標題: Arduino按鍵實驗程序 [打印本頁]
作者: EagleSword    時間: 2018-12-27 10:29
標題: Arduino按鍵實驗程序
按鍵實驗:按一下亮第一個燈,按第二下亮第二個燈,按第三下,兩個燈交替亮滅,按第四下,全滅。
const byte LED = 13;
const byte LED1 = 12;
const byte SW = 11;
int count = 0;
int bstate = 0;
int lstate = 0;
void setup() {
  // put your setup code here, to run once:
pinMode(LED,OUTPUT);
pinMode(LED1,OUTPUT);
pinMode(SW,INPUT);
Serial.begin(9600);
void loop() {
  // put your main code here, to run repeatedly:
//boolean val = digitalRead(SW);
bstate = digitalRead(SW);
if(bstate != lstate)
  if (bstate == HIGH)
    count++;
  delay(50);
lstate = bstate;
if (count%4 == 1)
  digitalWrite(LED,HIGH);
  digitalWrite(LED1,LOW);
if (count%4 == 2)
  digitalWrite(LED1,HIGH);
  digitalWrite(LED,LOW);
if (count%4 == 3)
  delay(100);
  delay(100);
if (count%4 == 0 && count!=0)
//if(val){
//  count++;
//  if(count%2==0){
//    digitalWrite(LED,HIGH);
//  if(count%2==1){
//    digitalWrite(LED,LOW);
//  //Serial.println(val);
//else
//  Serial.println('/0x0c');
