基于STC89C52的MF RC522門禁卡 代碼
張珅源520690
2018-12-16 23:47
#include <intrins.h>
#include "reg52.h"
#include "main.h"
#include "mfrc522.h"
#include <string.h>
#define MAXRLEN 18
//功 能:尋卡
//參數(shù)說明: req_code[IN]:尋卡方式
// 0x52 = 尋感應(yīng)區(qū)內(nèi)所有符合14443A標準的卡
// 0x26 = 尋未進入休眠狀態(tài)的卡
// pTagType[OUT]:卡片類型代碼
// 0x4400 = Mifare_UltraLight
// 0x0400 = Mifare_One(S50)
// 0x0200 = Mifare_One(S70)
// 0x0800 = Mifare_Pro(X)
// 0x4403 = Mifare_DESFire
//返 回: 成功返回MI_OK
char PcdRequest(unsigned char req_code,unsigned char *pTagType)
char status;
unsigned int unLen;
unsigned char ucComMF522Buf[MAXRLEN];
// unsigned char xTest ;
ClearBitMask(Status2Reg,0x08);
WriteRawRC(BitFramingReg,0x07);
// xTest = ReadRawRC(BitFramingReg);
// if(xTest == 0x07 )
// { LED_GREEN =0 ;}
// else {LED_GREEN =1 ;while(1){}}
SetBitMask(TxControlReg,0x03);
ucComMF522Buf[0] = req_code;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
// if(status == MI_OK )
// else {LED_GREEN =1 ;}
if ((status == MI_OK) && (unLen == 0x10))
*pTagType = ucComMF522Buf[0];
*(pTagType+1) = ucComMF522Buf[1];
{ status = MI_ERR; }
return status;
//功 能:防沖撞
//參數(shù)說明: pSnr[OUT]:卡片序列號,4字節(jié)
//返 回: 成功返回MI_OK
char PcdAnticoll(unsigned char *pSnr)
char status;
unsigned char i,snr_check=0;
unsigned int unLen;
WriteRawRC(BitFramingReg,0x00);
ClearBitMask(CollReg,0x80);
ucComMF522Buf[0] = PICC_ANTICOLL1;
ucComMF522Buf[1] = 0x20;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
if (status == MI_OK)
for (i=0; i<4; i++)
*(pSnr+i) = ucComMF522Buf[i];
snr_check ^= ucComMF522Buf[i];
if (snr_check != ucComMF522Buf[i])
SetBitMask(CollReg,0x80);
return status;
//功 能:選定卡片
//參數(shù)說明: pSnr[IN]:卡片序列號,4字節(jié)
//返 回: 成功返回MI_OK
char PcdSelect(unsigned char *pSnr)
char status;
unsigned char i;
unsigned int unLen;
ucComMF522Buf[1] = 0x70;
ucComMF522Buf[6] = 0;
for (i=0; i<4; i++)
ucComMF522Buf[i+2] = *(pSnr+i);
ucComMF522Buf[6] ^= *(pSnr+i);
CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
if ((status == MI_OK) && (unLen == 0x18))
{ status = MI_OK; }
return status;
//功 能:驗證卡片密碼
//參數(shù)說明: auth_mode[IN]: 密碼驗證模式
// 0x60 = 驗證A密鑰
// 0x61 = 驗證B密鑰
// addr[IN]:塊地址
// pKey[IN]:密碼
// pSnr[IN]:卡片序列號,4字節(jié)
//返 回: 成功返回MI_OK
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
char status;
unsigned int unLen;
unsigned char i,ucComMF522Buf[MAXRLEN];
ucComMF522Buf[0] = auth_mode;
ucComMF522Buf[1] = addr;
for (i=0; i<6; i++)
{ ucComMF522Buf[i+2] = *(pKey+i); }
for (i=0; i<6; i++)
{ ucComMF522Buf[i+8] = *(pSnr+i); }
// memcpy(&ucComMF522Buf[2], pKey, 6);
// memcpy(&ucComMF522Buf[8], pSnr, 4);
status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
return status;
//功 能:讀取M1卡一塊數(shù)據(jù)
//參數(shù)說明: addr[IN]:塊地址
