mpu9250 9軸傳感器測試源碼(STM32串口輸出)
kk123456789
2018-11-6 17:10
利用IIC通信讀取MPU9250傳感器原始數據
// GY-9250 GY-9150 IIC測試程序
// 使用單片機STM32F103C8T6
// 晶振:8.00M
// 編譯環境 Keil uVision4
// 與模塊連接 GPIOB6->SCL GPIOB7->SDA
// 使用:STM32F103C8T6串口1連接電腦
// 電腦串口助手顯示,波特率:115200
#include "stm32f10x_lib.h"
#include <math.h> //Keil library
ErrorStatus HSEStartUpStatus;
// 定義MPU9250內部地址
#define SMPLRT_DIV 0x19 //陀螺儀采樣率,典型值:0x07(125Hz)
#define CONFIG 0x1A //低通濾波頻率,典型值:0x06(5Hz)
#define GYRO_CONFIG 0x1B //陀螺儀自檢及測量范圍,典型值:0x18(不自檢,2000deg/s)
#define ACCEL_CONFIG 0x1C //加速計自檢、測量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define ACCEL_XOUT_H 0x3B
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
#define TEMP_OUT_H 0x41
#define TEMP_OUT_L 0x42
#define GYRO_XOUT_H 0x43
#define GYRO_XOUT_L 0x44
#define GYRO_YOUT_H 0x45
#define GYRO_YOUT_L 0x46
#define GYRO_ZOUT_H 0x47
#define GYRO_ZOUT_L 0x48
#define MAG_XOUT_L 0x03
#define MAG_XOUT_H 0x04
#define MAG_YOUT_L 0x05
#define MAG_YOUT_H 0x06
#define MAG_ZOUT_L 0x07
#define MAG_ZOUT_H 0x08
#define PWR_MGMT_1 0x6B //電源管理,典型值:0x00(正常啟用)
#define WHO_AM_I 0x75 //IIC地址寄存器(默認數值0x68,只讀)
#define GYRO_ADDRESS 0xD0 //陀螺地址
#define MAG_ADDRESS 0x18 //磁場地址
#define ACCEL_ADDRESS 0xD0
unsigned char TX_DATA[4]; //顯示據緩存區
unsigned char BUF[10]; //接收數據緩存區
char test=0; //IIC用到
short T_X,T_Y,T_Z,T_T; //X,Y,Z軸,溫度
/*模擬IIC端口輸出輸入定義*/
#define SCL_H GPIOB->BSRR = GPIO_Pin_6
#define SCL_L GPIOB->BRR = GPIO_Pin_6
#define SDA_H GPIOB->BSRR = GPIO_Pin_7
#define SDA_L GPIOB->BRR = GPIO_Pin_7
#define SCL_read GPIOB->IDR & GPIO_Pin_6
#define SDA_read GPIOB->IDR & GPIO_Pin_7
/* 函數申明 -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void USART1_Configuration(void);
void WWDG_Configuration(void);
void Delay(u32 nTime);
void Delayms(vu32 m);
/* 變量定義 ----------------------------------------------*/
void DATA_printf(uchar *s,short temp_data)
if(temp_data<0){
temp_data=-temp_data;
*s='-';
else *s=' ';
*++s =temp_data/100+0x30;
temp_data=temp_data%100; //取余運算
*++s =temp_data/10+0x30;
temp_data=temp_data%10; //取余運算
*++s =temp_data+0x30;
* Function Name : I2C_GPIO_Config
* Description : Configration Simulation IIC GPIO
* Input : None
* Output : None
* Return : None
void I2C_GPIO_Config(void)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
* Function Name : I2C_delay
* Description : Simulation IIC Timing series delay
* Input : None
* Output : None
* Return : None
void I2C_delay(void)
u8 i=30; //這里可以優化速度 ,經測試最低到5還能寫入
while(i)
i--;
void delay5ms(void)
int i=5000;
while(i)
i--;
* Function Name : I2C_Start
* Description : Master Start Simulation IIC Communication
* Input : None
* Output : None
* Return : Wheather Start
bool I2C_Start(void)
SDA_H;
SCL_H;
I2C_delay();
if(!SDA_read)return FALSE; //SDA線為低電平則總線忙,退出
SDA_L;
I2C_delay();
if(SDA_read) return FALSE; //SDA線為高電平則總線出錯,退出
SDA_L;
I2C_delay();
return TRUE;
* Function Name : I2C_Stop
* Description : Master Stop Simulation IIC Communication
* Input : None
* Output : None
* Return : None
void I2C_Stop(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SDA_H;
I2C_delay();
* Function Name : I2C_Ack
* Description : Master Send Acknowledge Single
