單片機(jī)驅(qū)動(dòng)ADC0809匯編語(yǔ)言源碼
[打印本頁(yè)]
WKN123
時(shí)間:
2018-11-9 12:02
ADC0809
實(shí)驗(yàn)參考程序:
1.
主程序
ORG 0000H
AJMP MAIN
ORG 000BH
AJMP T0SUB
ORG 0030H
MAIN: MOV SP, #5FH;設(shè)置堆棧
CLR A
MOV 30H, A;顯示緩沖區(qū)清零,30H單元存放電壓的個(gè)位BCD碼
MOV 31H, A
MOV 32H, A
MOV 33H, A;31H單元存放電壓的小數(shù)點(diǎn)后第三位BCD碼
MOV 34H, A
MOV 40H, A;讀取的電壓值單元清零,40H單元存放電壓的高兩位BCD碼
MOV 41H, A;41H單元存放電壓的低兩位 BCD碼
MOV R2, A;轉(zhuǎn)換結(jié)果單元清零
MOV TMOD, #01H;設(shè)置定時(shí)器T0每50ms中斷一次
MOV TH0, #4CH
MOV TL0, #00H
SETB ET0
SETB EA
SETB TR0
MOV P2, #0F0H; 關(guān)顯示器并使ADC0809未選
LOOP: MOV A, R2;根據(jù)轉(zhuǎn)換結(jié)果查表得到對(duì)應(yīng)的電壓值
MOV R3, #00H;R3R4存放2xR2
CLR C
RLC A
MOV R4, A
MOV A, R3
RLC A
MOV R3, A
MOV DPTR,#VTAB;指向電壓表首地址
MOV A, R4
ADD A, DPL
MOV DPL, A
MOV A, R3
ADDC A, DPH
MOV DPH, A
CLR A
MOVC A, @A+DPTR
MOV R0, #40H
MOV @R0, A
INC DPTR;讀取電壓值的第二個(gè)字節(jié)
CLR A
MOVC A, @A+DPTR
INC R0
MOV @R0, A
ACALL DISPLAY;調(diào)用顯示子程序
ACALL DELAY1ms;調(diào)用延時(shí)子程序
SJMP LOOP
顯示子程序:
DISPLAY: MOV R1, #30H;拆分BCD碼
MOV R0, #40H;指向讀取的電壓值的單元
MOV A, @R0
ANL A, #0F0H
SWAP A
MOV @R1, A
INC R1
MOV A, @R0
ANL A, #0FH
MOV @R1, A
INC R0;拆分第二個(gè)字節(jié)的BCD碼
INC R1
MOV A, @R0
ANL A, #0F0H
SWAP A
MOV @R1, A
INC R1
MOV A, @R0
ANL A, #0FH
MOV @R1, A
MOV P2, #0F0H;關(guān)顯示器,P2口的低四位控制四位數(shù)碼管的顯示位置
MOV DPTR, #SEGTAB;指向段碼表
MOV R1, #30H
MOV A, @R1
MOVC A, @A+DPTR
MOV P1, A;顯示個(gè)位電壓值
ANL P1,#7FH;點(diǎn)亮小數(shù)點(diǎn)
MOV P2, #0F1H;P2.0置位,顯示個(gè)位數(shù)碼
ACALL DELAY1ms;延時(shí)1ms
MOV P2, #0F0H;關(guān)閉顯示器
INC R1
MOV A, @R1;顯示小數(shù)點(diǎn)后第一位電壓值
MOVC A, @A+DPTR
MOV P1, A
MOV P2, #0F2H
ACALL DELAY1ms
MOV P2, #0F0H
INC R1;顯示小數(shù)點(diǎn)后第二位電壓值
MOV A, @R1
MOVC A, @A+DPTR
MOV P1, A
MOV P2, #0F4H
ACALL DELAY1ms
MOV P2, #0F0H
INC R1;顯示小數(shù)點(diǎn)后第三位電壓值
MOV A, @R1
MOVC A, @A+DPTR
MOV P1, A
MOV P2, #0F8H
ACALL DELAY1ms
RET
1ms延時(shí)子程序:
DELAY1ms: MOV R5, #02H
L1: MOV R6, #0F0H
DJNZ R6, $
DJNZ R5, L1
RET
定時(shí)采樣中斷服務(wù)子程序:
T0SUB: PUSH ACC;保護(hù)現(xiàn)場(chǎng)
PUSH 00H
MOV TH0, #4CH;恢復(fù)初值50ms
MOV TL0, #00H
CLR P2.7;啟動(dòng)ADC0809的0通道轉(zhuǎn)換(A15)
MOV R0, #0F0H
MOVX @R0, A
NOP
NOP
NOP
NOP
JNB P3.0, $;轉(zhuǎn)換結(jié)束嗎?
