dsPIC3EP256MC506的AN1160用擇多函數(shù)實(shí)現(xiàn)飯電動(dòng)勢(shì)濾波的無(wú)傳感器BLDC控制
[打印本頁(yè)]
ylm110
時(shí)間:
2018-12-29 15:24
本應(yīng)用筆記介紹一種采用 dsPIC ® 數(shù)字信號(hào)控制器
(Digital Signal Controller, DSC)或 PIC24 單片機(jī)來(lái)實(shí)現(xiàn)無(wú)刷直流 (Brushless Direct Current, BLDC)電機(jī)無(wú)傳感器控制的算法。該算法利用對(duì)反電動(dòng)勢(shì)(Back-Electromotive Force,BEMF)進(jìn)行數(shù)字濾波的擇多函數(shù)來(lái)實(shí)現(xiàn)。通過(guò)對(duì)電機(jī)的每一相進(jìn)行濾波來(lái)確定電機(jī)驅(qū)動(dòng)電壓換相的時(shí)刻。這一控制技術(shù)省卻了分立的低通濾波硬件和片外比較器。需指出,這里論述的所有內(nèi)容及應(yīng)用軟件,都是假定使用三相電機(jī)。該電機(jī)控制算法包括四個(gè)主要部分:
• 利用 DSC 或單片機(jī)的模數(shù)轉(zhuǎn)換器(Analog-to-Digital Converter,ADC)來(lái)采樣梯形波 BEMF 信號(hào)
• PWM 導(dǎo)通側(cè) ADC 采樣,以降低噪聲并解決低電感問(wèn)題
• 將梯形波BEMF信號(hào)與V BUS /2進(jìn)行比較,以檢測(cè)過(guò)零點(diǎn)
• 用擇多函數(shù)濾波器對(duì)比較結(jié)果信號(hào)進(jìn)行濾波
• 以三種不同模式對(duì)電機(jī)驅(qū)動(dòng)電壓進(jìn)行換相:
- 傳統(tǒng)開環(huán)控制器
- 傳統(tǒng)閉環(huán)控制器
- 比例 - 積分(Proportional-Integral,PI)閉環(huán)
控制器
(12.44 KB, 下載次數(shù): 80)
2018-12-29 16:33 上傳
單片機(jī)源程序如下:
* ?2011 Microchip Technology Inc.
* MICROCHIP SOFTWARE NOTICE AND DISCLAIMER:
* You may use this software, and any derivatives
* created by any person or entity by or on your behalf, exclusively with Microchip抯 products.
* Microchip and its licensors retain all ownership and intellectual property rights in the
* accompanying software and in all derivatives hereto.
* This software and any accompanying information is for suggestion only.
* It does not modify Microchip抯 standard warranty for its products. You agree that you are
* solely responsible for testing the software and determining its suitability.
* Microchip has no obligation to modify, test, certify, or support the software.
* THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY,
* INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS FOR
* A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE, ITS INTERACTION WITH MICROCHIP扴 PRODUCTS, COMBINATION WITH
* ANY OTHER PRODUCTS, OR USE IN ANY APPLICATION.
* IN NO EVENT, WILL MICROCHIP BE LIABLE, WHETHER IN CONTRACT, WARRANTY, TORT (INCLUDING NEGLIGENCE OR BREACH
* OF STATUTORY DUTY), STRICT LIABILITY, INDEMNITY, CONTRIBUTION, OR OTHERWISE, FOR ANY INDIRECT, SPECIAL, PUNITIVE,
* EXEMPLARY, INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, FOR COST OR EXPENSE OF ANY KIND WHATSOEVER RELATED TO THE SOFTWARE,
* HOWSOEVER CAUSED, EVEN IF MICROCHIP HAS BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE. TO THE FULLEST
* EXTENT ALLOWABLE BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL CLAIMS IN ANY WAY RELATED TO THIS SOFTWARE WILL NOT EXCEED
* THE AMOUNT OF FEES, IF ANY, THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS SOFTWARE.
* MICROCHIP PROVIDES THIS SOFTWARE CONDITIONALLY UPON YOUR ACCEPTANCE OF THESE TERMS.
#include "defs.h" //defines, function headers, pi, etc
#ifdef RTDM_DEMO
#include "debug.h" //RTDM/DMCI functionality
#endif
int main(void)
Init_Ports(); // Clock ( Fcy 70MHz ) , port configuration, etc
#ifdef RTDM_DEMO
DBG_Init(); // RTDM ( Debugger ) Initialization
#endif
//defaults: CLKW rotation, motor stopped
Flags.RunMotor = 0;
Flags.Startup = 0;
Flags.CLKW = 1;
Flags.newCLKW = 1;
Flags.DMCI_Control_SW = 0; //default potentiometer read
Timer2Average = TMR2_MAX;
trigger_count = 1;
Flags.nb_delay_on = 0;
#ifdef OPEN_LOOP_CONTROL
DesiredDuty = MIN_DUTY_CYCLE;
#else
DesiredRPM = STARTUP_RPM;
#endif
Flags.current_state = STATE_STOPPED;
while(1) {
if(S2) { //CLKW/CCLKW switch
while(S2) //debounce
Delay_100uSec(DEBOUNCE_DELAY*10);
Flags.newCLKW = !Flags.CLKW;
if(S3) { //start/stop switch
while(S3) //debounce
if(Flags.current_state == STATE_STOPPED)
Flags.current_state = STATE_STARTING;
Flags.current_state = STATE_STOPPING;
switch(Flags.current_state) {
case STATE_STOPPING:
Stop_Motor();
break;
case STATE_STARTING:
//startup done on MCPWM ISR
break;
case STATE_FAULT:
Stop_Motor();
break;
case STATE_STARTED:
if(Flags.newCLKW != Flags.CLKW) {
Stop_Motor();
Flags.CLKW = Flags.newCLKW;
Delay_100uSec(5000); //delay 500 ms for motor to actually stop
break;
case STATE_STOPPED:
break;
#ifdef RTDM_DEMO
DBG_SyncComm(); //assure RTDM communication
#endif
return 0;
Init_Motor()
Procedure used to initialize all params for the motor and
for the AN1160 algorithm.
