液晶1602數字時鐘顯示屏
wangxueming
2018-11-6 19:48
液晶1602數字時鐘顯示屏
#include<reg51.h>
#define ucharunsigned char
#define uintunsigned int
sbit lcdrs=P2^0;//定義1602 液晶RS端
sbit lcdrw=P2^1;
sbitlcden=P2^2; //定義1602液晶lcden端
sbits1=P1^0; //定義按鍵--功能鍵
sbit s2=P1^1; //定義按鍵-增加鍵
sbit s3=P1^2; //減小
sbit s4=P1^3; //定義按鍵-鬧鐘鍵
sbitbeep=P2^4;//定義蜂鳴器
sbit led=P2^3;//定義LED燈端
ucharcount,s1num,s4num;
charyear,month,day,week,miao,shi,fen,pshi;
uchar codetable[]=" 20 - - ";//定義初始上電時液晶默認顯示狀態
void delay(uintz) //延時函數
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void zhuanhuan()
if(shi==0)
pshi=12;
if(shi<=12&&shi>=1)
pshi=shi;
if(shi>12)
pshi=shi-12;
void di()//蜂鳴器發生函數
beep=0;
delay(300);
beep=1;
delay(300);
void write_com(ucharcom) //液晶寫命令
lcdrs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
voidwrite_date(uchar date) //液晶寫數據函數
lcdrs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void _shi()//寫 'AM"、"PM"函數
if(shi>=12)
write_com(0x80+0x40+1);//寫出"PM"
write_date('P');
write_date('M');
write_com(0x80+0x40+1);//寫出"AM"
write_date('A');
write_date('M');
voidwrite_ymd(uchar add1,uchar date1)
uchar shi,ge;
shi=date1/10;//分解-一個 2位數的十位和個位
ge=date1%10;
write_com(0x80+add1);//設置 顯示位置
write_date(0x30+shi); //送去液晶顯示十位
write_date(0x30+ge); //送去液晶顯示各位
voidwrite_sfm(uchar add,uchar date) //寫時分秒函數
uchar shi,ge;
shi=date/10;//分解一一個2位數的十位和個位
ge=date%10;
write_com(0x80+0x40+add);// 設置顯示位置
write_date(0x30+shi);//送 去液晶顯示十位
write_date(0x30+ge); //送 去液晶顯示個位
voidwrite_week(char week) //與液晶星期顯示函數
write_com(0x80+12);
switch(week)
case 1: write_date('M');delay(5);
write_date('O');delay(5);
write_date('N');
break;
case 2: write_date('T');delay(5);
write_date('U' );delay(5);
write_date('E');
break;
case 3: write_date('W');delay(5);
write_date('E' );delay(5);
write_date('D');break;
case 4: write_date('T');delay(5);
write_date('H');delay(5);
write_date('U');
break;
case 5: write_date('F');delay(5);
write_date('R');delay(5);
write_date('I');
break;
case 6: write_date('S');delay(5);
write_date('A');delay(5);
write_date('T');
break;
case 7: write_date('S');delay(5);
write_date('U');delay(5);
write_date('N');
break;
void writeym()
day=1;
month++;
if(month==13)
month=1;
year++;
if(year==100)
year=0;
write_ymd(3,year);// 若變化則重新寫入
write_ymd(6,month);//月 若變化則重新寫入
void init()//初始化函數
uchar num;
lcden=0;
year=13;//初始化種變量值
month=6;
day=21;
week=5;
shi=13;
fen=59;
miao=58;
count=0;
s1num=0;
s4num=0;
write_com(0x38);//初始化1602液晶
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);// 設置顯示初始坐標
for(num=0;num<15;num++)//顯示年月日星期
write_date(table[num]);
delay(5);
delay(5);
write_com(0x80+0x40+6);//與出時間顯示部分的兩個".”
