51單片機測風速代碼 485型風速傳感器
搖籃
2018-11-23 10:49
本代碼自己編寫,51單片機測風速,LCD1602顯示,需風速傳感器
#include "reg52.h"
#include "LCD.H"
typedef unsigned char u8;
typedef unsigned int u16;
bit flagFrame = 0;
bit flagTxd = 0;
u8 cntRxd = 0;
u8 cntTxd;
u8 pdata bufRxd[7];
u8 *ptrTxd;
u8 crch,crcl;
u8 datas[10];
unsigned char pdata buf[40];
void delayms(u8 ms) //延時ms
u8 i;
while(ms--)
for(i = 0; i < 120; i++);
unsigned char GetCRC16(unsigned char *ptr, unsigned char len)
unsigned int index;
unsigned char crch = 0xFF; //高 CRC 字節(jié)
unsigned char crcl = 0xFF; //低 CRC 字節(jié)
unsigned char code TabH[] ={ //CRC 高位字節(jié)值表
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
unsigned char code TabL[] = { //CRC 低位字節(jié)值表
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
0x43, 0x83, 0x41, 0x81, 0x80, 0x40
while (len--) //計算指定長度的 CRC
index = crch ^ *ptr++;
crch = crcl ^ TabH[index];
crcl = TabL[index];
return((crch<<8)|crcl);
void UsartInit()
SCON=0X50; //設(shè)置為工作方式1
TMOD=0X20; //設(shè)置計數(shù)器工作方式2
PCON=0X80; //波特率加倍
TH1=0XF3; //計數(shù)器初始值設(shè)置,注意波特率是4800的
TL1=0XF3;
ES=1; //打開接收中斷
EA=1; //打開總中斷
TR1=1; //打開計數(shù)器
void Timer0Init()
TMOD|=0X01;//選擇為定時器0模式,工作方式1,僅用TR0打開啟動。
TH0=0XFC; //給定時器賦初值,定時1ms
TL0=0X18;
ET0=1;//打開定時器0中斷允許
EA=1;//打開總中斷
TR0=1;//打開定時器
void UartRxMonitor(unsigned char ms)
static unsigned char cntbkp = 0;
static unsigned char idletmr = 0;
if(cntRxd>0)
if(cntbkp != cntRxd)
cntbkp = cntRxd ;
idletmr = 0;
if(idletmr<30)
idletmr += ms;
if(idletmr>=30)
flagFrame=1;
cntbkp=0;
unsigned char UartRead(unsigned char *buf,unsigned char len)
unsigned char i;
if(len>cntRxd)
len = cntRxd;
for(i=0;i<len;i++)
*buf++=bufRxd[i];
cntRxd=0;
return len;
void datapros()
int c;
c=buf[3]*256+buf[4];
datas[0]=c/1000;
datas[1]=c%1000/100;
datas[2]=c%1000%100/10;
datas[3]=c%1000%100%10;
void UartDriver()
unsigned char len;
u16 crc;
if(flagFrame)
flagFrame = 0;
len = UartRead(buf,sizeof(buf));
if(buf[0]!=0x04)
return;
crc=GetCRC16(buf,len-2);
crch = crc>>8;
crcl = crc&0xFF;
if((buf[len-2]=crch)&&(buf[len-1]=crcl))
return;
datapros();
void LcdDisplay()
LcdWriteCom(0x80);
LcdWriteData('0'+datas[0]);
LcdWriteCom(0x81);
LcdWriteData('0'+datas[1]);
LcdWriteCom(0x82);
LcdWriteData('0'+datas[2]);
LcdWriteCom(0x83);
LcdWriteData('.');
LcdWriteCom(0x84);
LcdWriteData('0'+datas[3]);
LcdWriteCom(0x85);
LcdWriteData('M');
LcdWriteCom(0x86);
LcdWriteData('/');
LcdWriteCom(0x87);
LcdWriteData('S');
u8 i;
u8 Order[8]={0x04,0x03,0x00,0x16,0x00,0x01,0x65,0x9B};
UsartInit();
Timer0Init();
LcdInit();
delayms(1000);
for(i=0;i<8;i++)
SBUF=Order[i];
while(!TI);
TI=0;
delayms(1000);
UartDriver();
LcdDisplay();
void Usart() interrupt 4
if(RI)
RI=0;
if(cntRxd<sizeof(bufRxd))
bufRxd[cntRxd++]=SBUF;
void Timer0() interrupt 1
TH0=0XFC; //給定時器賦初值,定時30ms
TL0=0X18;
UartRxMonitor(1); //
485型風速傳感器.zip
(53.09 KB, 下載次數(shù): 152)
2018-11-23 10:48 上傳
51測風速 (485)
admin
2018-11-23 14:42
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
djj6216
2019-8-6 08:50
這個引腳定義了么
山外青衫
2020-3-8 13:00
很好,有沒有原理圖?
明日香
2020-8-11 09:41
大佬,求個原理圖,非常感謝