// pData[OUT]:讀出的數(shù)據(jù),16字節(jié)
//返 回: 成功返回MI_OK
char PcdRead(unsigned char addr,unsigned char *pData)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_READ;
CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
if ((status == MI_OK) && (unLen == 0x90))
// { memcpy(pData, ucComMF522Buf, 16); }
for (i=0; i<16; i++)
{ *(pData+i) = ucComMF522Buf[i]; }
return status;
//功 能:寫數(shù)據(jù)到M1卡一塊
// pData[IN]:寫入的數(shù)據(jù),16字節(jié)
//返 回: 成功返回MI_OK
char PcdWrite(unsigned char addr,unsigned char *pData)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_WRITE;
if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
//memcpy(ucComMF522Buf, pData, 16);
{ ucComMF522Buf[i] = *(pData+i); }
CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
return status;
//功 能:命令卡片進入休眠狀態(tài)
//返 回: 成功返回MI_OK
char PcdHalt(void)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_HALT;
ucComMF522Buf[1] = 0;
return MI_OK;
//用MF522計算CRC16函數(shù)
void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
unsigned char i,n;
ClearBitMask(DivIrqReg,0x04);
WriteRawRC(CommandReg,PCD_IDLE);
SetBitMask(FIFOLevelReg,0x80);
for (i=0; i<len; i++)
{ WriteRawRC(FIFODataReg, *(pIndata+i)); }
WriteRawRC(CommandReg, PCD_CALCCRC);
i = 0xFF;
do
n = ReadRawRC(DivIrqReg);
i--;
while ((i!=0) && !(n&0x04));
pOutData[0] = ReadRawRC(CRCResultRegL);
pOutData[1] = ReadRawRC(CRCResultRegM);
//功 能:復(fù)位RC522
//返 回: 成功返回MI_OK
char PcdReset(void)
MF522_RST=1;
_nop_();
MF522_RST=0;
_nop_();
MF522_RST=1;
_nop_();
WriteRawRC(CommandReg,PCD_RESETPHASE);
_nop_();
WriteRawRC(ModeReg,0x3D); //和Mifare卡通訊,CRC初始值0x6363
WriteRawRC(TReloadRegL,30);
WriteRawRC(TReloadRegH,0);
WriteRawRC(TModeReg,0x8D);
WriteRawRC(TPrescalerReg,0x3E);
WriteRawRC(TxAutoReg,0x40);
return MI_OK;
//設(shè)置RC632的工作方式
char M500PcdConfigISOType(unsigned char type)
if (type == 'A') //ISO14443_A
/* WriteRawRC(CommandReg,0x20); //as default
WriteRawRC(ComIEnReg,0x80); //as default
WriteRawRC(DivlEnReg,0x0); //as default
WriteRawRC(ComIrqReg,0x04); //as default
WriteRawRC(DivIrqReg,0x0); //as default
WriteRawRC(Status2Reg,0x0);//80 //trun off temperature sensor
WriteRawRC(WaterLevelReg,0x08); //as default
WriteRawRC(ControlReg,0x20); //as default
WriteRawRC(CollReg,0x80); //as default
WriteRawRC(ModeReg,0x3D);//3F
/* WriteRawRC(TxModeReg,0x0); //as default???
WriteRawRC(RxModeReg,0x0); //as default???
WriteRawRC(TxControlReg,0x80); //as default???
WriteRawRC(TxSelReg,0x10); //as default???
WriteRawRC(RxSelReg,0x86);//84
// WriteRawRC(RxThresholdReg,0x84);//as default
// WriteRawRC(DemodReg,0x4D); //as default
// WriteRawRC(ModWidthReg,0x13);//26
WriteRawRC(RFCfgReg,0x7F); //4F
/* WriteRawRC(GsNReg,0x88); //as default???
