjjhtony    時間: 2019-3-25 20:44
  1. uint get_ad()
  2. {
  3.     uint adval;//=0;
  4.     GO=1;
  5.     while(GO);
  6.     adval=ADRESL;
  7.     adval |=((uint)ADRESH)<<8;
  8.     return(adval);
  9. }
  10. void advalue()
  11. {
  12.     uint adnum;
  13.     uint advin;
  14.     float vin;
  15.     while(1)
  16.     {
  17.         advin=get_ad();//用這得不到正確的get_ad返回值
  18.         //advin=0b1000101100;//用這驗證是OK的
  19.         vin=(4.6*advin)/1023;
  20.         adnum=(uint)(vin*1000);
  21.         adnum1=adnum/1000;
  22.         adnum2=adnum%1000/100;
  23.         display(adnum1,adnum2);
  24.         delay();
  25.     }
  26. }
  27. void init()
  28. {
  29.     OSCCAL=0b00000000;//????
  30.     TRISIO=0b00001111;//????
  31.     OPTION_REG=0b10000000;//??????
  32.     ADCON0=0b10001001;//
  33.     IOC=0;
  34.     ANSEL=0b00000100;//
  35.     delay();
  36. }
  37. void main()
  38. {
  39.     init();
  40.     led1=0;
  41.     while(1)
  42.     {
  43.         advalue();
  44.     }
  45. }
部分代碼如上,其他自己加上吧!程序修改了。
作者: gravedigger    時間: 2019-3-30 00:37
zjjhtony 發表于 2019-3-25 20:44
謝謝回復,你改的程序是可以的,昨天用MCV08重新寫了一遍也成功了,還在想是不是我的12F675有問題,今天拿你的對了一下,發現根本的問題是漏了一個()     advin=get_ad();就是這個括號 懺愧啊
