ov2640 IO口讀取驅(qū)動(dòng)源碼
[打印本頁(yè)]
dbh625
時(shí)間:
2018-10-28 20:33
ov2640 IO口讀取驅(qū)動(dòng)源碼,具體看壓縮包。
單片機(jī)源程序如下:
* OV2640 driver.
#include <config.h>
#ifdef CAM2640
#include <devices/ov2640.h>
#include <devices/sensor.h>
#include "ov2640_regs.h"
const static uint8_t OV2640_AUTOEXPOSURE_LEVEL0[]=
0xFF, 0x01, 0xff,
0x24, 0x20, 0xff,
0x25, 0x18, 0xff,
0x26, 0x60, 0xff,
0x00, 0x00, 0x00
const static uint8_t OV2640_AUTOEXPOSURE_LEVEL1[]=
0xFF, 0x01, 0xff,
0x24, 0x34, 0xff,
0x25, 0x1c, 0xff,
0x26, 0x70, 0xff,
0x00, 0x00, 0x00
const static uint8_t OV2640_AUTOEXPOSURE_LEVEL2[]=
0xFF, 0x01, 0xff,
0x24, 0x3e, 0xff,
0x25, 0x38, 0xff,
0x26, 0x81, 0xff,
0x00, 0x00, 0x00
const static uint8_t OV2640_AUTOEXPOSURE_LEVEL3[]=
0xFF, 0x01, 0xff,
0x24, 0x48, 0xff,
0x25, 0x40, 0xff,
0x26, 0x81, 0xff,
0x00, 0x00, 0x00
const static uint8_t OV2640_AUTOEXPOSURE_LEVEL4[]=
0xFF, 0x01, 0xff,
0x24, 0x58, 0xff,
0x25, 0x50, 0xff,
0x26, 0x92, 0xff,
0x00, 0x00, 0x00
static void SCCB_WriteRegs(sensor_t *sensor, const uint8_t * pbuf)
uint8_t reg_addr;
uint8_t reg_data;
if (sensor == NULL) {
return;
if((*pbuf == 0) && (*(pbuf + 1) == 0))
break;
reg_addr = *pbuf++;
reg_data = *pbuf++;
sal_fiic_write_slave_std(sensor->iic_dev, OV2640_IIC_ADDR, reg_data, reg_addr);
static int set_auto_exposure_level(sensor_t *sensor, int level)
return SAL_ERR_P_NULL;
switch (level) {
case 0:
SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL0);
break;
case 1:
SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL1);
break;
case 2:
SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL2);
break;
case 3:
SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL3);
break;
case 4:
SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL4);
break;
default:
break;
return 0;
static int probe(sensor_t *sensor)
sal_fiic_read_slave_std(sensor->iic_dev, OV2640_IIC_ADDR, OV_CHIP_ID, &sensor->chip_id);
if (sensor->chip_id == OV2640_ID) {
sal_info("OV2640 probe OK, OV2640 ID = 0x%02x.\r\n", sensor->chip_id);
sensor->slv_addr = OV2640_IIC_ADDR;
return SAL_OK;
sal_err("OV2640 not found! chip_id read: %02x.\r\n", sensor->chip_id);
return SAL_ERR;
static int reset(sensor_t *sensor)
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_DSP_RA_DLMT, 0x01);
sensor->iic_dev->delay_us(2);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_SENSOR_COM7, 0x80);
return 0;
static int set_bandw (sensor_t *sensor, uint8_t black_white)
