單片機時鐘和電壓表
13655
2019-2-1 15:20
單片機時鐘和電壓表
#include <reg52.h>
#include "XPT2046.h"
uchar a;
sbit lcden=P2^7; //LDC1602讀寫使能
sbit rs=P2^6; //LCD1602寄存器
sbit rw=P2^5; //LCD1602讀寫
sbit s1=P3^0; //時鐘暫停
sbit s2=P3^1; //時間減
sbit s3=P3^3; //時間加
sbit k3=P3^2; //中斷開關,按下后跳到電壓表
sbit LSA=P2^2; //三八譯碼器A口
sbit LSB=P2^3; //三八譯碼器B口
sbit LSC=P2^4; //三八譯碼器C口
int disp[4];
int code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //數碼管0到9
int code xiaoshu[10]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
uchar count,s1num;
char miao,shi,fen;
uchar code table[]=" 2019-1-11 TIME ";
uchar code table1[]=" 00:00:00";
uchar code table2[]="student id:1840740128";
void delay(uint z) //延時
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
rs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
uchar num;
lcden=0;
rw=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<15;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
write_date(table1[num]);
delay(5);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void keyscan()
if(s1==0)
delay(5);
if(s1==0)
{ s1num++;
while(!s1);
if(s1num==1)
TR0=0;
write_com(0x80+0x40+10);
write_com(0x0f);
if(s1num==2)
write_com(0x80+0x40+7);
if(s1num==3)
write_com(0x80+0x40+4);
if(s1num==4)
s1num=0;
write_com(0x0c);
TR0=1;
if(s1num!=0)
if(s2==0)
delay(5);
if(s2==0)
while(!s2);
if(s1num==1)
miao++;
if(miao==60)
miao=0;
write_sfm(10,miao);
if(s1num==2)
fen++;
if(fen==60)
fen=0;
write_sfm(7,fen);
if(s1num==3)
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
if(s3==0)
delay(5);
if(s3==0)
while(!s3);
if(s1num==1)
miao--;
if(miao==-1)
miao=59;
write_sfm(10,miao);
if(s1num==2)
fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
if(s1num==3)
shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
void timer0() interrupt 1 //定時器中斷
count++;
if(count==18)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
write_sfm(7,fen);
write_sfm(10,miao);
void datapros()
int temp;
static int i;
if(i==50)
i=0;
temp = Read_AD_Data(0xE4); // AIN3 外部輸入
i++;
disp[3]=xiaoshu[temp/1000];//千位
disp[2]=smgduan[temp%1000/100];//百位
disp[1]=smgduan[temp%1000%100/10];//個位
disp[0]=smgduan[temp%1000%100%10];
//數碼管顯示函數
void DigDisplay()
int i;
for(i=0;i<4;i++)
switch(i) //位選,選擇點亮的數碼管,
case(0):
LSA=0;LSB=0;LSC=0; break;//顯示第0位
case(1):
LSA=1;LSB=0;LSC=0; break;//顯示第1位
case(2):
LSA=0;LSB=1;LSC=0; break;//顯示第2位
case(3):
LSA=1;LSB=1;LSC=0; break;//顯示第3位
P0=disp[i];//發送數據
delay(1); //間隔一段時間掃描
P0=0x00;//消隱
void dianyabiao()
datapros(); //數據處理函數
DigDisplay();//數碼管顯示函數
void shumaguan()
a=0;
IT0=0; //中斷觸發方式為低電平觸發,IT0=1則為下邊沿觸發
EX0=1; //打開外部中斷0
EA=1; //打開中斷總開關
init();
switch(a%2)
case 1:dianyabiao();break;
case 0:keyscan();break;
void INTERR(void) interrupt 0
if(k3==0)
delay(100);
if(k3==1)
break;
a++;
delay(300);
改AD.zip
2019-2-1 15:19 上傳
52.78 KB, 下載次數: 2, 下載積分: 黑幣 -5
admin
2019-2-2 02:35
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
jifengjianwu
2019-2-2 07:57
謝謝樓主,學習了。