Also rotor alignment is done here.
void Init_Motor()
int i; //auxiliary counter
if(Flags.nb_delay_on == 0) {
T1CONbits.TON = 0;
T2CONbits.TON = 0;
TMR1 = 0;
TMR2 = 0;
Flags.TrainPI = 0;
//setting direction CLKW or CCLKW
if(Flags.CLKW == 1) {
for(i=0;i<6;i++) {
PWM_STATE1[i] = PWM_STATE1_CLKW[i];
PWM_STATE2[i] = PWM_STATE2_CLKW[i];
PWM_STATE3[i] = PWM_STATE3_CLKW[i];
MotorPhaseAState[i] = MotorPhaseAState_CLKW[i];
MotorPhaseBState[i] = MotorPhaseBState_CLKW[i];
MotorPhaseCState[i] = MotorPhaseCState_CLKW[i];
ADC_CHANNEL[i] = ADC_CHANNEL_CLKW[i];
ADC_MASK[i] = ADC_MASK_CLKW[i];
ADC_XOR[i] = ADC_XOR_CLKW[5-i];
for(i=0;i<64;i++)
ADC_BEMF_FILTER[i] = ADC_BEMF_FILTER_CLKW[63-i];
} else {
for(i=0;i<6;i++) {
PWM_STATE1[i] = PWM_STATE1_CLKW[5-i];
PWM_STATE2[i] = PWM_STATE2_CLKW[5-i];
PWM_STATE3[i] = PWM_STATE3_CLKW[5-i];
MotorPhaseAState[i] = MotorPhaseAState_CLKW[5-i];
MotorPhaseBState[i] = MotorPhaseBState_CLKW[5-i];
MotorPhaseCState[i] = MotorPhaseCState_CLKW[5-i];
ADC_CHANNEL[i] = ADC_CHANNEL_CLKW[5-i];
ADC_MASK[i] = ADC_MASK_CLKW[5-i];
for(i=0;i<64;i++)
stallCount = 0;
PIDStructure.qInMeas = STARTUP_RPM;
PIDStructure.qInRef = STARTUP_RPM;
InitPI(&PIDStructure,SpeedControl_P,SpeedControl_I,PI_ANTI_WINDUP,MAX_DUTY_CYCLE,MIN_DUTY_CYCLE,0);
TMR2 = TMR2_MAX; //initialize TMR2 and TMR2 average with the value corresponding to the minimum motor speed
Timer2Value = TMR2;
Timer2Average = TMR2;
Timer1Value = 0;
Flags.RunMotor = 1; // turn the motor ON
Flags.Startup = 1; // motor initialized, go to starting sequence
ADCCommState = 5; //always start with sector 6 forced
//set pwm overdrive to the according PWM channel
IOCON1 = PWM_STATE1[ADCCommState];
IOCON2 = PWM_STATE2[ADCCommState];
IOCON3 = PWM_STATE3[ADCCommState];
CurrentDuty = STARTUP_DUTY; //Init PWM duty cycle value to minimum duty allowed
PDC1 = CurrentDuty;
PDC2 = CurrentDuty;
PDC3 = CurrentDuty;
nb_delay = ROTOR_ALIGN_T*PWM_100us_FACTOR*10;
delay_counter = 0;
Flags.nb_delay_on = 1;
t_current = STARTUP_START_T*10; //in ms
t_sector = 0;
Start_Motor()
Procedure for starting the motor according to the implemented
startup ramp. After the ramp, PI loop training will begin.
void Start_Motor()
if(Flags.nb_delay_on == 0) { //this is just to test if we're not in a non-blocking delay actually
if(++ADCCommState>5) // Change The Six-Step Commutation Sector
ADCCommState = 0;
AD1CHS0 = ADC_CHANNEL[ADCCommState]; //Change ADC Channel AN Selection
if(t_current < (unsigned long int)STARTUP_T_RAMP*10) {
t_sector = STARTUP_SEC_C/t_current; //calculates T for 1 sector, in 100s of uS.
if(t_sector <= 0) t_sector = 1;
} else
if (t_current < ((unsigned int)STARTUP_T_RAMP*10 + STARTUP_T_SUST*10)) {
Flags.TrainPI = 1;
AD1CON1bits.SSRC = 3;
Flags.TrainPI = 0;
//overdrive and output next motor sector
//here we want a non-blocking delay for the startup to execute
nb_delay = t_sector * PWM_100us_FACTOR;
delay_counter = 0;
t_current += t_sector;
adcBackEMFFilter = 0; //clear the BEMF filter
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
dsPICDEM MCLV-2開發(fā)板用戶指南.pdf
(1.18 MB, 下載次數(shù): 51)
2018-12-29 15:23 上傳
點(diǎn)擊文件名下載附件
AN1160_dsPIC33EP256MC506_MCLV.rar
(1.04 MB, 下載次數(shù): 67)
2018-12-29 15:23 上傳
點(diǎn)擊文件名下載附件
mcu_mpu
時(shí)間:
2019-9-18 14:37
好東西,學(xué)習(xí)了。
