標(biāo)題: 單片機(jī)0-99秒表程序+電路(精確到0.1秒) [打印本頁(yè)]
作者: 境s。    時(shí)間: 2018-12-8 17:02
大二工科直女,單片機(jī)剛?cè)肟樱@是第一個(gè)全部由自己完成的處女作啦,在圖書(shū)館調(diào)試到腰酸背痛,但還是超級(jí)開(kāi)心!!
我的單片機(jī)是淘寶買(mǎi)的學(xué)習(xí)板,所以電路圖直接發(fā)現(xiàn)有的咯
萌新們大家一起加油鴨~~
單片機(jī)源程序如下:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #define uint unsigned  int
  5. sbit key2=P3^0;
  6. sbit key3=P3^1;
  7. sbit key4=P3^2;
  8. sbit key5=P3^3;
  9. sbit DU=P2^6;
  10. sbit WE=P2^7;
  11. uchar secs,sec, msec, usec;
  12. uchar  code tabel[]= {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F,};
  13. void delay(uint z)
  14. {
  15.         uint x,y;
  16.         for(x = z; x > 0; x--)
  17.                 for(y = 114; y > 0 ; y--);
  18. }
  19. void display(uchar secs,sec,msec)
  20. {
  21.
  22.         P0 = 0XFF;
  23.         WE = 1;
  24.         P0 = 0XFE;
  25.         WE = 0;
  26.
  27.         DU = 1;
  28.         P0 = tabel[secs];
  29.         DU = 0;
  30.         delay(5);
  31.         P0 = 0XFF;
  32.         WE = 1;
  33.         P0 = 0XFD;
  34.         WE = 0;
  35.
  36.         DU = 1;
  37.         P0 = tabel[sec];
  38.         DU = 0;
  39.         delay(5);
  40.         P0 = 0XFF;
  41.         WE = 1;
  42.         P0 = 0XFB;
  43.         WE = 0;
  44.
  45.         DU = 1;
  46.         P0 = tabel[msec];
  47.         DU = 0;
  48.         delay(5);
  49. }
  50. void dian()
  51. {
  52.            P0 = 0XFF;
  53.         WE = 1;
  54.         P0 = 0XFD;
  55.         WE = 0;
  56.
  57.         DU = 1;
  58.         P0 = 0x80;
  59.         DU = 0;
  60.         delay(5);
  61. }
  62. void count()
  63. {
  64.            if(usec == 10)
  65.                         {
  66.                                 usec = 0;
  67.                                 msec++;
  68.                         }
  69.                           if(msec==10)
  70.                           {
  71.                           msec=0;
  72.                           sec++;
  73.                           }
  74.                            if(sec==10)
  75.                           {
  76.                           sec=0;
  77.                           secs++;
  78.                           }
  79.                            if(secs==10)
  80.                         {
  81.                                         TR0=0;
  82.                                         TH0=0XDC;
  83.                                         TL0=0X00;
  84.                                         usec=0;
  85.                                         msec=0;
  86.                                    sec=0;
  87.                                    secs=0;
  88.                                         TR0=1;
  89.             }
  90. }
  91. void timer0() interrupt 1
  92. {
  93.         TH0=0XDC;
  94.         TL0=0X00;
  95.         usec++;
  96.         count();
  97.
  98. }
  99. void init()
  100. {
  101.
  102.         TMOD=0X01;
  103.         TH0=0XDC;
  104.         TL0=0X00;
  105.         EA=1;
  106.         ET0=1;
  107.         sec=0;
  108.     msec=0;
  109.         usec=0;
  110.         secs=0;
  111. }
  112. void keyscan()
  113. {
  114.         if(key2==0)//判斷按鍵是否按下
  115.                 {
  116.                         delay(10);//延時(shí)10ms用以消抖
  117.                         if(key2==0)//按鍵確實(shí)按下
  118.                         {
  119.                                 while(key2==0)//松手檢測(cè)
  120.                                 {
  121.                                         display(secs,sec,msec);//還沒(méi)松手時(shí),不斷刷新顯示函數(shù),這樣數(shù)碼管就不會(huì)不顯示
  122.                                 }
  123.                                 TR0=1;//打開(kāi)定時(shí)器0
  124.
  125.                         }
  126.                 }
  127.
  128.                 if(key3==0)//判斷按鍵是否按下
  129.                 {
  130.                         delay(10);//延時(shí)10ms用以消抖
  131.                         if(key3==0)//按鍵確實(shí)按下
  132.                         {
  133.                                 while(key3==0)//松手檢測(cè)
  134.                                 {
  135.                                      TR0=0;//關(guān)閉定時(shí)器0
  136.                                 }
  137.                     }
  138.             }
  139.        if(key4==0)//判斷按鍵是否按下
  140.                 {
  141.                         delay(10);//延時(shí)10ms用以消抖
  142.                         if(key4==0)//按鍵確實(shí)按下
  143.                         {
  144.                                 while(key4==0)//松手檢測(cè)
  145.                                 {
  146.                                      TR0=1;//關(guān)閉定時(shí)器0
  147.                                 }
  148.                     }
  149.             }
  150.
  151.            if(key5==0)
  152.            {
  153.                         delay(10);//延時(shí)10ms消抖
  154.                         if(key5==0)//zero按鍵確實(shí)按下
  155.                         {
  156.                                 TR0=0;//關(guān)閉定時(shí)器0
  157.                             while(key5==0)//松手檢測(cè)
  158.                                    {
  159.                                             display(secs,sec,msec);//還沒(méi)松手時(shí),不斷刷新顯示函數(shù),這樣數(shù)碼管就不會(huì)不顯示
  160.                                    }
  161.                                 TH0=0; //重新裝初值
  162.                                 TL0=0;
  163.                                 sec=0;//初始化一下變量為默認(rèn)的數(shù)值(0);
  164.                                 msec=0;
  165.                                 usec=0;
  166.                                 secs=0;
  167.
  168.                         }
  169.
  170.            }
  171.
  172. }
  173. void main()
  174. {
  175.
  176.         init();
  177.         while(1)
  178.         { dian();
  179.         keyscan();
  180.         display(secs,sec,msec);
  181.         }
  182. }
秒表.rar (22.78 KB, 下載次數(shù): 29)
開(kāi)發(fā)板原理圖V3(1).pdf (152.3 KB, 下載次數(shù): 27)
作者: 素質(zhì)    時(shí)間: 2018-12-10 10:14
厲害了
