單片機全自動洗衣機程序
zbyw
2018-12-5 15:41
單片機全自動洗衣機程序
全自動洗衣機
#include <reg51.h> /*地址頭文件*/
#include <absacc.h> /*絕對地址訪問頭文件*/
#include <math.h> /*數學庫函數*/
#include <intrins.h> /*內部函數庫*/
#define IN0 XBYTE[0x2030] /* 0809通道0地址 */
#define w_c_add XBYTE[0x2070] /* lcd寫命令字地址 */
#define w_d_add XBYTE[0x2071] /* lcd寫數據地址 */
#define r_s_add XBYTE[0x2072] /* lcd讀狀態字地址 */
#define r_d_add XBYTE[0x2073] /* lcd讀數據地址 */
#define c8279 XBYTE [0x2021] /* 8279命令/狀態口的地址 */
#define d8279 XBYTE [0x2020] /* 8279數據口地址 */
unsigned char water_level;/*水位*/
unsigned char wash_power;/*洗滌強度*/
unsigned char wash_power1;
unsigned char piao_time;/*漂洗次數*/
unsigned char m;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
0x77,0x7c,0x39,0x5e,0x79,0x71}; /* 字型表 */
unsigned char code TAB1[8] = {0x10,0x30,0x20,0x60,0x40,0xC0,0x80,0x90};//電機正轉
unsigned char code TAB2[8] = {0x90,0x80,0xC0,0x40,0x60,0x20,0x30,0x10};//電機反轉
unsigned char bdata status; /* 可位尋址片內數據存儲器,允許位與字節混合訪問 */
sbit busy=status^7; /*“忙”線的第7位*/
sbit clflag=ACC^7; /*8279查詢位*/
unsigned char key;
unsigned char keyflag=0;
unsigned char Min;
unsigned char Sec;
unsigned char TimeEnd=0;
unsigned char ZTime;
sbit Speaker=P3^6; /*蜂鳴器*/
sbit Led=P3^0; /*Led小燈*/
sbit Led1=P3^1; /*Led小燈*/
void alarm(unsigned int t);
void delay(unsigned int t);
void delay1(unsigned char n);
void DaoJiShi();
void TimeSelect();
void lcd_num(unsigned char i,unsigned char j,unsigned char num);
void lcd_string(unsigned char i,unsigned char j,unsigned char *s);
void lcd_clr(); /*LCD清除程序*/
void init_lcd(); /*LCD初始化*/
void lcd_busy(void); /*LCD忙狀態檢測函數 */
void init_8279(void);
unsigned char adc0809();
void play0809(unsigned char m,unsigned char n);
void MotorChoose();
void MotorChoose1();
void ZdCanShu();
void PxTimes();
void XdPower();
void ShuiWei();
void ShangShui();
void QinPao();
void TuoShui();
void XiDi();
void ShuaiGan();
void PiaoXi();
主函數
{ unsigned char j;
init_lcd();
init_8279();
while(key!=0x0f); /*按f開啟洗衣機*/
alarm(2);
keyflag=0;
lcd_string(1,1,"****************");
lcd_busy();
lcd_string(2,1,"歡迎使用洗衣機");
lcd_busy();
lcd_string(3,1,"按任意鍵繼續");
lcd_busy();
lcd_string(4,1,"****************");
while(keyflag!=1);
alarm(2);
keyflag=0;
lcd_clr();
lcd_busy();
lcd_string(2,3,"開始工作!");
delay(5);
lcd_busy();
lcd_string(2,1,"請選擇使用模式");
delay(5);
lcd_clr();
lcd_clr();
lcd_busy();
lcd_string(1,1,"0 - 全自動模式");
lcd_string(2,1,"1 - 浸泡");
lcd_string(2,5,"2 - 洗滌");
lcd_string(3,1,"3 - 漂洗");
lcd_string(3,5,"4 - 甩干");
while(1!=keyflag);
alarm(2);
keyflag=0;
