51單片機程序:出入庫管理系統的編輯
dongfangh2008
2019-3-12 08:19
51單片機程序:出入庫管理系統的編輯
#include <reg51.h>
#include <intrins.h>
#define DS1302_SECOND 0x80 //秒寄存器
#define DS1302_MINUTE 0x82 //分寄存器
#define DS1302_HOUR 0x84 //小時寄存器
#define DS1302_WEEK 0x8A //星期寄存器
#define DS1302_DAY 0x86 //日寄存器
#define DS1302_MONTH 0x88 //月寄存器
#define DS1302_YEAR 0x8C //年寄存器
#define right 1 //正確
#define error 0 //錯誤
typedef struct SYSTEMTIME
uchar Second;
uchar Minute;
uchar Hour;
uchar Week;
uchar Day;
uchar Month;
uchar Year;
uchar DateString[9];
uchar TimeString[9];
}SYSTEMTIME; //定義的時間類型
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
sbit DQ=P1^0; //DS1990A數據線引腳
sbit SDA=P1^1; //2402數據線引腳
sbit SCL=P1^2; //2402時鐘線引腳
sbit DS1302_RST=P1^3; //DS1302復位線引腳
sbit DS1302_CLK=P1^4; //DS1302時鐘線引腳
sbit DS1302_IO=P1^5; //DS1302數據線引腳
sbit din=P2^0; //MAX7221數據線引腳
sbit load=P2^1; //MAX7221控制線引腳
sbit clk=P2^2; //MAX7221時鐘線引腳
sbit Lock=P2^3; //電子鎖控制線引腳
uchar code CrcTable[256]={
0,94,188,226,97,63,221,131,194,156,126,32,163,253,31,65,
157,195,33,127,252,162,64,30,95,1,227,189,62,96,130,220,
35,125,159,193,66,28,254,160,225,191,93,3,128,222,60,98,
190,224,2,92,223,129,99,61,124,34,192,158,29,67,161,255,
70,24,250,164,39,121,155,197,132,218,56,102,229,187,89,7,
219,133,103,57,186,228,6,88,25,71,165,251,120,38,196,154,
101,59,217,135,4,90,184,230,167,249,27,69,198,152,122,36,
248,166,68,26,153,199,37,123,58,100,134,216,91,5,231,185,
140,210,48,110,237,179,81,15,78,16,242,172,47,113,147,205,
17,79,173,243,112,46,204,146,211,141,111,49,178,236,14,80,
175,241,19,77,206,144,114,44,109,51,209,143,12,82,176,238,
50,108,142,208,83,13,239,177,240,174,76,18,145,207,45,115,
202,148,118,40,171,245,23,73,8,86,180,234,105,55,213,139,
87,9,235,181,54,104,138,212,149,203,41,119,244,170,72,22,
233,183,85,11,136,214,52,106,43,117,151,201,74,20,246,168,
116,42,200,150,21,75,169,247,182,232,10,84,215,137,107,53
}; //校驗碼查詢表
uchar code ID[]={
0x01,0x2c,0xc5,0xb8,
0x00,0x00,0x00,0x8b}; //默認訪問者身份ID
uchar code dispcode[]={
0x7e,0x30,0x6d,0x79,
0x33,0x5b,0x5f,0x70,
0x7f,0x7b,0x77,0x1f,
0x4e,0x3d,0x4f,0x47}; //共陰極顯示代碼
bit flag=0;
uchar CRCbyte,num=200,da_ad=0x00; //CRC校驗碼,2402存儲地址
uchar SN[8],time[6];
uchar buf[]={0,0,0,0,0,0,0,0};
SYSTEMTIME time1;
/******************函數聲明*******************/
void Init_DS1302(void); //DS1302初始化
void Init_DS1990(void); //DS1990初始化
void Init_T0(void); //定時器T0初始化
void DS1302InputByte(uchar d); //DS1302
void Write_1302(uchar ucAddr, uchar ucDa);//DS1302寫數據
void DS1302_SetProtect(bit flag); //DS1302寫保護設定
void DS1302_SetTime(uchar Address, uchar Value);//DS1302設置時間函數
void DS1302_GetTime(SYSTEMTIME *Time);//DS1302時間轉換函數
void DS1302_time(void); //DS1302時間顯示函數
void Init_MAX7221(void); //MAX7221初始化
void Write_7221(uchar com,uchar da);//MAX7221寫字節程序
void Delay(uint i); //延時函數
void Writebyte(uchar dat); //向DS1990A寫一個字節函數
void Record(void); //記錄訪問時間
void Start_bit(void); //I2C起始函數
void Stop_bit(void); //I2C停止函數
bit Compare(void); //驗證身份函數
bit Read1990(void); //讀身份信息函數
bit Write_8bit(uchar ch); //I2C總線寫8位數據函數
uchar DS1302OutputByte(void); //DS1302讀一個字節
uchar Read1302(uchar ucAddr); //DS1302讀數據
uchar CRC(uchar j); //DS1990A校驗位計算函數
