標題: AAL024-10E 電流傳感器 AG903B-07E DEMO [打印本頁]
作者: goodluck-ray    時間: 2018-11-16 09:53
.This Evaluation Board Includes
• Three AAL024-10E TDFN current sensors
• 2.5" x 2.75" (64 mm by 70 mm), 0.15" (3.8 mm) thick PCB
• Three current measurement configurations
• Sturdy screw connections
• Up to 40 amp AC or DC noncontact current measurement
AAL024-10E Features
• Wheatstone bridge analog outputs
• High sensitivity: 3.6 mV/V/Oe typical
• Wide linear range: 1.5 to 10.5 Oe; 15 Oe saturation
• 2.2 kΩ bridge resistance/1.1 kΩ output impedance for easy interface
• Low offset: 4 mV/V max.
• Low hysteresis: 2% max. for excellent repeatability
• Wide bandwidth: 500 kHz
• −50 to 125°C
• Ultraminiature 2.5 mm x 2.5 mm TDFN6 package
Advantages of Sensing Current Over Trace
• Negligible insertion resistance
• Usable for a wide current range
• Inherent electrical isolation
• AC or DC operation
AG903B-01.pdf
173.89 KB, 下載次數(shù): 2, 下載積分: 黑幣 -5