* Input : None
* Output : None
* Return : None
void I2C_Ack(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
* Function Name : I2C_NoAck
* Description : Master Send No Acknowledge Single
* Input : None
* Output : None
* Return : None
void I2C_NoAck(void)
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
* Function Name : I2C_WaitAck
* Description : Master Reserive Slave Acknowledge Single
* Input : None
* Output : None
* Return : Wheather Reserive Slave Acknowledge Single
bool I2C_WaitAck(void) //返回為:=1有ACK,=0無ACK
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
SCL_L;
I2C_delay();
return FALSE;
SCL_L;
I2C_delay();
return TRUE;
* Function Name : I2C_SendByte
* Description : Master Send a Byte to Slave
* Input : Will Send Date
* Output : None
* Return : None
void I2C_SendByte(u8 SendByte) //數據從高位到低位//
u8 i=8;
while(i--)
SCL_L;
I2C_delay();
if(SendByte&0x80)
SDA_H;
SDA_L;
SendByte<<=1;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
* Function Name : I2C_RadeByte
* Description : Master Reserive a Byte From Slave
* Input : None
* Output : None
* Return : Date From Slave
unsigned char I2C_RadeByte(void) //數據從高位到低位//
u8 i=8;
u8 ReceiveByte=0;
SDA_H;
while(i--)
ReceiveByte<<=1;
SCL_L;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
ReceiveByte|=0x01;
SCL_L;
return ReceiveByte;
//ZRX
//單字節寫入*******************************************
bool Single_Write(unsigned char SlaveAddress,unsigned char REG_Address,unsigned char REG_data) //void
if(!I2C_Start())return FALSE;
I2C_SendByte(SlaveAddress); //發送設備地址+寫信號//I2C_SendByte(((REG_Address & 0x0700) >>7) | SlaveAddress & 0xFFFE);//設置高起始地址+器件地址
if(!I2C_WaitAck()){I2C_Stop(); return FALSE;}
I2C_SendByte(REG_Address ); //設置低起始地址
I2C_WaitAck();
I2C_SendByte(REG_data);
I2C_WaitAck();
I2C_Stop();
delay5ms();
return TRUE;
//單字節讀取*****************************************
unsigned char Single_Read(unsigned char SlaveAddress,unsigned char REG_Address)
{ unsigned char REG_data;
I2C_SendByte(SlaveAddress); //I2C_SendByte(((REG_Address & 0x0700) >>7) | REG_Address & 0xFFFE);//設置高起始地址+器件地址
if(!I2C_WaitAck()){I2C_Stop();test=1; return FALSE;}
I2C_SendByte((u8) REG_Address); //設置低起始地址
I2C_WaitAck();
I2C_Start();
I2C_SendByte(SlaveAddress+1);
I2C_WaitAck();
REG_data= I2C_RadeByte();
I2C_NoAck();
I2C_Stop();
//return TRUE;
return REG_data;
** 函數名稱 : RCC_Configuration(void)
** 函數功能 : 時鐘初始化
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
/* Enable GPIOA, GPIOB, GPIOC, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB , ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD , ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOF , ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG | RCC_APB2Periph_AFIO , ENABLE);
** 函數名稱 : GPIO_Configuration(void)
** 函數功能 : 端口初始化
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE );
/* Configure USART1 Tx (PA.09) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; // 選中管腳9
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 復用推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; // 最高輸出速率50MHz
GPIO_Init(GPIOA, &GPIO_InitStructure); // 選擇A端口