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0xff, 0x00);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7c, 0x00);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, black_white);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7c, 0x05);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x80);
return SAL_OK;
static int set_auto_whitebal(sensor_t *sensor, int enable)
#define CTRL1 0xC3
#define CTRL1_AWB 0x08 /* Enable AWB */
uint8_t reg;
int ret = SAL_OK;
sal_fiic_read_slave_std(sensor->iic_dev, sensor->slv_addr, 0xFF, ®);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0xFF, reg & (~0x01));
sal_fiic_read_slave_std(sensor->iic_dev, sensor->slv_addr, CTRL1, ®);
ret = sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, CTRL1, (reg & (~CTRL1_AWB)) | ((enable != 0) ? CTRL1_AWB : 0));
return ret;
static int set_color_effects (sensor_t *sensor, uint8_t value1, uint8_t value2)
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x18);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, value1);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, value2);
return SAL_OK;
static int set_contrast (sensor_t *sensor, uint8_t value1, uint8_t value2)
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x04);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7c, 0x07);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x20);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x06);
return SAL_OK;
static int set_brightness (sensor_t *sensor, uint8_t brightness)
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7c, 0x09);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, brightness);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x00);
return SAL_OK;
const unsigned char OV2640_JPEG_INIT[][2]=
{0xff, 0x00},
{0x2c, 0xff},
{0x2e, 0xdf},
{0xff, 0x01},
{0x3c, 0x32},
{0x11, 0x00},
{0x09, 0x02},
{0x04, 0x28},
{0x13, 0xe5},
{0x14, 0x48},
{0x2c, 0x0c},
{0x33, 0x78},
{0x3a, 0x33},
{0x3b, 0xfB},
{0x3e, 0x00},
{0x43, 0x11},
{0x16, 0x10},
{0x39, 0x92},
{0x35, 0xda},
{0x22, 0x1a},
{0x37, 0xc3},
{0x23, 0x00},
{0x34, 0xc0},
{0x36, 0x1a},
{0x06, 0x88},
{0x07, 0xc0},
{0x0d, 0x87},
{0x0e, 0x41},
{0x4c, 0x00},
{0x48, 0x00},
{0x5B, 0x00},
{0x42, 0x03},
{0x4a, 0x81},
{0x21, 0x99},
{0x24, 0x40},
{0x25, 0x38},
{0x26, 0x82},
{0x5c, 0x00},
{0x63, 0x00},
{0x61, 0x70},
{0x62, 0x80},
{0x7c, 0x05},
{0x20, 0x80},
{0x28, 0x30},
{0x6c, 0x00},
{0x6d, 0x80},
{0x6e, 0x00},
{0x70, 0x02},
{0x71, 0x94},
{0x73, 0xc1},
{0x12, 0x40},//0x40
/*SensorWindow */
{0x17, 0x11},// HREFST[10:3]
{0x18, 0x43},// HREFEND[10:3]
{0x19, 0x00},// VSTRT[9:2]
{0x1a, 0x4b}, // VEND[9:2]
