標(biāo)題: Arduino控制Technics ST-D5000收音頭仿真與源碼 [打印本頁]
作者: learningone    時間: 2018-11-25 09:38
源碼:
QRP 2m FM Transceiver Project with BS2 shiftout any bits
modify by learning 2016.12 */
//Technics ST-D5000 76.1-109.1/150-235/450-809MHz with 25kHz steps
#include<stdlib.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
int buttonpin = A3;
const int PLL_data = 8 ;
const int PLL_clock = 9 ;
const int PLL_LE = 10 ;
unsigned int  C = 0xA9 ;//25kHz steps
unsigned int  D_up;
unsigned int  D_low;
int T = 100;
long freqbandarray[] = {
  7610, 15000, 45000};//0.01MHz
char* bandtext[]={
  "FM", "VH", "U"};
int band = 0;
long stepsizearray[] = {
  5 ,10 ,800};//0.01MHz
char* stepsizetext[]={
  "50 kHz", "100 kHz", "8 MHz"};
int stepsize = 1;
int button;
int buttondelay = 0;
int menuoption = 0;
全部資料51hei下載地址:
LM7001_Tuner.rar (95.13 KB, 下載次數(shù): 11)