lcd_clr();
switch(key)
case 0:
{ ZdCanShu();
/*********************上水**************************/
lcd_busy();
lcd_string(4,1,"請按確認鍵");
while(key!=0x0e); /*按e確認*/
alarm(1);
keyflag=0;
lcd_clr();
lcd_busy();
lcd_string(1,1,"上水中");
ShangShui();
delay(5);
/*******************浸泡***************************/
QinPao();
delay(2);
/*********************洗滌**************************/
XiDi();
delay(2);
/*********************脫水**************************/
TuoShui();
delay(2);
/*********************漂洗**************************/
PiaoXi();
delay(2);
/*********************甩干**************************/
ShuaiGan();
delay(2);
break;
case 1:
{ ShuiWei();
lcd_busy();
lcd_string(3,1,"請按確認鍵");
alarm(1);
keyflag=0;
lcd_clr();
lcd_busy();
ShangShui();
delay(5);
QinPao();
break;
case 2:
{ ShuiWei();
XdPower();
lcd_busy();
alarm(1);
keyflag=0;
lcd_clr();
lcd_busy();
ShangShui();
delay(5);
XiDi();
delay(2);
TuoShui();
delay(2);
break;
case 3:
{ ShuiWei();
PxTimes();
lcd_busy();
alarm(1);
keyflag=0;
PiaoXi();
delay(2);
break;
case 4:
{/*********************甩干**************************/
lcd_clr();
lcd_busy();
lcd_string(2,1,"請按確認鍵");
while(key!=0x0e);
alarm(1);
keyflag=0;
ShuaiGan();
delay(2);
break;
default:break;
lcd_clr();
while(j<5)
alarm(2);
delay(2);
lcd_busy();
lcd_string(2,3,"工作結束!");
j++;
lcd_clr();
while(1);
函數名:delay
函數功能:延時函數
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<30000;j++);
函數名:delay1
函數功能:延時xms函數
void delay1(unsigned char t)
{ unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<60;j++);
函數名:init_8279
函數功能:8279初始化函數
c8279=0xd1; /* 清除顯示 */
do {ACC=c8279;} /* 讀8279狀態寄存器 */
while(clflag==1); /* 讀狀態字,等待清除結束*/
c8279=0x00; /* 8字符顯示左入口 */
c8279=0x23; /* 12分頻 */
EA=1;
EX0=1;
函數名:INT0_SERVICE
函數功能:外中斷0服務函數(讀鍵值)
void INT0_SERVICE(void) interrupt 0 using 2
unsigned char i;
EA=0;
c8279=0x40; /*讀fifo ram命令*/
i=d8279;
i=i&0x0f; /*取鍵值低4位*/
key=i; /*返回鍵值*/
keyflag=1;
c8279=0x80;
d8279=table[key];
EA=1;
函數名:init_lcd
函數功能:LCD初始化函數
void init_lcd() /*LCD初始化*/
lcd_busy();
w_c_add=0x30; /* 功能設置:8位數據 */
lcd_busy();
w_c_add=0x0C; /* 顯示狀態:整體顯示,游
標位置無效*/
lcd_busy();
w_c_add=0x01; /* 清除顯示:將DDRAM填滿
“20H”*/
lcd_busy();
w_c_add=0x02; /* 地址歸位:設定DDRAM地址計數器
到“00” */
函數名:lcd_busy
函數功能:LCD檢測忙函數
void lcd_busy(void) /*LCD忙狀態檢測函數 */
do
status=r_s_add; /* 讀狀態字地址的第7位 */
while(busy);
函數名:lcd_clr
函數功能:LCD清屏函數
void lcd_clr() /*LCD清除程序*/
lcd_busy();
w_c_add=0x01; /* 清除顯示:將DDRAM填滿“20H”*/
函數名:lcd_string
函數功能:LCD字符串顯示
{ unsigned char m;
switch(i)
{case 1:m=0x80;break;