MOVX A, @R0;讀取轉(zhuǎn)換結(jié)果
MOV R2, A
SETB P2.7;ADC0809退出選中
POP 00H;恢復(fù)現(xiàn)場(chǎng)
POP ACC
RETI
SEGTAB: DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H;段碼表
VTAB: DB 00H,00H,00H,20H,00H,39H,00H,59H;電壓值表格
DB 00H,78H,00H,98H,01H,12H,01H,38H
DB 01H,56H,01H,76H,01H,95H,02H,15H
DB 02H,34H,02H,54H,02H,80H,03H,00H
DB 03H,20H,03H,40H,03H,60H,03H,80H
DB 03H,91H,04H,10H,04H,30H,04H,49H
DB 04H,69H,04H,88H,05H,08H,05H,27H
DB 05H,47H,05H,66H,05H,86H,06H,05H
DB 06H,25H,06H,45H,06H,64H,06H,84H
DB 07H,03H,07H,23H,07H,42H,07H,62H
DB 07H,81H,08H,01H,08H,20H,08H,40H
DB 08H,59H,08H,79H,08H,98H,09H,18H
DB 09H,38H,09H,57H,09H,77H,09H,96H
DB 10H,16H,10H,35H,10H,55H,10H,74H
DB 10H,94H,11H,13H,11H,33H,11H,52H
DB 11H,72H,11H,91H,12H,11H,12H,30H
DB 12H,50H,12H,70H,12H,89H,13H,09H
DB 13H,28H,13H,48H,13H,67H,13H,87H
DB 14H,06H,14H,26H,14H,45H,14H,65H
DB 14H,84H,15H,04H,15H,23H,15H,43H
DB 15H,63H,15H,82H,16H,02H,16H,21H
DB 16H,41H,16H,60H,16H,80H,16H,99H
DB 17H,19H,17H,38H,17H,58H,17H,77H
DB 17H,97H,18H,16H,18H,36H,18H,55H
DB 18H,75H,18H,95H,19H,14H,19H,34H
DB 19H,53H,19H,73H,19H,92H,20H,12H
DB 20H,31H,20H,51H,20H,70H,20H,90H
DB 21H,09H,21H,29H,21H,48H,21H,68H
DB 21H,88H,22H,07H,22H,27H,22H,46H
DB 22H,66H,22H,85H,23H,05H,23H,24H
DB 23H,44H,23H,63H,23H,83H,24H,02H
DB 24H,22H,24H,41H,24H,61H,24H,80H
DB 25H,00H,25H,19H,25H,39H,25H,59H
DB 25H,78H,25H,98H,26H,17H,26H,37H
DB 26H,56H,26H,76H,26H,95H,27H,15H
DB 27H,34H,27H,54H,27H,73H,27H,93H
DB 28H,13H,28H,32H,28H,52H,28H,71H
DB 28H,91H,29H,10H,29H,30H,29H,49H
DB 29H,69H,29H,88H,30H,08H,30H,27H
DB 30H,47H,30H,66H,30H,86H,31H,05H
DB 31H,25H,31H,45H,31H,64H,31H,83H
DB 32H,03H,32H,23H,32H,42H,32H,62H
DB 32H,81H,33H,01H,33H,20H,33H,40H
DB 33H,59H,33H,79H,33H,98H,34H,18H
DB 34H,38H,34H,57H,34H,77H,34H,96H
DB 35H,16H,35H,35H,35H,55H,35H,75H
DB 35H,94H,36H,13H,36H,33H,36H,52H
DB 36H,72H,36H,91H,37H,11H,37H,30H
DB 37H,50H,37H,70H,37H,89H,38H,09H
DB 38H,28H,38H,48H,38H,67H,38H,88H
DB 39H,06H,39H,26H,39H,45H,39H,65H
DB 39H,84H,40H,04H,40H,23H,40H,43H
DB 40H,63H,40H,82H,41H,02H,41H,21H
DB 41H,41H,41H,60H,41H,80H,41H,99H
DB 42H,19H,42H,38H,42H,58H,42H,77H
DB 42H,97H,43H,16H,43H,36H,43H,55H
DB 43H,75H,43H,95H,44H,14H,44H,34H
DB 44H,53H,44H,73H,44H,92H,45H,12H
DB 45H,31H,45H,51H,45H,70H,45H,89H
DB 46H,09H,46H,29H,46H,48H,46H,68H
DB 46H,88H,47H,07H,47H,27H,47H,46H
DB 47H,66H,47H,85H,48H,05H,48H,24H
DB 48H,44H,48H,63H,48H,83H,49H,02H
DB 49H,22H,49H,41H,49H,61H,49H,80H
END
admin
時(shí)間:
2018-11-9 15:27
補(bǔ)全原理圖或者詳細(xì)說(shuō)明一下電路連接即可獲得100+黑幣
