標(biāo)題: 計數(shù)器源碼 [打印本頁]
作者: quhongsheng    時間: 2018-12-12 15:12
#include <reg51.h>
typedef unsigned char uchar;
typedef unsigned int uint;
//lcd 管腳口定義
#define LCD1602_DATAPINS P0
//開拓者
sbit LCD1602_E=P2^7;
sbit LCD1602_RW=P2^5;
sbit LCD1602_RS=P2^6;
sbit cgq = P3^0;
sbit beep = P1^5;
////自己焊的板子
//sbit LCD1602_RS = P1^0;
//sbit LCD1602_RW = P1^1;
//sbit LCD1602_E = P1^2;
//sbit cgq = P2^1;
//sbit beep = P1^4;
uint count = 0;        //計數(shù)值
uint a = 0;
static uint p = 0;        //中斷標(biāo)號
uint flag = 0,m = 0;        //中斷標(biāo)志位
uint num1[] = {'0','1','2','3','4','5','6','7','8','9'};                //數(shù)字
uchar line1[] = "  **Counter**   ";        //首行顯示字符
uint num2[16];        //存儲數(shù)值
uchar blank[] = "                ";        //存儲16個空格
void delay_1ms(uint x)
        uint y;
        for(;x > 0;x--)
                for(y = 110;y > 0;y--);
void Lcd1602_Delay1ms(uint c)   //誤差 0us
    uchar a,b;
        for (; c>0; c--)
                 for (b=199;b>0;b--)
                          for(a=1;a>0;a--);
void LcdWriteCom(uchar com)          //寫入命令
        LCD1602_E = 0;     //使能
        LCD1602_RS = 0;           //選擇發(fā)送命令
        LCD1602_RW = 0;           //選擇寫入
        LCD1602_DATAPINS = com;     //放入命令
        Lcd1602_Delay1ms(1);                //等待數(shù)據(jù)穩(wěn)定
        LCD1602_E = 1;                  //寫入時序
        Lcd1602_Delay1ms(5);          //保持時間
        LCD1602_E = 0;
void LcdWriteData(uchar dat)                        //寫入數(shù)據(jù)
        LCD1602_E = 0;        //使能清零
        LCD1602_RS = 1;        //選擇輸入數(shù)據(jù)
        LCD1602_DATAPINS = dat; //寫入數(shù)據(jù)
        LCD1602_E = 0;
void LcdDisplay(uint num)
        uint i;
        num2[15-2] = num/100;                  //百位
        if(num > 99)
                num2[15-1] = num/10%10;
                num2[15-1] = num/10;                //十位
        num2[15] = num%10;                        //個位
        LcdWriteCom(0x01);  //清屏
        LcdWriteCom(0x80);  //設(shè)置數(shù)據(jù)指針起點
        for(i=0;i<16;i++)
                LcdWriteData(line1[i]);
        LcdWriteCom(0x80+0x40);           //光標(biāo)移動到第二行
        for(i=0;i<16;i++)
                if(i < 13)
                        LcdWriteData(blank[i]);
                        LcdWriteData(num1[num2[i]]);
void LcdInit()                                                  //LCD初始化子程序
        LcdWriteCom(0x38);  //開顯示
        LcdWriteCom(0x0c);  //開顯示不顯示光標(biāo)
        LcdWriteCom(0x06);  //寫一個指針加1
//傳感器計數(shù)
void CgqCounter()
        if(cgq == 0)
                delay_1ms(20);
                if(cgq == 0)
                        while((!cgq));
                        count++;
                        LcdDisplay(count);
void Timer0_Init()
        TMOD |= 0x01;
        TH0 = 0xfc;
        TL0 = 0x18;
        EA = 1;
        ET0 = 1;
        TR0 = 0;
        Timer0_Init();
        LcdInit();
        LcdDisplay(count);
                CgqCounter();
                if((count % 12 == 0) && (count >= 12) && (m != count))
                        flag = 1;
                        TR0 = 1;
void Timer0() interrupt 1
        TH0 = 0xfc;
        TL0 = 0x18;
        p++;
        if(flag == 1)
                beep = !beep;
                if(p == 2000)
                        TR0 = 0;
                        p = 0;
                        flag = 0;
                        m = count;
作者: admin    時間: 2018-12-13 02:51
補全原理圖或者詳細(xì)說明一下電路連接即可獲得100+黑幣
