標(biāo)題: 制作自己的wifi 開關(guān) ESP8266 lua開啟UDP通信 [打印本頁(yè)]
作者: 沙漠之痕    時(shí)間: 2018-11-6 22:48
本帖最后由 沙漠之痕 于 2018-11-7 12:50 編輯
一. 模塊連接路由器開啟監(jiān)聽端口
1. 模塊開啟監(jiān)聽8080 端口:
init.lua文件:
tmr.alarm(0,4000,0,function()
    dofile("udp.lua")
end)
init.lua文件結(jié)束
udp.lua文件:
ListenPort = 8080
wifi.setmode(wifi.STATIONAP)
stacfg={}
stacfg.ssid="qqqqq"
stacfg.pwd="11223344"
wifi.sta.config(stacfg)
wifi.sta.autoconnect(1)
UdpSocket = net.createUDPSocket()
UdpSocket:listen(ListenPort)
UdpSocket:on("receive", function(socket, data, port, ip)
         print("\r\nport:"..port.."---ip:"..ip.."\r\n")
         ConnectPort = port
         ConnectIP = ip
        uart.write(0,data)
end)
uart.on("data",0,function(data)
    if UdpSocket~=nil then
        if ConnectPort~=0 then
            UdpSocket:send(ConnectPort, ConnectIP, data)
        end
    end
end,0)
------------------Got IP -----------------------------------------
printip = 0
wifi.eventmon.register(wifi.eventmon.STA_DISCONNECTED, function(T)
    printip = 0
end)
wifi.eventmon.register(wifi.eventmon.STA_GOT_IP, function(T)
   if printip == 0 then
      print("+IP "..T.IP)
   end
   printip = 1
end)
------------------END Got IP -------------------------------------
udp.lua文件結(jié)束
2. 通過手機(jī)端發(fā)送”open”打開繼電器; 發(fā)送”close”關(guān)閉繼電器
init.lua文件:
RELAY_Pin = 1
gpio.mode(RELAY_Pin, gpio.OUTPUT)
gpio.write(RELAY_Pin,0)
    dofile("udp.lua")
end)
init.lua文件結(jié)束
udp.lua文件:
UdpReceData = ""
UdpReceDataCnt = 0
UdpReceDataStat = false
ListenPort = 8080
stacfg={}
stacfg.ssid="qqqqq"
         ConnectPort = port
         ConnectIP = ip
         UdpReceData = UdpReceData..data
         UdpReceDataCnt = 0
         UdpReceDataStat = true
end)
tmr.alarm(1,10,1,function()
    if UdpReceDataStat == true then
        UdpReceDataCnt = UdpReceDataCnt+1
        if UdpReceDataCnt >=10 then
            uart.write(0,UdpReceData)
            if UdpReceData=="open" then gpio.write(RELAY_Pin,1) end
            if UdpReceData=="close" then gpio.write(RELAY_Pin,0) end
            UdpReceData = ""
            UdpReceDataCnt = 0
        end
    end
end)
        end
    end
end,0)
printip = 0
    printip = 0
end)
      print("+IP "..T.IP)
   end
   printip = 1
end)
udp.lua文件結(jié)束
手機(jī)端發(fā)送”open”開繼電器
手機(jī)端發(fā)送”close”開繼電器
接收模塊通過UDP發(fā)送出的數(shù)據(jù)
二 . 模塊連接路由器向8080端口發(fā)送數(shù)據(jù)(客戶端模式)
init.lua文件:
    dofile("udp.lua")
end)
init.lua文件結(jié)束
udp.lua文件:
stacfg={}
stacfg.ssid="qqqqq"
ConnectIP = "192.168.0.103"
ConnectPort = 8000
        uart.write(0,data)
end)
    end
end,0)
printip = 0
    printip = 0
end)
      print("+IP->"..T.IP)
   end
   printip = 1
end)
udp.lua文件結(jié)束
三 . 模塊開放熱點(diǎn)監(jiān)聽端口
1. 模塊開放熱點(diǎn)建立UDP監(jiān)聽端口通信
init.lua文件:
    dofile("udp.lua")
end)
init.lua文件結(jié)束
udp.lua文件:
wifi.setmode(wifi.SOFTAP)
apcfg={}
apcfg.ssid="ESP_udp"
apcfg.pwd="11223344"
wifi.ap.config(apcfg)
UdpSocket:listen(8080)
         ConnectPort = port
         ConnectIP = ip
        uart.write(0,data)
end)
        end
    end
end,0)
udp.lua文件結(jié)束
手機(jī)端與模塊間發(fā)送數(shù)據(jù)
四 .模塊開放熱點(diǎn)建立UDP通信向某個(gè)端口發(fā)送數(shù)據(jù)(客戶端模式)
1.
init.lua文件:
    dofile("udp.lua")
end)
init.lua文件結(jié)束
udp.lua文件:
apcfg={}
         ConnectPort = port
         ConnectIP = ip
        uart.write(0,data)
end)
UdpConnectIP = "192.168.4.2"
UdpConnectPort = 8000
            UdpSocket:send(UdpConnectPort, UdpConnectIP, data)
        end
    end
end,0)
udp.lua文件結(jié)束
UDP間發(fā)送數(shù)據(jù);
需要模塊下對(duì)其發(fā)送數(shù)據(jù),在手機(jī)端建立UDP通信;手機(jī)端會(huì)顯示模塊的ip和端口然后手機(jī)端可以向模塊發(fā)送數(shù)據(jù)
2. 手機(jī)端通過發(fā)送”open”打開繼電器; 發(fā)送”close”關(guān)閉繼電器
init.lua文件:
RELAY_Pin = 1
    dofile("udp.lua")
end)
init.lua文件結(jié)束
Udp.lua文件:
UdpReceData = ""
UdpReceDataCnt = 0
apcfg={}
         ConnectPort = port
         ConnectIP = ip
         UdpReceDataCnt = 0
         uart.write(0,data)
end)
        if UdpReceDataCnt >= 10 then
            UdpReceData = ""
            UdpReceDataCnt = 0
        end
    end
end)
        end
    end
end,0)
udp.lua文件結(jié)束
連接模塊熱點(diǎn), 創(chuàng)建手機(jī)udp客戶端 為什么要讓模塊建立監(jiān)聽端口呢; 因?yàn)槟K要去向服務(wù)端發(fā)送數(shù)據(jù)才可以得到對(duì)方的ip和端口,那么要控制繼電器不能先讓模塊給你發(fā)送數(shù)據(jù)吧?而且每次的連接端口都是變化的; 所以讓模塊去監(jiān)聽端口,ip和端口都是固定的; 這樣也方便控制
ESP8266 udp通信 lua源碼.zip (3.08 KB, 下載次數(shù): 20)
交流QQ:1813763867
QQ群:235371864
