標題: 基于stm32的dht11溫濕度源代碼分享 [打印本頁]
作者: yc318220    時間: 2018-11-16 16:20
基于stm32溫濕度    LCD可顯示學號姓名
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "usmart.h"
  8. #include "malloc.h"
  9. #include "sdio_sdcard.h"
  10. #include "w25qxx.h"
  11. #include "ff.h"
  12. #include "exfuns.h"
  13. #include "text.h"
  14. #include "rtc.h"
  15. #include "beep.h"
  16. #include "dht11.h"
  17. int main(void)
  18. {
  19. //        u32 fontcnt;
  20. //        u8 i,j;
  21. //        u8 fontx[2];//gbk碼
  22.     u8 key1;
  23.     u8 t=0;
  24.     u8 t1=0;
  25.                 u8 j=30;
  26.           u8 temperature;
  27.           u8 humidity;
  28.   BEEP_Init();
  29.         delay_init();                     //延時函數初始化
  30.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置中斷優先級分組為組2:2位搶占優先級,2位響應優先級
  31.         uart_init(115200);                 //串口初始化為115200
  32.          usmart_dev.init(72);                //初始化USMART
  33.          LED_Init();                                          //初始化與LED連接的硬件接口
  34.         KEY_Init();                                        //初始化按鍵
  35.         LCD_Init();        //初始化LCD
  36.   RTC_Init();
  37.   DHT11_Init();
  38.         W25QXX_Init();                                //初始化W25Q128
  39.          my_mem_init(SRAMIN);                //初始化內部內存池
  40.         exfuns_init();                                //為fatfs相關變量申請內存
  41.          f_mount(fs[0],"0:",1);                 //掛載SD卡
  42.          f_mount(fs[1],"1:",1);                 //掛載FLASH.
  43.         while(font_init())                         //檢查字庫
  44.         {
  45. //UPD:
  46.                 LCD_Clear(WHITE);                           //清屏
  47.                  POINT_COLOR=RED;                        //設置字體為紅色
  48.                 LCD_ShowString(30,50,200,16,16,"WarShip STM32");
  49.                 while(SD_Init())                        //檢測SD卡
  50.                 {
  51.                         LCD_ShowString(30,70,200,16,16,"SD Card Failed!");
  52.                         delay_ms(200);
  53.                         LCD_Fill(30,70,200+30,70+16,WHITE);
  54.                         delay_ms(200);
  55.                 }
  56.                 LCD_ShowString(30,70,200,16,16,"SD Card OK");
  57.                 LCD_ShowString(30,90,200,16,16,"Font Updating...");
  58.                 key1=update_font(20,110,16,"0:");//更新字庫
  59.                 while(key1)//更新失敗
  60.                 {
  61.                         LCD_ShowString(30,110,200,16,16,"Font Update Failed!");
  62.                         delay_ms(200);
  63.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  64.                         delay_ms(200);
  65.                 }
  66.                 LCD_ShowString(30,110,200,16,16,"Font Update Success!   ");
  67.                 delay_ms(1500);
  68.                 LCD_Clear(WHITE);//清屏
  69.         }
  70.         POINT_COLOR=RED;
  71.         Show_Str(150,50,200,24,"溫濕度檢測系統",24,0);
  72.          POINT_COLOR=BLUE;
  73.         Show_Str(60,350,240,24,"學號:",24,0);
  74.   Show_Str(60,310,200,24,"姓名\",24,0);
  75.         LCD_ShowString(60,240,200,24,24,"Temp:  C");
  76.          LCD_ShowString(60,270,200,24,24,"Humi:  %");
  77.         while(1)
  78.         {
  79.      if(t!=calendar.sec)
  80.                 {
  81.                         t=calendar.sec;
  82.                         LCD_ShowNum(60,130,calendar.w_year,4,24);
  83.                         LCD_ShowNum(120,130,calendar.w_month,2,24);
  84.                         LCD_ShowNum(150,130,calendar.w_date,2,24);
  85.                         switch(calendar.week)
  86.                         {
  87.                                 case 0:
  88.                                         Show_Str(60,210,200,24,"星期天     ",24,0);
  89.                                         break;
  90.                                 case 1:
  91.                                         Show_Str(60,210,200,24,"星期一  ",24,0);
  92.
  93.                                         break;
  94.                                 case 2:
  95.                                         Show_Str(60,210,200,24,"星期二 ",24,0);
  96. //                                        LCD_ShowString(60,210,200,24,24,"星期二  ");
  97.                                         break;
  98.                                 case 3:
  99.                                         Show_Str(60,210,200,24,"星期三 ",24,0);
  100. //                                        LCD_ShowString(60,210,200,24,24,"星期三 ");
  101.                                         break;
  102.                                 case 4:
  103.                                         Show_Str(60,210,200,24,"星期四  ",24,0);
  104. //                                        LCD_ShowString(60,210,200,24,24,"星期四 ");
  105.                                         break;
  106.                                 case 5:
  107.                                         Show_Str(60,210,200,24,"星期五  ",24,0);
  108. //                                        LCD_ShowString(60,210,200,24,24,"星期五   ");
  109.                                         break;
  110.                                 case 6:
  111.                                         Show_Str(60,210,200,24,"星期六 ",24,0);
  112. //                                        LCD_ShowString(60,210,200,24,24,"Saturday ");
  113.                                         break;
  114.                         }
  115.                         LCD_ShowNum(60,170,calendar.hour,2,24);
  116.                         LCD_ShowNum(90,170,calendar.min,2,24);
  117.                         LCD_ShowNum(120,170,calendar.sec,2,24);
  118.                         LED0=!LED0;
  119.                 }
  120.                 delay_ms(10);
  121.                                 LED0=!LED0;
  122.                 if(t1%10==0)                        //每100ms讀取一次
  123.                 {
  124.                         DHT11_Read_Data(&temperature,&humidity);        //讀取溫濕度值
  125.                         LCD_ShowNum(60+60,240,temperature,2,24);        //顯示溫度
  126.                         LCD_ShowNum(60+60,270,humidity,2,24);                //顯示濕度
  127.                 if(temperature>=j)
  128.                 {
  129.                         BEEP=~BEEP;
  130.                         delay_ms(20);
  131.                 }
  132.                 }
  133.                  delay_ms(10);
  134.                 t1++;
  135.                 if(t1==20)
  136.                 {
  137.                         t1=0;
  138.                         LED0=!LED0;
  139.                 }
  140.                         }
  141.                 }
溫濕度.rar (1.69 MB, 下載次數: 176)