uchar Readbyte(void); //從DS1990A讀一個字節函數
uchar Page_wr(uchar firstw_ad,uchar counter,uchar *firstr_ad);//I2C總線頁面寫函數
/******************主函數*******************/
uchar i;
Init_MAX7221();
Init_DS1302();
Init_T0();
P2=0;
while (1)
if(Compare()==1) //身份驗證一致
Lock=1; //閉合繼電器
TR0=1; //定時器T0啟動
Record(); //記錄訪問時間
for(i=1;i<9;i++)
Write_7221(i,0x01);
if(da_ad==248)
da_ad=0; //判斷存儲內容是否已經滿
da_ad+=8; //修改2402存儲地址
while(Compare());
DS1302_time(); //顯示當前時間
/**************T0定時器初始化******************/
void Init_T0(void)
TMOD=0x01; //工作方式1
TH0=(65536-50000)/256; //定時時間為0.5ms
TL0=(65536-50000)%256;
EA=1; //開總中斷
ET0=1; //允許定時器T0中斷
/**************T0定時器服務程序******************/
void timer0(void) interrupt 1
TH0=(65536-50000)/256; //重載初值
num--;
if(num==0) //5秒定時到
TR0=0; //關定時器T0
num=200; //重載時間計數器
Lock=0; //斷開繼電器
/**************DS1302一個寫字節******************/
void DS1302InputByte(uchar d) //實時時鐘寫入一字節(內部函數)
uchar i;
ACC=d;
for (i=8;i>0;i--)
DS1302_IO=ACC0; //相當于匯編中的 RRC
DS1302_CLK=1;
DS1302_CLK=0; //發一個高跳變到低的脈沖
ACC=ACC>>1;
/**************DS1302讀一個字節******************/
uchar DS1302OutputByte(void) //實時時鐘讀取一字節(內部函數)
uchar i;
for (i=8;i>0;i--)
ACC=ACC>>1; //相當于匯編中的 RRC
ACC7=DS1302_IO;
DS1302_CLK=1;
return(ACC);
/****************DS1302寫數據********************/
DS1302_RST=0;
DS1302_CLK=0;
DS1302_RST=1;
DS1302InputByte(ucAddr); //地址,命令
DS1302InputByte(ucDa); //寫1Byte數據
DS1302_CLK=1;
DS1302_RST=0;
/****************DS1302讀數據********************/
uchar Read1302(uchar ucAddr) //讀取DS1302某地址的數據
uchar ucData;
DS1302_RST=0;
DS1302_CLK=0;
DS1302_RST=1; //enable
DS1302InputByte(ucAddr|0x01); //地址,命令
ucData=DS1302OutputByte(); //讀1Byte數據
DS1302_CLK=1;
DS1302_RST=0;
return(ucData);
/**************DS1302寫保護設定******************/
void DS1302_SetProtect(bit flag) //是否寫保護
if (flag)
Write_1302(0x8E,0x10); //WP=1,不能寫入
Write_1302(0x8E,0x00); //WP=0,可以寫入
/**************DS1302設置時間函數****************/
DS1302_SetProtect(0);
Write_1302(Address, ((Value/10)<<4|(Value%10)));//高4位為十位,低4位為個位
/*****************DS1302初始化******************/
uchar Second=Read1302(DS1302_SECOND);
if (Second&0x80) //如果第七為1(表明沒有啟動), 則啟動時鐘
DS1302_SetTime(DS1302_SECOND,0);
/**************DS1302時間轉換函數***************/
uchar ReadValue;
ReadValue=Read1302(DS1302_SECOND);
Time->Second=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F); //轉換秒
ReadValue=Read1302(DS1302_MINUTE);
Time->Minute=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F); //轉換分
ReadValue=Read1302(DS1302_HOUR);
Time->Hour=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F); //轉換時
ReadValue=Read1302(DS1302_DAY);
Time->Day=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F); //轉換日
ReadValue=Read1302(DS1302_WEEK);
Time->Week=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F); //轉換星期
ReadValue=Read1302(DS1302_MONTH);
Time->Month=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F); //轉換月
ReadValue=Read1302(DS1302_YEAR);
Time->Year=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F); //轉換年
/*****************MAX7221初始化***************/
Write_7221(0x0c,0x01); //正常工作狀態,關斷模式
Write_7221(0x09,0x00); //譯碼選擇,非BCD碼
Write_7221(0x0a,0x0f); //亮度調節
Write_7221(0x0b,0x07); //顯示位數
