標(biāo)題: w5500 dhcp優(yōu)化版+udp nrf52832程序源碼 M4內(nèi)核芯片 [打印本頁(yè)]
作者: f78fk    時(shí)間: 2019-1-8 11:09
用官網(wǎng)W5500庫(kù)版本的DHCP例子 申請(qǐng)10次會(huì)有5次 獲取不到IP 卡在了discover步驟,
經(jīng)過(guò)優(yōu)化,現(xiàn)在自測(cè)了50多遍,100%可以申請(qǐng)到IP。
主控用的nrf52832 cortex m4內(nèi)核 硬件spi
SDK為nRF_SDK_15.2.0
把解壓后的目錄放nRF_SDK_15.2.0\examples\ble_central下編譯就可以成功。
代碼預(yù)覽
  1. #include "ethernet.h"
  2. #include "dhcp.h"
  3. /* Private typedef -----------------------------------------------------------*/
  4. /* Private define ------------------------------------------------------------*/
  5. #define SOCK_TCPS        0
  6. /* Private macro -------------------------------------------------------------*/
  7. uint8_t gSEND_BUFF[SEND_BUFF_SIZE];
  8. // Default Network Configuration
  9. wiz_NetInfo gWIZNETINFO = { .mac = {0x00, 0x02, 0x04,0x06, 0x08, 0x10},
  10.                             .ip = {192,168,1,2 },
  11.                             .sn = {255,255,2555,0},
  12.                             .gw = {0, 0, 0, 0},
  13.                             .dns = {1,2,4,8},
  14.                             .dhcp =  NETINFO_DHCP };
  15. void network_init(void);
  16.
  17. void set_macaddr(void)
  18. {
  19.     gWIZNETINFO.mac[0] = (uint8_t )(NRF_FICR->DEVICEADDR[0]);
  20.     gWIZNETINFO.mac[1] = (uint8_t )(NRF_FICR->DEVICEADDR[0]>>8);
  21.     gWIZNETINFO.mac[2] = (uint8_t )(NRF_FICR->DEVICEADDR[0]>>16);
  22.     gWIZNETINFO.mac[3] = (uint8_t )(NRF_FICR->DEVICEADDR[0]>>24);
  23.     gWIZNETINFO.mac[4] = (uint8_t )(NRF_FICR->DEVICEADDR[1]);
  24.     gWIZNETINFO.mac[5] = (uint8_t )(NRF_FICR->DEVICEADDR[1]>>8);
  25. }
  26. uint8_t DHCP_message[128];
  27. void ethernet_init(void)
  28. {
  29.     uint8_t tmp;
  30.
  31.         uint8_t memsize[2][8] = {{2,2,2,2,2,2,2,2},{2,2,2,2,2,2,2,2}};
  32.
  33.
  34.     SPI_Configuration();
  35.
  36.     memset((char *)gSEND_BUFF,0,SEND_BUFF_SIZE);
  37.
  38.     reg_wizchip_cris_cbfunc(SPI_CrisEnter, SPI_CrisExit);        //注冊(cè)臨界區(qū)函數(shù)
  39.         /* Chip selection call back */
  40. #if   _WIZCHIP_IO_MODE_ == _WIZCHIP_IO_MODE_SPI_VDM_
  41.         reg_wizchip_cs_cbfunc(SPI_CS_Select, SPI_CS_Deselect);//注冊(cè)SPI片選信號(hào)函數(shù)
  42. #elif _WIZCHIP_IO_MODE_ == _WIZCHIP_IO_MODE_SPI_FDM_
  43.         reg_wizchip_cs_cbfunc(SPI_CS_Select, SPI_CS_Deselect);  // CS must be tried with LOW.
  44. #else
  45.    #if (_WIZCHIP_IO_MODE_ & _WIZCHIP_IO_MODE_SIP_) != _WIZCHIP_IO_MODE_SIP_
  46.       #error "Unknown _WIZCHIP_IO_MODE_"
  47.    #else
  48.       reg_wizchip_cs_cbfunc(wizchip_select, wizchip_deselect);
  49.    #endif
  50. #endif
  51.         /* SPI Read & Write callback function */
  52.         reg_wizchip_spi_cbfunc(SPI_ReadByte, SPI_WriteByte);        //注冊(cè)讀寫(xiě)函數(shù)
  53.         /* WIZCHIP SOCKET Buffer initialize */
  54.         if(ctlwizchip(CW_INIT_WIZCHIP,(void*)memsize) == -1){
  55.
  56.                  while(1)
  57.          {
  58.              NRF_LOG_DEBUG("WIZCHIP Initialized fail.\r\n");
  59.              nrf_delay_ms(500);
  60.          }
  61.         }
  62.     NRF_LOG_DEBUG("WIZCHIP Initialized Successful.\r\n");
  63.         /* PHY link status check */
  64.         do{
  65.                  if(ctlwizchip(CW_GET_PHYLINK, (void*)&tmp) == -1)
  66.          {
  67.                                 NRF_LOG_DEBUG("Unknown PHY Link stauts.\r\n");
  68.