/* Configure USART1 Rx (PA.10) as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //選中管腳10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空輸入
GPIO_Init(GPIOA, &GPIO_InitStructure); //選擇A端口
** 函數名稱 : USART1_Configuration(void)
** 函數功能 : 串口1初始化
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 |RCC_APB2Periph_USART1, ENABLE );
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; // 時鐘低電平活動
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; // 時鐘低電平
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; // 時鐘第二個邊沿進行數據捕獲
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; // 最后一位數據的時鐘脈沖不從SCLK輸出
/* Configure the USART1 synchronous paramters */
USART_ClockInit(USART1, &USART_ClockInitStructure); // 時鐘參數初始化設置
USART_InitStructure.USART_BaudRate = 115200; // 波特率為:115200
USART_InitStructure.USART_WordLength = USART_WordLength_8b; // 8位數據
USART_InitStructure.USART_StopBits = USART_StopBits_1; // 在幀結尾傳輸1個停止位
USART_InitStructure.USART_Parity = USART_Parity_No ; // 奇偶失能
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; // 硬件流控制失能
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; // 發送使能+接收使能
/* Configure USART1 basic and asynchronous paramters */
USART_Init(USART1, &USART_InitStructure);
/* Enable USART1 */
USART_ClearFlag(USART1, USART_IT_RXNE); //清中斷,以免一啟用中斷后立即產生中斷
USART_ITConfig(USART1,USART_IT_RXNE, ENABLE); //使能USART1中斷源
USART_Cmd(USART1, ENABLE); //USART1總開關:開啟
** 函數名稱 : NVIC_Configuration(void)
** 函數功能 : 中斷初始化
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
NVIC_InitStructure.NVIC_IRQChannel = WWDG_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_Init(&NVIC_InitStructure);
** 函數名稱 : WWDG_Configuration(void)
** 函數功能 : 看門狗初始化
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);
WWDG_SetPrescaler(WWDG_Prescaler_8); // WWDG clock counter = (PCLK1/4096)/8 = 244 Hz (~4 ms)
WWDG_SetWindowValue(0x41); // Set Window value to 0x41
WWDG_Enable(0x50); // Enable WWDG and set counter value to 0x7F, WWDG timeout = ~4 ms * 64 = 262 ms
WWDG_ClearFlag(); // Clear EWI flag
WWDG_EnableIT(); // Enable EW interrupt
** 函數名稱 : Delay(vu32 nCount)
** 函數功能 : 延時函數
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
void Delay(vu32 nCount)
for(; nCount != 0; nCount--);
** 函數名稱 : void Delayms(vu32 m)
** 函數功能 : 長延時函數 m=1,延時1ms
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
u32 i;
for(; m != 0; m--)
for (i=0; i<50000; i++);
** 函數名稱 : WWDG_IRQHandler(void)
** 函數功能 : 窗口提前喚醒中斷
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
void WWDG_IRQHandler(void)
/* Update WWDG counter */
WWDG_SetCounter(0x50);
/* Clear EWI flag */
WWDG_ClearFlag();
void USART1_SendData(uchar SendData)
USART_SendData(USART1, SendData);
Delayms(1);
//初始化MPU9250,根據需要請參考pdf進行修改************************
void Init_MPU9250(void)
Single_Write(GYRO_ADDRESS,PWR_M, 0x80); //
Single_Write(GYRO_ADDRESS,SMPL, 0x07); //
Single_Write(GYRO_ADDRESS,DLPF, 0x1E); //±2000°
Single_Write(GYRO_ADDRESS,INT_C, 0x00 ); //
Single_Write(GYRO_ADDRESS,PWR_M, 0x00); //
Single_Write(GYRO_ADDRESS,PWR_MGMT_1, 0x00); //解除休眠狀態
Single_Write(GYRO_ADDRESS,SMPLRT_DIV, 0x07);
Single_Write(GYRO_ADDRESS,CONFIG, 0x06);
Single_Write(GYRO_ADDRESS,GYRO_CONFIG, 0x18);
