怎樣用at89c51同時使用lcd1602和數碼管
九區三國殺
2018-11-12 18:28
zl2168
2018-11-14 08:30
把2個案例拼起來
123456m
2018-11-15 17:58
32個I/O可以或動態顯示也可以或加芯片邏輯芯片
九區三國殺
2018-11-15 21:28
123456m 發表于 2018-11-15 17:58
已經設計了lcd時鐘,數碼管代碼無法實現啊
mrming
2018-11-15 21:41
串口通信
九區三國殺
2018-11-16 12:40
mrming 發表于 2018-11-15 21:41
串口通信
我代碼如下:
#include<reg51.h>
unsigned char tab[]=" 23:58:48";
unsigned char code tab2[]="SZ30329 ";
#define lcdp P0
sbit rs=P3^5;
sbit rw=P3^6;
sbit en=P3^7;
sbit led=P1^7;
sbit s1=P1^0;
sbit s2=P1^1;
sbit s3=P1^2;
sbit RED=P3^4;
unsigned s=2;
unsigned flag=0;
unsigned char n,count,number;
char shi=23,fen=58,miao=55;
void delay(unsigned char z)
unsigned char i,j;
for(i=z;i>0;i--)
for(j=110;j>0;j--);
} //延時
void time_gai()
if(count==0)
s--;
void write_com(unsigned char com)//寫指令
rs=0;
rw=0;
en=0;
lcdp=com;
delay(5);
en=1;
delay(5);
en=0;
void write_date(unsigned char date)//寫數據
rs=1;
rw=0;
en=0;
lcdp=date;
delay(5);
en=1;
delay(5);
en=0;
void write_sj(unsigned add,unsigned date)
unsigned char shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+add);
write_date(shi+0x30);
write_date(ge+0x30);
void init() //初始化
write_com(0x38); //設置16x2顯示,5x7點陣,8位數據接口
write_com(0x06); //寫一個字符后地址指針自動加1
write_com(0x01); //顯示清零,數據指針清零
write_com(0x0c); //開顯示,不顯示光標
//write_com(0x08);
//write_com(0x0e);//光標開啟,但不閃爍
write_com(0x80); //顯示位置
for(n=0;n<10;n++)
write_date(tab[n]);
delay(1);
write_com(0x80+0x40+3);//第二行顯示
for(n=0;n<8;n++)
write_date(tab2[n]);
delay(1);
//定時器初始化
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TMOD=0x01;
EA=1;
ET0=1;
TR0=1;
void keyscan()
if(s1==0)
delay(5);
if(s1==0)
number++;
while(!s1);
if(number==1)
TR0=0;
write_com(0x80+9);
write_com(0x0f);//光標閃爍
if(number==2)
write_com(0x80+6);
if(number==3)
write_com(0x80+3);
if(number==4)
TR0=1;
number=0;
write_com(0x0c);//關閉光標
if(number!=0)
if(s2==0)
delay(5);
if(s2==0)
while(!s2);
if(number==1)
miao++;
if(miao==60)
miao=0;
write_sj(8,miao);
write_com(0x80+9);
if(number==2)
fen++;
if(fen==60)
fen=0;
write_sj(5,fen);
write_com(0x80+6);
if(number==3)
shi++;
led=!led;
if(shi==24)
shi=0;
write_sj(2,shi);
write_com(0x80+3);
if(s3==0)
delay(5);
if(s3==0)
while(!s3);
if(number==1)
miao--;
if(miao==-1)
miao=59;
write_sj(8,miao);
write_com(0x80+9);
if(number==2)
fen--;
if(fen==-1)
fen=59;
write_sj(5,fen);
write_com(0x80+6);
if(number==3)
shi--;
led=!led;
if(shi==-1)
shi=23;
write_sj(2,shi);
write_com(0x80+3);
RED=0;
init();
keyscan();
void time0() interrupt 1
count++;
if(count==20)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
write_sj(2,shi);
write_sj(5,fen);
write_sj(8,miao);
想加個倒計時秒表,四分鐘(不用調的),按下開關就工作,求大神幫寫下程序