WriteRawRC(CWGsCfgReg,0x20); //as default???
WriteRawRC(ModGsCfgReg,0x20); //as default???
WriteRawRC(TReloadRegL,30);//tmoLength);// TReloadVal = 'h6a =tmoLength(dec)
// PcdSetTmo(106);
delay_10ms(1);
PcdAntennaOn();
else{ return -1; }
return MI_OK;
//功 能:讀RC632寄存器
//參數(shù)說明:Address[IN]:寄存器地址
//返 回:讀出的值
unsigned char ReadRawRC(unsigned char Address)
unsigned char i, ucAddr;
unsigned char ucResult=0;
MF522_SCK = 0;
MF522_NSS = 0;
ucAddr = ((Address<<1)&0x7E)|0x80;
for(i=8;i>0;i--)
MF522_SI = ((ucAddr&0x80)==0x80);
MF522_SCK = 1;
ucAddr <<= 1;
MF522_SCK = 0;
for(i=8;i>0;i--)
MF522_SCK = 1;
ucResult <<= 1;
ucResult|=(bit)MF522_SO;
MF522_SCK = 0;
MF522_NSS = 1;
MF522_SCK = 1;
return ucResult;
//功 能:寫RC632寄存器
// value[IN]:寫入的值
void WriteRawRC(unsigned char Address, unsigned char value)
MF522_SCK = 0;
MF522_NSS = 0;
ucAddr = ((Address<<1)&0x7E);
for(i=8;i>0;i--)
MF522_SCK = 1;
ucAddr <<= 1;
MF522_SCK = 0;
for(i=8;i>0;i--)
MF522_SI = ((value&0x80)==0x80);
MF522_SCK = 1;
value <<= 1;
MF522_SCK = 0;
MF522_NSS = 1;
MF522_SCK = 1;
//功 能:置RC522寄存器位
//參數(shù)說明:reg[IN]:寄存器地址
// mask[IN]:置位值
void SetBitMask(unsigned char reg,unsigned char mask)
char tmp = 0x0;
tmp = ReadRawRC(reg);
WriteRawRC(reg,tmp | mask); // set bit mask
//功 能:清RC522寄存器位
// mask[IN]:清位值
void ClearBitMask(unsigned char reg,unsigned char mask)
char tmp = 0x0;
WriteRawRC(reg, tmp & ~mask); // clear bit mask
//功 能:通過RC522和ISO14443卡通訊
//參數(shù)說明:Command[IN]:RC522命令字
// pInData[IN]:通過RC522發(fā)送到卡片的數(shù)據(jù)
// InLenByte[IN]:發(fā)送數(shù)據(jù)的字節(jié)長度
// pOutData[OUT]:接收到的卡片返回數(shù)據(jù)
// *pOutLenBit[OUT]:返回數(shù)據(jù)的位長度
char PcdComMF522(unsigned char Command,
unsigned char *pInData,
unsigned char InLenByte,
unsigned char *pOutData,
unsigned int *pOutLenBit)
char status = MI_ERR;
unsigned char irqEn = 0x00;
unsigned char waitFor = 0x00;
unsigned char lastBits;
unsigned char n;
unsigned int i;
switch (Command)
case PCD_AUTHENT:
irqEn = 0x12;
waitFor = 0x10;
break;
case PCD_TRANSCEIVE:
irqEn = 0x77;
waitFor = 0x30;
break;
default:
break;
WriteRawRC(ComIEnReg,irqEn|0x80);
ClearBitMask(ComIrqReg,0x80);
for (i=0; i<InLenByte; i++)
{ WriteRawRC(FIFODataReg, pInData[i]); }
WriteRawRC(CommandReg, Command);
if (Command == PCD_TRANSCEIVE)
{ SetBitMask(BitFramingReg,0x80); }
// i = 600;//根據(jù)時鐘頻率調(diào)整,操作M1卡最大等待時間25ms
i = 2000;
do
n = ReadRawRC(ComIrqReg);
i--;
while ((i!=0) && !(n&0x01) && !(n&waitFor));
