STM32F429 uCOSIII_emWin528_Demo(光敏電阻)例程
yhdsxq
2019-1-20 01:36
/* --------------- APPLICATION GLOBALS ---------------- */
static OS_TCB AppTaskStartTCB;
static CPU_STK AppTaskStartStk[APP_CFG_TASK_START_STK_SIZE];
static OS_TCB AppTaskObj0TCB;
static CPU_STK AppTaskObj0Stk[APP_CFG_TASK_OBJ0_STK_SIZE];
static OS_TCB AppTaskGUITCB;
__align(8) static CPU_STK AppTaskGUIStk[APP_CFG_TASK_GUI_STK_SIZE];
* FUNCTION PROTOTYPES
static void AppTaskStart (void *p_arg);
static void AppTaskCreate (void);
static void AppObjCreate (void);
static void AppTaskObj0 (void *p_arg);
static void AppTaskGUI (void *p_arg);
KEY Key1,Key2;
uint8_t tpad_flag=0;
* main()
* Description : This is the standard entry point for C code. It is assumed that your code will call
* main() once you have performed all necessary initialization.
* Arguments : none
* Returns : none
int main(void)
OS_ERR err;
#if (CPU_CFG_NAME_EN == DEF_ENABLED)
CPU_ERR cpu_err;
#endif
Mem_Init(); /* Initialize Memory Managment Module */
Math_Init(); /* Initialize Mathematical Module */
CPU_NameSet((CPU_CHAR *)"STM32F429II",
(CPU_ERR *)&cpu_err);
#endif
BSP_IntDisAll(); /* Disable all Interrupts. */
OSInit(&err); /* Init uC/OS-III. */
App_OS_SetAllHooks();
OSTaskCreate(&AppTaskStartTCB, /* Create the start task */
"App Task Start",
AppTaskStart,
0u,
APP_CFG_TASK_START_PRIO,
&AppTaskStartStk[0u],
AppTaskStartStk[APP_CFG_TASK_START_STK_SIZE / 10u],
APP_CFG_TASK_START_STK_SIZE,
0u,
0u,
0u,
(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
&err);
if(err!=OS_ERR_NONE) bsp_result|=BSP_OS;
OSStart(&err); /* Start multitasking (i.e. give control to uC/OS-III). */
while (DEF_ON) { /* Should Never Get Here. */
//按鍵定時掃描的定時器
static void inputscan(void)
OS_ERR err;
OSSchedLock(&err);
GT9xx_GetOnePiont();//觸摸屏定時掃描
OSSchedUnlock(&err);
Key_RefreshState(&Key1);//刷新按鍵狀態
Key_RefreshState(&Key2);//刷新按鍵狀態
if(Key_AccessTimes(&Key1,KEY_ACCESS_READ)!=0)//按鍵被按下過
LED2_TOGGLE;
Key_AccessTimes(&Key1,KEY_ACCESS_WRITE_CLEAR);
if(Key_AccessTimes(&Key2,KEY_ACCESS_READ)!=0)//按鍵被按下過
LED3_TOGGLE;
Key_AccessTimes(&Key2,KEY_ACCESS_WRITE_CLEAR);
* STARTUP TASK
* Description : This is an example of a startup task. As mentioned in the book's text, you MUST
* initialize the ticker only once multitasking has started.
* Arguments : p_arg is the argument passed to 'AppTaskStart()' by 'OSTaskCreate()'.
* Returns : none
* Notes : 1) The first line of code is used to prevent a compiler warning because 'p_arg' is not
* used. The compiler should not generate any code for this statement.
OS_ERR err;
(void)p_arg;
BSP_Init(); /* Initialize BSP functions */
CPU_Init(); /* Initialize the uC/CPU services */
#if OS_CFG_STAT_TASK_EN > 0u
OSStatTaskCPUUsageInit(&err); /* Compute CPU capacity with no task running */
#endif
#ifdef CPU_CFG_INT_DIS_MEAS_EN
CPU_IntDisMeasMaxCurReset();
#endif
#if (APP_CFG_SERIAL_EN == DEF_ENABLED)
APP_TRACE_DBG(("Creating Application kernel objects\n\r"));
#endif
AppObjCreate();
/* Create Applicaiton kernel objects */
APP_TRACE_DBG(("Creating Application Tasks\n\r"));
#endif
AppTaskCreate(); /* Create Application tasks */
while (DEF_TRUE)
{ /* Task body, always written as an infinite loop. */
inputscan();
OSTimeDlyHMSM(0u, 0u, 0u, 20u,
OS_OPT_TIME_HMSM_STRICT,
&err);
* AppTaskCreate()
* Description : Create Application Tasks.
