標題: 單片機控制數碼管順序顯示12345678仿真+代碼 [打印本頁]
作者: lucy789    時間: 2018-11-26 13:19
數碼管順序顯示12345678仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. sbit WLE=P2^6;
  5. sbit DLE=P2^7;
  6. uchar code table[]={
  7. 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  8. 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  9. uchar code pos[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  10. uchar n;
  11. void delay(uint z)
  12. {
  13.         uint x,y;
  14.         for(x=z;x>0;x--)
  15.         for(y=112;y>0;y--);
  16. }
  17. void main()
  18. {
  19.         while(1)
  20.         {
  21.                 for(n=1;n<=8;n++)
  22.                 {
  23.                         if(n==1)
  24.                         {
  25.                                 WLE=1;
  26.                                 P0=pos[n];
  27.                                 WLE=0;
  28.                                 DLE=1;
  29.                                 P0=table[n];
  30.                                 DLE=0;
  31.                                 delay(1000);
  32.                         }
  33.                         else if(n==2)
  34.                         {
  35.                                 WLE=1;
  36.                                 P0=pos[n];
  37.                                 WLE=0;
  38.                                 DLE=1;
  39.                                 P0=table[n];
  40.                                 DLE=0;
  41.                                 delay(1000);
  42.                         }
  43.                         else if(n==3)
  44.                         {
  45.                                 WLE=1;
  46.                                 P0=pos[n];
  47.                                 WLE=0;
  48.                                 DLE=1;
  49.                                 P0=table[n];
  50.                                 DLE=0;
  51.                                 delay(1000);
  52.                         }
  53.                         else if(n==4)
  54.                         {
  55.                                 WLE=1;
  56.                                 P0=pos[n];
  57.                                 WLE=0;
  58.                                 DLE=1;
  59.                                 P0=table[n];
  60.                                 DLE=0;
  61.                                 delay(1000);
  62.                         }
  63.                         else if(n==5)
  64.                         {
  65.                                 WLE=1;
  66.                                 P0=pos[n];
  67.                                 WLE=0;
  68.                                 DLE=1;
  69.                                 P0=table[n];
  70.                                 DLE=0;
  71.                                 delay(1000);
  72.                         }
  73.                         else if(n==6)
  74.                         {
  75.                                 WLE=1;
  76.                                 P0=pos[n];
  77.                                 WLE=0;
  78.                                 DLE=1;
  79.                                 P0=table[n];
  80.                                 DLE=0;
  81.                                 delay(1000);
  82.                         }
  83.                         else if(n==7)
  84.                         {
  85.                                 WLE=1;
  86.                                 P0=pos[n];
  87.                                 WLE=0;
  88.                                 DLE=1;
  89.                                 P0=table[n];
  90.                                 DLE=0;
  91.                                 delay(1000);
  92.                         }
  93.                         else if(n==8)
  94.                         {
  95.                                 WLE=1;
  96.                                 P0=pos[n];
  97.                                 WLE=0;
  98.                                 DLE=1;
  99.                                 P0=table[n];
  100.                                 DLE=0;
  101.                                 delay(1000);
  102.                         }
  103.                 }
  104.         }
  105. }
  106.
test1.rar (31.84 KB, 下載次數: 12)