case 2:m=0x90;break;
case 3:m=0x88;break;
case 4:m=0x98;break;
default:break;
w_c_add=m+j-0x01;
for(;*s!='\0';s++)
lcd_busy();
w_d_add=*s;
函數名:lcd_num
函數功能:LCD字符串顯示
void lcd_num(unsigned char i,unsigned char j,unsigned char num) /*顯示一個數字*/
{ unsigned char m;
switch(i)
default:break;
w_c_add=m+j-0x01;
lcd_busy();
w_d_add=0x30+num; /*0~9分別對應0x30~0x39*/
函數名:alarm
函數功能:報警函數
void alarm(unsigned int m)
{ Led=0;
Led1=0;
Speaker=0;
delay(m); /*延時*/
Speaker=1;
Led=1;
Led1=1;
函數名:ShuiWei
函數功能:水位選擇顯示
void ShuiWei()
{ lcd_clr();
lcd_busy();
lcd_string(1,1,"請選擇水位:");
lcd_string(2,1,"1-一級");
lcd_string(3,1,"2-二級");
lcd_string(4,1,"3-三級");
delay(8);
lcd_clr();
lcd_busy();
lcd_string(1,1,"水位:");
while(1!=keyflag);
alarm(1);
water_level=key; /*水位*/
keyflag=0;
switch(water_level)
case 1:{lcd_busy();lcd_string(1,6,"一級");delay(8);break;}
case 2:{lcd_busy();lcd_string(1,6,"二級");delay(8);break;}
case 3:{lcd_busy();lcd_string(1,6,"三級");delay(8);break;}
default:break;
函數名:XdPower
函數功能:洗滌強度選擇顯示
void XdPower()
{ lcd_clr();
lcd_busy();
lcd_string(1,1,"請選擇洗滌強度:");
lcd_string(2,1,"1-強洗");
lcd_string(2,5,"2-輕洗");
lcd_string(3,1,"3-弱洗");
lcd_string(3,5,"4-自動");
delay(8);
lcd_clr();
lcd_busy();
lcd_string(2,1,"洗滌強度:");
while(1!=keyflag);
alarm(1);
wash_power=key;/*洗滌強度*/
keyflag=0;
switch(wash_power)
case 1:{lcd_busy();lcd_string(2,6,"強洗");delay(8);break;}
case 2:{lcd_busy();lcd_string(2,6,"輕洗");delay(8);break;}
case 3:{lcd_busy();lcd_string(2,6,"弱洗");delay(8);break;}
case 4:{lcd_busy();lcd_string(2,6,"自動");delay(8);break;}
default:break;
函數名:PxTimes
函數功能:洗滌強度選擇顯示
void PxTimes()
{ lcd_clr();
lcd_busy();
lcd_string(1,1,"請選擇漂洗次數:");
lcd_string(2,1,"1-三次");
lcd_string(3,1,"2-四次");
lcd_string(4,1,"3-五次");
delay(8);
lcd_clr();
lcd_busy();
lcd_string(1,1,"漂洗次數:");
while(1!=keyflag);
alarm(1);
piao_time=key;/*漂洗次數*/
keyflag=0;
switch(piao_time)
case 1:{lcd_busy();lcd_string(1,6,"三次");delay(8);break;}
case 2:{lcd_busy();lcd_string(1,6,"四次");delay(8);break;}
case 3:{lcd_busy();lcd_string(1,6,"五次");delay(8);break;}
default:break;
函數名:ZdCanShu
函數功能:洗滌強度選擇顯示
void ZdCanShu()
lcd_clr();
lcd_busy();
delay(8);
while(1!=keyflag);
alarm(1);
keyflag=0;
lcd_clr();
lcd_busy();
delay(8);
while(1!=keyflag);
alarm(1);
keyflag=0;
lcd_clr();
lcd_busy();
delay(8);
while(1!=keyflag);
alarm(1);
keyflag=0;
lcd_clr();
lcd_busy();
lcd_busy();
lcd_busy();
lcd_string(3,1,"漂洗次數:");
switch(water_level)
default:break;
switch(wash_power)
default:break;
switch( piao_time)
case 1:{lcd_busy();lcd_string(3,6,"三次");delay(8);break;}