* Argument(s) : none
* Return(s) : none
* Caller(s) : AppTaskStart()
* Note(s) : none.
OS_ERR os_err;
/* ---------- CREATE KERNEL OBJECTS TEST TASK --------- */
OSTaskCreate((OS_TCB *)&AppTaskObj0TCB,
(CPU_CHAR *)"Kernel Objects Task 0",
(OS_TASK_PTR )AppTaskObj0,
(void *)0,
(OS_PRIO )APP_CFG_TASK_OBJ0_PRIO,
(CPU_STK *)&AppTaskObj0Stk[0],
(CPU_STK_SIZE )AppTaskObj0Stk[APP_CFG_TASK_OBJ0_STK_SIZE / 10u],
(CPU_STK_SIZE )APP_CFG_TASK_OBJ0_STK_SIZE,
(OS_MSG_QTY )0u,
(OS_TICK )0u,
(void *)0,
(OS_OPT )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
(OS_ERR *)&os_err);
OSTaskCreate((OS_TCB *)&AppTaskGUITCB,
(OS_TASK_PTR )AppTaskGUI,
(void *)0,
(OS_PRIO )APP_CFG_TASK_GUI_PRIO,
(CPU_STK *)&AppTaskGUIStk[0],
(CPU_STK_SIZE )AppTaskGUIStk[APP_CFG_TASK_GUI_STK_SIZE / 10u],
(CPU_STK_SIZE )APP_CFG_TASK_GUI_STK_SIZE,
(OS_MSG_QTY )0u,
(OS_TICK )0u,
(void *)0,
(OS_ERR *)&os_err);
* AppObjCreate()
* Description : Create Application Kernel Objects.
* Return(s) : none
* Note(s) : none.
KeyCreate(&Key1,GetPinStateOfKey1);
KeyCreate(&Key2,GetPinStateOfKey2);
* AppTaskObj0()
* Description : Test uC/OS-III objects.
* Argument(s) : p_arg is the argument passed to 'AppTaskObj0' by 'OSTaskCreate()'.
* Return(s) : none
* Caller(s) : This is a task
* Note(s) : none.
OS_ERR err;
static uint8_t tpad_count=0;
(void)p_arg;
while(TPAD_Init())
tpad_count++;
if(tpad_count>=10)
bsp_result |= BSP_TPAD;
break;
bsp_DelayUS(1000);
if((tpad_count<10)&&TPAD_Scan(0))
BEEP_ON;
if(UserApp_Flag)tpad_flag=1;
OSTimeDlyHMSM(0, 0, 0, 100,
&err);
BEEP_OFF;
/************** 板載錯誤 ***************/
void hardwareerr(void)
OS_ERR err;
printf("bsp_result->(0x%04X)\n",bsp_result);
if((bsp_result&(~BSP_NETWORK))==0) return;
if(!((bsp_result&BSP_SDRAM)||(bsp_result&BSP_GUI)))
char tempstr[20];
sprintf(tempstr,"error->(0x%04X)",bsp_result);
GUI_Clear();
GUI_SetColor(GUI_RED);
GUI_SetFont(GUI_FONT_24_ASCII);
GUI_DispStringHCenterAt(tempstr, 400,120);
LCD_BL_ON();
LED1_ON;//BEEP_ON;
OSTimeDlyHMSM(0,0,0,500,OS_OPT_TIME_HMSM_STRICT,&err);
LED1_OFF;//BEEP_OFF;
OSTimeDlyHMSM(0,0,0,100,OS_OPT_TIME_HMSM_STRICT,&err);
* AppTaskObj1()
* Argument(s) : p_arg is the argument passed to 'AppTaskObj1' by 'OSTaskCreate()'.
* Return(s) : none
* Note(s) : none.
(void)p_arg;
if(bsp_result!=BSP_OK)
hardwareerr();
emWinMainApp();
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
33. uCOSIII_emWin528_Demo(光敏電阻).7z
(3.09 MB, 下載次數: 39)
2019-1-21 02:38 上傳