Single_Write(GYRO_ADDRESS,ACCEL_CONFIG, 0x01);
// Single_Write(GYRO_ADDRESS,0x6A,0x00);//close Master Mode
//******讀取MPU9250數據****************************************
void READ_MPU9250_ACCEL(void)
BUF[0]=Single_Read(ACCEL_ADDRESS,ACCEL_XOUT_L);
BUF[1]=Single_Read(ACCEL_ADDRESS,ACCEL_XOUT_H);
T_X= (BUF[1]<<8)|BUF[0];
T_X/=164; //讀取計算X軸數據
BUF[2]=Single_Read(ACCEL_ADDRESS,ACCEL_YOUT_L);
BUF[3]=Single_Read(ACCEL_ADDRESS,ACCEL_YOUT_H);
T_Y= (BUF[3]<<8)|BUF[2];
T_Y/=164; //讀取計算Y軸數據
BUF[4]=Single_Read(ACCEL_ADDRESS,ACCEL_ZOUT_L);
BUF[5]=Single_Read(ACCEL_ADDRESS,ACCEL_ZOUT_H);
T_Z= (BUF[5]<<8)|BUF[4];
T_Z/=164; //讀取計算Z軸數據
void READ_MPU9250_GYRO(void)
BUF[0]=Single_Read(GYRO_ADDRESS,GYRO_XOUT_L);
BUF[1]=Single_Read(GYRO_ADDRESS,GYRO_XOUT_H);
T_X/=16.4; //讀取計算X軸數據
BUF[2]=Single_Read(GYRO_ADDRESS,GYRO_YOUT_L);
BUF[3]=Single_Read(GYRO_ADDRESS,GYRO_YOUT_H);
T_Y/=16.4; //讀取計算Y軸數據
BUF[4]=Single_Read(GYRO_ADDRESS,GYRO_ZOUT_L);
BUF[5]=Single_Read(GYRO_ADDRESS,GYRO_ZOUT_H);
T_Z/=16.4; //讀取計算Z軸數據
// BUF[6]=Single_Read(GYRO_ADDRESS,TEMP_OUT_L);
// BUF[7]=Single_Read(GYRO_ADDRESS,TEMP_OUT_H);
// T_T=(BUF[7]<<8)|BUF[6];
// T_T = 35+ ((double) (T_T + 13200)) / 280;// 讀取計算出溫度
void READ_MPU9250_MAG(void)
Single_Write(GYRO_ADDRESS,0x37,0x02);//turn on Bypass Mode
Delayms(10);
Single_Write(MAG_ADDRESS,0x0A,0x01);
Delayms(10);
BUF[0]=Single_Read (MAG_ADDRESS,MAG_XOUT_L);
BUF[1]=Single_Read (MAG_ADDRESS,MAG_XOUT_H);
T_X=(BUF[1]<<8)|BUF[0];
BUF[2]=Single_Read(MAG_ADDRESS,MAG_YOUT_L);
BUF[3]=Single_Read(MAG_ADDRESS,MAG_YOUT_H);
//讀取計算Y軸數據
BUF[4]=Single_Read(MAG_ADDRESS,MAG_ZOUT_L);
BUF[5]=Single_Read(MAG_ADDRESS,MAG_ZOUT_H);
//讀取計算Z軸數據
//********串口發送數據***************************************
void Send_data(uchar MAG,uchar axis)
{uchar i;
USART1_SendData(MAG);
USART1_SendData(axis);
USART1_SendData(':');
for(i=0;i<4;i++)USART1_SendData(TX_DATA[i]);
USART1_SendData(' ');
** 函數名稱 : main(void)
** 函數功能 : 主函數
** 輸 入 : 無
** 輸 出 : 無
** 返 回 : 無
int main(void)
RCC_Configuration(); //配置RCC
GPIO_Configuration(); //配置GPIO
USART1_Configuration(); //配置串口1
I2C_GPIO_Config(); //配置IIC使用端口
Delayms(10); //延時
Init_MPU9250(); //初始化MPU9250
READ_MPU9250_ACCEL(); //加速度
DATA_printf(TX_DATA,T_X);//轉換X軸數據到數組
Send_data('A','X'); //發送X軸數
DATA_printf(TX_DATA,T_Y);//轉換Y軸數據到數組
Send_data('A','Y'); //發送Y軸數
DATA_printf(TX_DATA,T_Z);//轉換Z軸數據到數組
Send_data('A','Z'); //發送Z軸數
READ_MPU9250_GYRO(); //陀螺
Send_data('G','X'); //發送X軸數
Send_data('G','Y'); //發送Y軸數
Send_data('G','Z'); //發送Z軸數
READ_MPU9250_MAG(); //磁場
Send_data('M','X'); //發送X軸數
Send_data('M','Y'); //發送Y軸數
Send_data('M','Z'); //發送Z軸數
DATA_printf(TX_DATA,T_T);//轉換溫度數據到數組
Send_data('T'); //發送溫度數據
USART1_SendData(0X0D); //換行
USART1_SendData(0X0A); //回車
Delayms(10); //延時
/*************結束***************/
STM32串口輸出MPU-9250.rar
(287 KB, 下載次數: 199)
2018-11-7 01:00 上傳
白小飛
2018-12-7 17:17
求磁場地址和陀螺地址怎么來的?
zhangchaozhu
2019-9-2 20:17
要求有字數限制
有為の少年
2019-11-3 20:57
想要,支持,很好
ep小飛
2019-12-2 15:04
大佬,我也是這一套,有一些問題請教,請問可以告訴扣扣號嗎?謝謝了
zxfeng0705
2020-4-7 14:33
讀出來的值不變
hominidclint
2020-4-9 20:51
感謝分享,非常好的學習資料,
mxper
2020-10-26 16:30
支持,很好,謝謝
chenpeng
2021-1-12 17:22
zxfeng0705 發表于 2020-4-7 14:33
讀出來的值不變
兄弟解決了嗎