case 2:{lcd_busy();lcd_string(3,6,"四次");delay(8);break;}
case 3:{lcd_busy();lcd_string(3,6,"五次");delay(8);break;}
default:break;
函數名:TimeSelect
函數功能:根據條件選擇洗滌時間
void TimeSelect()
switch(wash_power1)
case 1:{Sec=10; Min=0;break;}
case 2:{Sec=15; Min=0;break;}
case 3:{Sec=20; Min=0;break;}
default:break;
函數名:DaoJiShi
函數功能:定時器0 50ms定時,用于倒計時計時
void DaoJiShi()
TMOD=0x11;
TH0=(65536-46080)/256;// 由于晶振為11.0592,故所記次數應為46080,計時器每隔50000微秒發起一次中斷。
TL0=(65536-46080)%256;
ET0=1;
EA=1;TR0=1;
TimeEnd=0;
函數名:Time0
函數功能:定時器0中斷處理程序,用于倒計時計時
void Time0() interrupt 1 using 2
int t[4];
EA=0;
t[0]=Sec/10;
t[1]=Sec%10;
t[2]=Min/10;
t[3]=Min%10;
lcd_busy();
lcd_num(3,1,t[2]);
lcd_busy();
lcd_num(3,2,t[3]);
lcd_busy();
lcd_num(3,3,10);
lcd_busy();
lcd_num(3,4,t[0]);
lcd_busy();
lcd_num(3,5,t[1]);
if(TimeEnd==0)
m++;
if(m>=20)
{ m=0;
Sec--;
if(Sec==0&&Min!=0)
Sec=59;
Min--;
if(Sec==0&&Min==0)
{ ET0=0;
TimeEnd=1;
t[0]=Sec/10;
t[1]=Sec%10;
t[2]=Min/10;
t[3]=Min%10;
lcd_busy();
lcd_num(3,1,t[2]);
lcd_busy();
lcd_num(3,2,t[3]);
lcd_busy();
lcd_num(3,3,10);
lcd_busy();
lcd_num(3,4,t[0]);
lcd_busy();
lcd_num(3,5,t[1]);
lcd_busy();
EA=1;
函數名:MotorChoose
函數功能:步進機強度選擇模塊
void MotorChoose()
{ unsigned char j,i,time;
switch(wash_power1)
case 1:{ time=25;lcd_busy();lcd_string(1,6,": 強洗");break;} /*用來控制轉速*/
case 2:{ time=30;lcd_busy();lcd_string(1,6,": 輕洗");break;}
case 3:{ time=35;lcd_busy();lcd_string(1,6,": 弱洗");break;}
default:break;
ZTime=Min*60+Sec;
if(ZTime!=0)
{ for(j=0;j<=15;j++)
for(i=0;i<9;i++)
P1 = TAB1[i];
delay1(time);
/* ZTime=Min*60+Sec;
if(ZTime!=0)*/
for(j=0;j<=15;j++)
for(i=0;i<9;i++)
P1 = TAB2[i];
delay1(time);
函數名:MotorChoose1
函數功能:步進機強度選擇模塊
void MotorChoose1()
time=28;
switch(piao_time)
case 1:{ lcd_busy();lcd_string(1,6,": 三次");break;} /*用來控制轉速*/
case 2:{ lcd_busy();lcd_string(1,6,": 四次");break;}
case 3:{ lcd_busy();lcd_string(1,6,": 五次");break;}
default:break;
ZTime=Min*60+Sec;
if(ZTime!=0)
for(i=0;i<9;i++)
P1 = TAB1[i];
delay1(time);
if(ZTime!=0)*/
for(j=0;j<=15;j++)
for(i=0;i<9;i++)
P1 = TAB2[i];
delay1(time);
函數名:adc0809
函數功能:AD轉換函數
IN0=0;
delay(1);
return(IN0); /*返回值,即轉換后的數據*/
函數名:0809play
功能:顯示AD轉換后的值
{ unsigned char t[3];
unsigned char temp;
temp=adc0809();
t[0]=temp/100;
temp=temp%100;
t[1]=temp/10;
t[2]=temp%10;
lcd_busy();
lcd_num(m,n,t[0]); /*顯示百位數字*/
lcd_busy();
lcd_num(m,n+1,t[1]); /*顯示十位數字*/
lcd_busy();
lcd_num(m,n+2,t[2]); /*顯示個位數字*/
函數名:ShangShui
函數功能:上水模塊
void ShangShui()
{ unsigned char f_flag;
f_flag=0;
