標題: 8位數碼管從右到左兩個兩個滾動顯示數字 [打印本頁]
作者: e.冰凌    時間: 2018-12-20 16:50
#include <reg52.h>
typedef  unsigned int u16;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
u16 D_tube[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                                        0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};                //顯示0~F的值
void delay(u16 n)
  while(n--);
void roll(u16 data1,u16 data2)
u16 num,i;
for(num=0;num<7;num++)
        for(i=0;i<10;i++)                                                //移動的速度,可調
                 switch (num)
                        case 0:
                                LSA=0;LSB=0;LSC=0;break;
                        case 1:
                                LSA=1;LSB=0;LSC=0;break;
                        case 2:
                                LSA=0;LSB=1;LSC=0;break;
                        case 3:
                                LSA=1;LSB=1;LSC=0;break;
                        case 4:
                                LSA=0;LSB=0;LSC=1;break;
                        case 5:
                                LSA=1;LSB=0;LSC=1;break;
                        case 6:
                                LSA=0;LSB=1;LSC=1;break;
                        case 7:
                                LSA=1;LSB=1;LSC=1;break;
                P0=D_tube[data1];
                delay(1000);
                P0=0x00;
                num+=1;
                 switch (num)
                        case 0:
                        case 1:
                        case 2:
                        case 3:
                        case 4:
                        case 5:
                        case 6:
                        case 7:
                P0=D_tube[data2];
                delay(1000);
                num--;
void bomb()
u16 i;
for(i=0;i<8;i++)
         switch (i)
                case 0:
                case 1:
                case 2:
                case 3:
                case 4:
                case 5:
                case 6:
                case 7:
        P0=0x7f;
        delay(100);
        u16 data1=1;                                //data1:右邊一位顯示的數字,可改變
        u16 data2=2;                                //data1:左邊一位顯示的數字
        roll(data1,data2);
        bomb();
作者: admin    時間: 2018-12-20 16:53
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
