簡易時鐘代碼供參考
ijnokmpl
2018-11-21 22:53
簡易時鐘代碼供參考
#include<reg51.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit lcden=P3^4;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^7;
uchar count,s1num;
char miao,shi,fen;
uchar code table[]=" 2018-11-20 MON";
uchar code table1[]=" 00:00:00";
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
rs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
uchar num;
dula=0;
wela=0;
lcden=0;
// fen=59;
// miao=53;
// shi=23;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<16;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
write_date(table1[num]);
delay(5);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void keyscan()
rd=0;
if(s1==0)
delay(5);
if(s1==0)
{ s1num++;
while(!s1);
if(s1num==1)
TR0=0;
write_com(0x80+0x40+10);
write_com(0x0f);
if(s1num==2)
write_com(0x80+0x40+7);
if(s1num==3)
write_com(0x80+0x40+4);
if(s1num==4)
s1num=0;
write_com(0x0c);
TR0=1;
if(s1num!=0)
if(s2==0)
delay(5);
if(s2==0)
while(!s2);
if(s1num==1)
miao++;
if(miao==60)
miao=0;
write_sfm(10,miao);
if(s1num==2)
fen++;
if(fen==60)
fen=0;
write_sfm(7,fen);
if(s1num==3)
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
if(s3==0)
delay(5);
if(s3==0)
while(!s3);
if(s1num==1)
/* if(miao==0)
miao=59;
write_sfm(10,miao);
miao--;
if(miao==-1)
miao=59;
write_sfm(10,miao);
if(s1num==2)
fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
if(s1num==3)
shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
init();
keyscan();
// while(1);
void timer0() interrupt 1
count++;
if(count==18)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
write_sfm(7,fen);
write_sfm(10,miao);