write_date(':');
delay(5);
write_com(0x80+0x40+9);
write_date(':');
delay(5);
write_week(week);
write_ymd(3,year);//分 別送去液晶顯示
write_ymd(6,month);
write_ymd(9,day);
write_sfm(10,miao);//分別送去液晶顯示
write_sfm(7,fen);
write_sfm(4,shi);
TMOD=0x01;//設置定時器0 I.作模式1
TH0=(65536-50000)/256;//定時器裝初值
TL0=(65536-50000)%256;
EA=1; //開總中斷
ET0=1; //開定時器0中斷
TR0=1; //啟動定時器 0
void keyscan()//按鍵掃描函數
if(s1==0)
delay(5);
if(s1==0) //確認按鍵被按下
s1num++;//功能鍵按下次數記錄
while(!s1);//釋放確認
if(s1num==1)//
TR0=0; //關閉定時 器
write_com(0x80+3);//光標定位到年位置
write_com(0x0f); //光標開始閃爍
if(s1num==2)//第二次按下光標閃爍定位到月位置
write_com(0x80+6);
if(s1num==3)//第三次按下光標閃爍定位到日位置{
write_com(0x80+9);
if(s1num==4)//第四次按下光標閃爍定位到星期位置
write_com(0x80+12);
if(s1num==7)//第七次按下光標閃爍定位到秒位置
write_com(0x80+0x40+10);
if(s1num==6)//第六次按下光標閃爍定位到分位置
write_com(0x80+0x40+7);
if(s1num==5)//第五次按下光標閃爍定位到時位置
write_com(0x80+0x40+4);
if(s1num==8)//第七次按下{
s1num=0;//記錄按鍵數清零
write_com(0x0c);//取消光標閃爍
TR0=1; //啟動定時 器使時鐘開始走
if(s1num!=0)//只有功能鍵被按下后,增加和減小鍵才有效{
if(s2==0)
delay(5);
if(s2==0)//增加鍵確認被按下
while(!s2);//按鍵釋放
if(s1num==1)//若功能鍵第1次按下
year++;// 則調整年加1
if(year==100)//若滿100后將清零
year=0;
write_ymd(3,year);//每調節-次送液晶顯示-下
write_com(0x80+3);//顯示位 置重新回到調節處
if(s1num==2)// 若功能鍵第二次按下
month++;//則調整月加1
if(month==13)//若滿12后將置:,
month=1;
write_ymd(6,month);//每調節次送液晶顯示一 下
write_com(0x80+6);//顯示位 置重新回到調節處
if(s1num==3)//若功能鍵第三次按下
day++;//則調整日加1
if(year%4==0&&month==2)
if(day==30)//若滿29后將置1
day=1;
if(year%4!=0&&month==2)
if(day==29)//若滿28后將置1
day=1;
if(month!=2&&month!=4&&month!=6&&month!=9&&month!=11)
if(day==32)//若滿31后將置1
day=1;
if(month==4||month==6||month==9||month==11)
if(day==31)//若滿30后將置1
day=1;
write_ymd(9,day);//每調節-次送液晶顯示-下
write_com(0x80+9);//顯示位置重新回到調節處
if(s1num==4)//若功能鍵第四次按下
week++;//則調整星期加1
if(week==8)//若滿8后將置一
week=1;
write_week(week);//每調節-次送液晶顯示一下
write_com(0x80+12);//顯示位置重新回到調節處
if(s1num==7)//若功能鍵第七次按下
miao++;//則調整秒加一
if(miao==60)//若滿60后將清零
miao=0;
write_sfm(10,miao);//每調節一次送液晶顯示 : ." 下
write_com(0x80+0x40+10);//顯示位置重新回到調節處
if(s1num==6)//巖功能鍵第2次按下
fen++;//則調整分鐘加1
if(fen==60)//若滿60后將清零
fen=0;
write_sfm(7,fen);//每調節次送液晶顯示 . 下
write_com(0x80+0x40+7);//顯示位置重新回到調節處
if(s1num==5)//巖功能鍵第5次按下
shi++;
if(shi==24)//若滿24后將清零
shi=0;
if(s4num==0)
write_sfm(4,shi);//每調節一 次送液 晶顯示一下
write_com(0x80+0x40+4);//顯示位置重新回到調節處
if(s4num==1)
zhuanhuan();
_shi();