  69.                  }
  70.
  71.         }while(tmp == PHY_LINK_OFF);
  72.     NRF_LOG_DEBUG("phy running.\n");
  73.
  74.     set_macaddr();
  75.
  76.     memset(DHCP_message,0,128);
  77.     DHCP_init(0,DHCP_message);
  78.
  79.         /* Network initialization */
  80.         network_init();
  81.
  82.
  83. }
  84. void show_netinfo(void);
  85. void ethernet_handle(void)
  86. {
  87.      uint8_t dhcp_res;
  88.      dhcp_res = DHCP_run();
  89.      if(dhcp_res != DHCP_IP_LEASED)
  90.      {
  91.          NRF_LOG_INFO("DHCP_run... 返回值:%d\n",dhcp_res);
  92.          nrf_delay_ms(1000);
  93.          return;
  94.      }
  95.
  96.      static uint8_t temp = 0;
  97.      if(temp == 0)
  98.      {
  99.         NRF_LOG_INFO("DHCP成功申請(qǐng)到IP地址\n");
  100.         show_netinfo();
  101.         temp = 1;
  102.      }
  103.      switch(getSn_SR(0))
  104.      {
  105.         case SOCK_UDP:
  106.
  107.                 if(getSn_IR(0) & Sn_IR_RECV)
  108.                 {
  109.                     setSn_IR(0, Sn_IR_RECV);
  110.                 }
  111. #if 0
  112.                 if((ret=getSn_RX_RSR(0))>0)
  113.                 {
  114.                     memset(gDATABUF,0,ret+1);
  115.                     recvfrom(0,gDATABUF, ret, DstIP,&DstPort);
  116.                     NRF_LOG_DEBUG("%s\r\n",gDATABUF);
  117.                     sendto(0,gDATABUF,ret, DstIP, DstPort);
  118.                 }
  119. #endif
  120.         break;
  121.         case SOCK_CLOSED:        // Socket處于關(guān)閉狀態(tài)
  122.                 socket(0,Sn_MR_UDP,UDP_LOCAL_PORT,0x00);        // 打開(kāi)Socket0,并配置為UDP模式,打開(kāi)一個(gè)本地端口
  123.         break;
  124.     }
  125.
  126. }
  127. void show_netinfo(void)
  128. {
  129.     uint8_t tmpstr[6];
  130.         ctlnetwork(CN_GET_NETINFO, (void*)&gWIZNETINFO);
  131.         // Display Network Information
  132.         ctlwizchip(CW_GET_ID,(void*)tmpstr);
  133.         NRF_LOG_INFO("=== %s NET CONF ===\r\n",(char*)tmpstr);
  134.         NRF_LOG_INFO("MAC: %02X:%02X:%02X:%02X:%02X:%02X\r\n",gWIZNETINFO.mac[0],gWIZNETINFO.mac[1],gWIZNETINFO.mac[2],
  135.     gWIZNETINFO.mac[3],gWIZNETINFO.mac[4],gWIZNETINFO.mac[5]);
  136.         NRF_LOG_INFO("SIP: %d.%d.%d.%d\r\n", gWIZNETINFO.ip[0],gWIZNETINFO.ip[1],gWIZNETINFO.ip[2],gWIZNETINFO.ip[3]);
  137.         NRF_LOG_INFO("GAR: %d.%d.%d.%d\r\n", gWIZNETINFO.gw[0],gWIZNETINFO.gw[1],gWIZNETINFO.gw[2],gWIZNETINFO.gw[3]);
  138.         NRF_LOG_INFO("SUB: %d.%d.%d.%d\r\n", gWIZNETINFO.sn[0],gWIZNETINFO.sn[1],gWIZNETINFO.sn[2],gWIZNETINFO.sn[3]);
  139.         NRF_LOG_INFO("DNS: %d.%d.%d.%d\r\n", gWIZNETINFO.dns[0],gWIZNETINFO.dns[1],gWIZNETINFO.dns[2],gWIZNETINFO.dns[3]);
  140.         NRF_LOG_INFO("======================\r\n");
  141. }
  142. void network_init(void)
  143. {
  144.         ctlnetwork(CN_SET_NETINFO, (void*)&gWIZNETINFO);
  145. }
SDK為nRF_SDK_15.2.0
iar的工程(沒(méi)裝iar的鞋童就不要下載了):
w5500_dhcp_udp.7z (342.93 KB, 下載次數(shù): 82)
作者: nickhan110    時(shí)間: 2019-9-5 14:16
不錯(cuò),很實(shí)用。謝謝
很好的資料。
作者: onono    時(shí)間: 2021-3-5 11:05
正在學(xué)習(xí)nRF52832,謝謝分享。
作者: sz_tony    時(shí)間: 2021-12-15 11:42
樓主 不能編譯呀