/**************MAX7221寫字節程序*************/
uchar temp,i,j;
load=0;
clk=0;
for (i=0;i<8;i++) //發送命令
temp=com;
if ((temp&(0x80>>i))!=0)
din=1;
else din=0;
clk=1;
for (j=0;j<5;j++);
clk=0;
for (i=0;i<8;i++) //發送數據
temp=da;
din=1;
else din=0;
clk=1;
for (j=0;j<5;j++);
clk=0;
load=1;
/**************時間顯示函數*******************/
DS1302_GetTime(&time1); //獲取當前時間
buf[7]=(time1.Second)%10;
buf[6]=(time1.Second)/10;
buf[4]=(time1.Minute)%10;
buf[3]=(time1.Minute)/10;
buf[1]=(time1.Hour)%10;
buf[0]=(time1.Hour)/10;
Write_7221(0x08,dispcode[buf[7]]);
Write_7221(0x07,dispcode[buf[6]]);
Write_7221(0x06,0x01);
Write_7221(0x05,dispcode[buf[4]]);
Write_7221(0x04,dispcode[buf[3]]);
Write_7221(0x03,0x01);
Write_7221(0x02,dispcode[buf[1]]);
Write_7221(0x01,dispcode[buf[0]]);
/**************I2C起始函數*******************/
SCL=1;_nop_();
SDA=1;_nop_();
SDA=0;_nop_();
SCL=0;_nop_();
/***************I2C停止函數******************/
void Stop_bit(void)
SDA=0;_nop_();
SCL=1;_nop_();
SDA=1;_nop_();
/***********I2C總線寫8位數據函數*************/
uchar i=8;
bit fan_w;
SCL=0;_nop_();
while (i--)
SDA=(bit)(ch&0x80);_nop_();
ch<<=1;
SCL=1;_nop_();
SCL=0;_nop_();
SDA=1;_nop_();
SCL=1;_nop_();
fan_w=SDA;
SCL=0;_nop_();
return(fan_w);
/************I2C總線頁面寫函數**************/
uchar *ufirstr_ad;
ufirstr_ad=firstr_ad;
Start_bit(); //啟動I2C
if (Write_8bit(0xA0)!=0) //發送2402器件地址
Stop_bit(); //無應答,返回
return(0);
if (Write_8bit(firstw_ad)!=0) //寫入數據的存儲地址
return(0);
while (counter--) //寫入數據
if (Write_8bit(*ufirstr_ad)!=0) //無應答,返回
Stop_bit();
return(0);
ufirstr_ad++; //準備下一數據
Stop_bit();
return(1); //寫數據成功
/*****************延時函數******************/
void Delay(uint i)
while (i--);
/***********DS1990A校驗位計算函數***********/
uchar CRC(uchar j)
uchar i,crc_data=0;
for (i=0;i<j;i++) //查表校驗
crc_data=CrcTable[crc_data^SN[i]];
return(crc_data);
/*************DS1990A初始化函數*************/
uchar i,x=0;
DQ=0; //置低
Delay(60); //延時480us
DQ=1; //釋放
Delay(10); //延時85us
for (i=0;i<10;i++)
if (DQ==0) //如果拉低
flag=1;
break;
Delay(20);
/***********從DS1990A讀一個字節函數*********/
uchar i=0;
uchar temp=0;
for (i=0;i<8;i++)
DQ=0;
temp>>=1;
DQ=1;
_nop_();
if (DQ)temp|=0x80;
Delay(8);
return(temp);
/**********向DS1990A寫一個字節函數**********/
uchar i=0,send;
for (i=0;i<8;i++)
DQ=0;
send=dat&0x01;
if (send==0x01)
DQ=1;
Delay(15);
Delay(15);
DQ=1;
dat>>=1;
Delay(8);
/*************讀身份信息函數****************/
bit Read1990(void)
uchar i;
Init_DS1990();
if (flag==1)
while (DQ==0);
flag=0;
Writebyte(0x33);
for (i=0;i<8;i++)
SN[i]=Readbyte();
CRCbyte=CRC(7);
if (CRCbyte==SN[7])
return(right);
return(error);
return(error);
/****************驗證身份函數***************/
bit Compare(void)
uchar i;
if (Read1990()==1) //若身份驗證正確返回1,錯誤返回0
for (i=0;i<8;i++)
if (SN[i]!=ID[i])return(error);
return(right);
return(error);
/****************記錄訪問時間***************/
void Record(void)
DS1302_GetTime(&time1); //獲取訪問時間
time[0]=time1.Second; //將訪問時間信息存入緩沖區
time[1]=time1.Minute;
time[2]=time1.Hour;
time[3]=time1.Day;
time[4]=time1.Month;
time[5]=time1.Year;
while(Page_wr(da_ad,6,time)==0); //等待寫入成功
出入管理系統.zip
(62.01 KB, 下載次數: 8)
2019-3-12 08:19 上傳
admin
2019-3-12 14:49
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
