為什么P1的第一個燈不亮,哪兒錯了。
#include<reg52.h>
sbit sda=P2^0;
sbit scl=P2^1;
uchar a;
void delay1(uchar x)
uchar a,b;
for(a=x;a>0;a--)
for(b=1000;b>0;b--);
void delay()
void start()
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop()
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void init()
sda=1;
delay();
scl=1;
delay();
void respons()
uchar i;
scl=1;
delay();
while((sda==1)&&(i<250))i++;
scl=0;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay();
sda=CY;
delay();
scl=1;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,n,j;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
j=sda;
n=(n<<1)|j;
scl=0;
delay();
return n;
sda=1;
delay();
init();
start();
write_byte(0xa0);
respons();
write_byte(3);
respons();
write_byte(0xfe);
respons();
stop();
delay1(100);
start();
write_byte(0xa0);
respons();
write_byte(3);
respons();
start();
write_byte(0xa1);
respons();
a=read_byte();
stop();
P1=a;
while(1);
哪兒錯了啊,sda,scl地址沒錯
好吧,總算有人回了,即使只是搭訕。。
把倒數第十七行,OXFE改成OXFF,應該就是P1口所有得等都亮