write_sfm(4,pshi);//每調節 - 次送液晶顯示. 下
write_com(0x80+0x40+4);// 顯示位置重新回到調節處
if(s3==0)
delay(5);
if(s3==0)//確認減小鍵被按下
while(!s3);//按鍵釋放
year--; //則調整秒減一
if(year==-1)//若減到負數則將其重新設置為99
year=99;
write_ymd(3,year);//每調節 -次送液晶顯示- 下
if(s1num==2)//若功能鍵第二次按下
month--;//則調整分鐘減1
if(month==0);//若減到負數則將其重新設置為59
month=12;
write_ymd(6,month);//每調節次送液晶顯示 --下
if(s1num==3)//若功能鍵第_次按下
day--;//則調整日加1
if(day==0)//若滿29后置一
day=29;
if(day==0)//若滿28后置一
day=28;
if(day==0)//若滿31后置一
day=31;
if(day==0)//若滿30后置一
day=30;
write_ymd(9,day);//每調節一次送液晶屏顯示一下
write_com(0x80+9);//顯示位 置重新回到調節處
if(s1num==4)//若功能鍵第二次被按下
week--;//則調整小時減1
if(week==0)//若減到負數則將其重新設置為23
week=7;
write_week(week);//每調節 次送液晶顯示一 下
write_com(0x80+12);// 顯示位置重新回到調節處
if(s1num==7)//若功能鍵第-次按下
miao--;//則調整秒誠1
if(miao==-1)//若減到負數則將其重新設置為59
miao=59;
write_sfm(10,miao);//每調節一次送液晶顯示- - 下
write_com(0x80+0x40+10);// 顯示位置重新回到調節處
if(s1num==6)//若功能鍵第2次按下
fen--;//則調整分鐘減1
if(fen==-1)//若減到負數則將其重新設置為59
fen=59;
write_sfm(7,fen);//每調節一次送液晶顯示- 下
write_com(0x80+0x40+7);// 顯示位置重新回到調節處
if(s1num==5)//若功能鍵第二次按下
shi--;
if(shi==-1)//若滿24后將清零
shi=23;
if(s4num==0)
write_sfm(4,shi);//每調節一 次送液 晶顯示- 下
if(s4num==1)
zhuanhuan();
_shi();
if(s1num==0)
if(s4==0)
delay(5);
if(s4==0)// 確認功能鍵被按下
s4num++;//功能鍵按下次數記錄
while(!s4);//釋放確認
if(s4num==1)//第一次被按下
zhuanhuan();
_shi();
write_sfm(4,pshi);
if(s4num==2)//第二次按下{
s4num=0;//記錄按鍵數清零
write_date(' ');
write_date(' ');
write_sfm(4,shi);
init();//首先初始化各數據
while(1)//進入主程序大循環
keyscan();//不停的檢測按鍵是否被按下
if(s1num!=0)
led=0;
led=miao%2;
if((shi>7&&shi<23)&&(fen==0)&&(miao==0) )
di();
void timer0()interrupt 1 //定時器0中斷服務程序
TH0=(65536-50000)/256;//再次裝定時器初值
count++; //中斷次數累加
if(count==20)//20次50毫秒為1秒
count=0;
miao++;
if(miao==60)//秒加到60則進位分鐘
miao=0;//同時秒數清零
fen++;
if(fen==60)//分鐘加到60則進位小時
fen=0;//同時分鐘數清零
shi++;
if(shi==24)//小時加到24則小時清零
shi=0;
week++;
if(week==8)
week=1;
write_week(week);//星期若變化則重新寫入
day++;
if(year%4==0&&month==2)//判斷是否為閏年的2月
if(day==30)
writeym();
write_ymd(9,day);//日若變化則重新寫入
if(year%4!=0&&month==2)//判斷是否為平年的2月
if(day==29)
writeym();
if(day==32)
writeym();
write_ymd(9,day);//ri若變化則重新寫入
if(day==31)
writeym();
write_ymd(9,day);//H 若變化則重新寫入
if(s4num==1)
zhuanhuan();
_shi();
write_sfm(4,pshi);//12 小時制小時若變化則重新寫入
else write_sfm(4,shi);//24 小時制小時若變化則重新寫入
write_sfm(7,fen);//分鐘若變化則重新寫入
write_sfm(0,miao);//秒若變化則重新寫入