ClearBitMask(BitFramingReg,0x80);
if (i!=0)
if(!(ReadRawRC(ErrorReg)&0x1B))
status = MI_OK;
if (n & irqEn & 0x01)
{ status = MI_NOTAGERR; }
n = ReadRawRC(FIFOLevelReg);
lastBits = ReadRawRC(ControlReg) & 0x07;
if (lastBits)
{ *pOutLenBit = (n-1)*8 + lastBits; }
{ *pOutLenBit = n*8; }
if (n == 0)
{ n = 1; }
if (n > MAXRLEN)
{ n = MAXRLEN; }
for (i=0; i<n; i++)
{ pOutData[i] = ReadRawRC(FIFODataReg); }
SetBitMask(ControlReg,0x80); // stop timer now
return status;
//開啟天線
//每次啟動或關(guān)閉天險發(fā)射之間應(yīng)至少有1ms的間隔
void PcdAntennaOn()
unsigned char i;
i = ReadRawRC(TxControlReg);
if (!(i & 0x03))
SetBitMask(TxControlReg, 0x03);
//關(guān)閉天線
void PcdAntennaOff()
ClearBitMask(TxControlReg, 0x03);
//功 能:扣款和充值
//參數(shù)說明: dd_mode[IN]:命令字
// 0xC0 = 扣款
// 0xC1 = 充值
// addr[IN]:錢包地址
// pValue[IN]:4字節(jié)增(減)值,低位在前
//返 回: 成功返回MI_OK
char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue)
char status;
unsigned int unLen;
ucComMF522Buf[0] = dd_mode;
memcpy(ucComMF522Buf, pValue, 4);
// for (i=0; i<16; i++)
// { ucComMF522Buf[i] = *(pValue+i); }
CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
unLen = 0;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
if (status != MI_ERR)
{ status = MI_OK; }
ucComMF522Buf[0] = PICC_TRANSFER;
return status;
//功 能:備份錢包
//參數(shù)說明: sourceaddr[IN]:源地址
// goaladdr[IN]:目標地址
//返 回: 成功返回MI_OK
char PcdBakValue(unsigned char sourceaddr, unsigned char goaladdr)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_RESTORE;
ucComMF522Buf[1] = sourceaddr;
ucComMF522Buf[0] = 0;
ucComMF522Buf[2] = 0;
ucComMF522Buf[3] = 0;
{ status = MI_OK; }
if (status != MI_OK)
{ return MI_ERR; }
ucComMF522Buf[1] = goaladdr;
return status;
// Delay 10ms
void delay_10ms(unsigned int _10ms)
#ifndef NO_TIMER2
RCAP2LH = RCAP2_10ms;
T2LH = RCAP2_10ms;
TR2 = TRUE;
while (_10ms--)
while (!TF2);
TF2 = FALSE;
TR2 = FALSE;
#else
while (_10ms--)
delay_50us(19);
if (CmdValid)
return;
delay_50us(20);
if (CmdValid)
return;
delay_50us(20);
if (CmdValid)
return;
delay_50us(20);
if (CmdValid)
return;
delay_50us(20);
if (CmdValid )
return;
delay_50us(20);
if (CmdValid)
return;
delay_50us(20);
if (CmdValid)
return;
delay_50us(20);
if (CmdValid)
return;
delay_50us(20);
if (CmdValid)
return;
delay_50us(19);
if (CmdValid)
return;
#endif
RFID門禁刷卡識別源代碼.zip
2018-12-16 23:47 上傳
260.63 KB, 下載次數(shù): 63, 下載積分: 黑幣 -5
hfsdage
2019-3-14 23:27
感謝樓主分享,最近需要
