哪位老哥能幫小弟解釋下這段代碼STC單片機的捕獲功能的,表示有點不明白
城江伍佬
2018-11-16 19:30
對于這段代碼幾個地方不清楚,希望哪個老哥幫忙解釋解釋
1 、((BYTE *)&count1)[3] = CCAP0L; //保存本次的捕獲值
((BYTE *)&count1)[2] = CCAP0H;
((BYTE *)&count1)[1] = cnt;
((BYTE *)&count1)[0] = 0;
這是將count1這個LONG INT 數強制轉換成一個數組?最后count1等于多少呢
2、 if (CF && ((CCAP0H & 0x80) == 0))
CF = 0;
cnt++;
這一段的作用是什么?
3、老哥們能不能詳細說說捕獲功能的具體運作流程,小子拜謝了
//本示例在Keil開發環境下請選擇Intel的8058芯片型號進行編譯
//若無特別說明,工作頻率一般為11.0592MHz
#include "reg51.h"
#include "intrins.h"
#define FOSC 11059200L
typedef unsigned char BYTE;
typedef unsigned int WORD;
typedef unsigned long DWORD;
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sfr P_SW1 = 0xA2; //外設功能切換寄存器1
#define CCP_S0 0x10 //P_SW1.4
#define CCP_S1 0x20 //P_SW1.5
sfr CCON = 0xD8; //PCA控制寄存器
sbit CCF0 = CCON^0; //PCA模塊0中斷標志
sbit CCF1 = CCON^1; //PCA模塊1中斷標志
sbit CR = CCON^6; //PCA定時器運行控制位
sbit CF = CCON^7; //PCA定時器溢出標志
sfr CMOD = 0xD9; //PCA模式寄存器
sfr CL = 0xE9; //PCA定時器低字節
sfr CH = 0xF9; //PCA定時器高字節
sfr CCAPM0 = 0xDA; //PCA模塊0模式寄存器
sfr CCAP0L = 0xEA; //PCA模塊0捕獲寄存器 LOW
sfr CCAP0H = 0xFA; //PCA模塊0捕獲寄存器 HIGH
sfr CCAPM1 = 0xDB; //PCA模塊1模式寄存器
sfr CCAP1L = 0xEB; //PCA模塊1捕獲寄存器 LOW
sfr CCAP1H = 0xFB; //PCA模塊1捕獲寄存器 HIGH
sfr CCAPM2 = 0xDC; //PCA模塊2模式寄存器
sfr CCAP2L = 0xEC; //PCA模塊2捕獲寄存器 LOW
sfr CCAP2H = 0xFC; //PCA模塊2捕獲寄存器 HIGH
sfr PCA_PWM0 = 0xf2; //PCA模塊0的PWM寄存器
sfr PCA_PWM1 = 0xf3; //PCA模塊1的PWM寄存器
sfr PCA_PWM2 = 0xf4; //PCA模塊2的PWM寄存器
BYTE cnt; //存儲PCA計時溢出次數
DWORD count0; //記錄上一次的捕獲值
DWORD count1; //記錄本次的捕獲值
DWORD length; //存儲信號的時間長度(count1 - count0)
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
P6M0 = 0x00;
P6M1 = 0x00;
P7M0 = 0x00;
P7M1 = 0x00;
ACC = P_SW1;
ACC &= ~(CCP_S0 | CCP_S1); //CCP_S0=0 CCP_S1=0
P_SW1 = ACC; //(P1.2/ECI, P1.1/CCP0, P1.0/CCP1, P3.7/CCP2)
// ACC = P_SW1;
// ACC &= ~(CCP_S0 | CCP_S1); //CCP_S0=1 CCP_S1=0
// ACC |= CCP_S0; //(P3.4/ECI_2, P3.5/CCP0_2, P3.6/CCP1_2, P3.7/CCP2_2)
// P_SW1 = ACC;
// ACC = P_SW1;
// ACC &= ~(CCP_S0 | CCP_S1); //CCP_S0=0 CCP_S1=1
// ACC |= CCP_S1; //(P2.4/ECI_3, P2.5/CCP0_3, P2.6/CCP1_3, P2.7/CCP2_3)
// P_SW1 = ACC;
CCON = 0; //初始化PCA控制寄存器
//PCA定時器停止
//清除CF標志
//清除模塊中斷標志
CL = 0; //復位PCA寄存器
CH = 0;
CCAP0L = 0;
CCAP0H = 0;
CMOD = 0x09; //設置PCA時鐘源為系統時鐘,且使能PCA計時溢出中斷
CCAPM0 = 0x21; //PCA模塊0為16位捕獲模式(上升沿捕獲,可測從高電平開始的整個周期),且產生捕獲中斷
// CCAPM0 = 0x11; //PCA模塊0為16位捕獲模式(下降沿捕獲,可測從低電平開始的整個周期),且產生捕獲中斷
// CCAPM0 = 0x31; //PCA模塊0為16位捕獲模式(上升沿/下降沿捕獲,可測高電平或者低電平寬度),且產生捕獲中斷
CR = 1; //PCA定時器開始工作
EA = 1;
cnt = 0;
count0 = 0;
count1 = 0;
while (1);
void PCA_isr() interrupt 7 using 1
if (CCF0)
CCF0 = 0;
CF = 0;
cnt++;
count0 = count1; //備份上一次的捕獲值
length = count1 - count0; //計算兩次捕獲的差值,即得到時間長度
((BYTE *)&length)[0] = 0;
if (CF)
CF = 0;
cnt++; //PCA計時溢出次數+1
zailushang316
2019-3-19 16:09
1 long定義的是4個字節的數據,他通過按地址指針尋位的方式,對每一個字節進行賦值操作,這條代碼等價于:count1=0;count1=count1<<8+cnt;count1=count1<<8+CCAP0H;count1=count1<<8+CCAP0L. 2 這行代碼我覺得考慮到的是捕獲到有效脈沖信號的同時,發生了溢出中斷的問題。3 捕獲模式就是捕捉到有效的信號沿以后,把計數器里面的值復制過來,計數器是不斷計數的,相當于你知道開始時間和結束時間,那這個信號的持續時間或者是周期你就知道了。