while(f_flag==0)
lcd_busy();
lcd_string(2,1,"水位高度:");
play0809(3,4);
delay(1);
switch(water_level)
case 3:{if(adc0809()>=200){alarm(3);f_flag=1;}
break;}
case 2:{if(adc0809()>=80) {alarm(3);f_flag=1;}
break;}
case 1:{if(adc0809()>=30) {alarm(3);f_flag=1;}
break;}
delay(2);
函數名:TuoShui
函數功能:脫水模塊
void TuoShui()
unsigned char i,time;
Min=0;Sec=5;time=18;
lcd_clr();
lcd_busy();
lcd_string(1,1,"脫水中");
lcd_busy();
lcd_string(2,1,"剩余時間:");
DaoJiShi();
ZTime=Min*60+Sec;
while(ZTime!=0)
{ ZTime=Min*60+Sec;
for(i=0;i<9;i++)
P1 = TAB1[i];
delay1(time);
函數名:ShuaiGan
函數功能:甩干模塊
void ShuaiGan()
Min=0;Sec=10;time=12;
lcd_clr();
lcd_busy();
lcd_string(1,1,"甩干中");
lcd_busy();
DaoJiShi();
ZTime=Min*60+Sec;
while(ZTime!=0)
{ ZTime=Min*60+Sec;
for(i=0;i<9;i++)
P1 = TAB1[i];
delay1(time);
函數名:QinPao
函數功能:浸泡模塊
void QinPao()
Sec=5;Min=0;TimeEnd=0;
lcd_clr();
lcd_busy();
lcd_string(1,1,"浸泡中");
TMOD=0x11;
TH0=(65536-46080)/256;// 由于晶振為11.0592,故所記次數應為46080,計時器每隔50000微秒發起一中斷。
TL0=(65536-46080)%256;//46080的來歷,為50000*11.0592/12
ET0=1;
TR0=1;
while(ET0==1);
函數名:XiDi
函數功能:洗滌模塊
void XiDi()
{ unsigned char i;
wash_power1=wash_power;
switch(wash_power)
{case 1:
case 2:
case 3:{
lcd_clr();
lcd_busy();
lcd_string(1,1,"洗滌中");
lcd_busy();
TimeSelect();
DaoJiShi();
ZTime=Min*60+Sec;
while(ZTime!=0)
{ ZTime=Min*60+Sec;
MotorChoose();
break;
case 4:
{ for(i=1;i<4;i++)
{ lcd_clr();
lcd_busy();
lcd_busy();
wash_power1=i;
TimeSelect();
DaoJiShi();
ZTime=Min*60+Sec;
while(ZTime!=0)
{ ZTime=Min*60+Sec;
MotorChoose();
break;
default:break;
函數名:PiaoXi
函數功能:漂洗模塊
void PiaoXi()
{ unsigned char i;
switch(piao_time)
{ case 1:{
for(i=0;i<3;i++)
{ /*********************上水**************************/
lcd_clr();
lcd_busy();
ShangShui();
delay(5);
Sec=10;Min=0;
lcd_clr();
lcd_busy();
lcd_string(1,1,"漂洗中");
lcd_busy();
DaoJiShi();
ZTime=Min*60+Sec;
while(ZTime!=0)
{ ZTime=Min*60+Sec;
MotorChoose1();
delay(2);
TuoShui();
delay(2);
break;
case 2:{
for(i=0;i<4;i++)
lcd_clr();
lcd_busy();
ShangShui();
delay(5);
Sec=10;Min=0;
lcd_clr();
lcd_busy();
lcd_busy();
DaoJiShi();
ZTime=Min*60+Sec;
while(ZTime!=0)
{ ZTime=Min*60+Sec;
MotorChoose1();
delay(2);
TuoShui();
delay(2);
break;
case 3:{
for(i=0;i<5;i++)
lcd_clr();
lcd_busy();
ShangShui();
delay(5);
Sec=10;Min=0;
lcd_clr();
lcd_busy();
lcd_busy();
DaoJiShi();
ZTime=Min*60+Sec;
while(ZTime!=0)
{ ZTime=Min*60+Sec;
MotorChoose1();
delay(2);
TuoShui();
delay(2);
break;
default:break;
47432zhang.zip
(46.32 KB, 下載次數: 30)
2018-12-5 15:41 上傳
洗衣機