{0x32, 0x09},// Bit7..6--PCLK分頻設(shè)置,10二分頻,11四分頻; Bit[5:3]: HREFEND[2:0]; Bit[2:0]: HREFST[2:0][===zm.li==>定義Window(H*W):400*300]
// {0x03, 0x0f}, Bit[3:2]: VEND[1:0]; Bit[1:0]: VSTRT[1:0]
{0x37, 0xc0},
{0x4f, 0x60},
{0x50, 0xa8},
{0x6d, 0x00},
{0x3d, 0x38},
{0x46, 0x3f},
{0x4f, 0x60},
{0x0c, 0x3c},
{0xff, 0x00},
{0xe5, 0x7f},
{0xf9, 0xc0},
{0x41, 0x24},
{0xe0, 0x14},
{0x76, 0xff},
{0x33, 0xa0},
{0x42, 0x20},
{0x43, 0x18},
{0x4c, 0x00},
{0x87, 0xd5},
{0x88, 0x3f},
{0xd7, 0x03},
{0xd9, 0x10},
{0xd3, 0x82},
{0xc8, 0x08},
{0xc9, 0x80},
{0x7c, 0x00},
{0x7d, 0x00},
{0x7c, 0x03},
{0x7d, 0x48},
{0x7d, 0x48},
{0x7c, 0x08},
{0x7d, 0x20},
{0x7d, 0x10},
{0x7d, 0x0e},
{0x90, 0x00},
{0x91, 0x0e},
{0x91, 0x1a},
{0x91, 0x31},
{0x91, 0x5a},
{0x91, 0x69},
{0x91, 0x75},
{0x91, 0x7e},
{0x91, 0x88},
{0x91, 0x8f},
{0x91, 0x96},
{0x91, 0xa3},
{0x91, 0xaf},
{0x91, 0xc4},
{0x91, 0xd7},
{0x91, 0xe8},
{0x91, 0x20},
{0x92, 0x00},
{0x93, 0x06},
{0x93, 0xe3},
{0x93, 0x05},
{0x93, 0x05},
{0x93, 0x00},
{0x93, 0x04},
{0x93, 0x00},
{0x93, 0x00},
{0x93, 0x00},
{0x93, 0x00},
{0x93, 0x00},
{0x93, 0x00},
{0x93, 0x00},
{0x96, 0x00},
{0x97, 0x08},
{0x97, 0x19},
{0x97, 0x02},
{0x97, 0x0c},
{0x97, 0x24},
{0x97, 0x30},
{0x97, 0x28},
{0x97, 0x26},
{0x97, 0x02},
{0x97, 0x98},
{0x97, 0x80},
{0x97, 0x00},
{0x97, 0x00},
{0xc3, 0xed},
{0xa4, 0x00},
{0xa8, 0x00},
{0xc5, 0x11},
{0xc6, 0x51},
{0xbf, 0x80},
{0xc7, 0x10},
{0xb6, 0x66},
{0xb8, 0xA5},
{0xb7, 0x64},
{0xb9, 0x7C},
{0xb3, 0xaf},
{0xb4, 0x97},
{0xb5, 0xFF},
{0xb0, 0xC5},
{0xb1, 0x94},
{0xb2, 0x0f},
{0xc4, 0x5c},
/*ImageSize定義*/
{0xc0, 0x64},
{0xc1, 0x4B},
{0x8c, 0x00},/*H*W=800*600*/
{0x86, 0x3D},
{0x50, 0x00},
/*ImageWindow 定義*/
{0x51, 0xC8},
{0x52, 0x96},
{0x53, 0x00},
{0x54, 0x00},
{0x55, 0x00},
/*OutSize定義*/
{0x5a, 0xC8},
{0x5b, 0x96},
{0x5c, 0x00},
{0xd3, 0x7f},
{0xc3, 0xed},
{0x7f, 0x00},
{0xda, 0x00},
{0xe5, 0x1f},
{0xe1, 0x67},
{0xe0, 0x00},
{0xdd, 0x7f},
{0x05, 0x00},
{0x12, 0x40},//0x40
{0xd3, 0x7f},
/*ImageSize定義*/
{0xc0, 0x16},/*Image HSize[10..3]*/
{0xC1, 0x12},/*Image VSize[10..3]*/
{0x8c, 0x00},/*Bit6--HSize[11]?, Bit5..3--HSize[2..0], Bit2..0--VSize[2..0]*//*H*V= 176*144 */
{0x86, 0x3d},
{0x50, 0x00},
/*ImageWindow 定義*/
{0x51, 0x2C},/*HSize[7..0]*/
{0x52, 0x24},/*VSize[7..0]*/
{0x53, 0x00},/*Offerset_X[7..0]*/
{0x54, 0x00},/*Offerset_Y[7..0]*/
{0x55, 0x00},/*Bit7-VSize[8], Bit6..4-Offerset_Y[10..8],Bit3-HSize[8], Bit2..0-Offerset_Y[10..8]*/
/*OutSize定義*/
{0x5A, 0x2c},/*OutW[7..0]*/
{0x5b, 0x24},/*OutH[7..0]*/
{0x5c, 0x00},/*Bit7..4-Zoom Spead, Bit2-OutH[8], Bit1..0-OutW[9..8]*/
const unsigned char OV2640_YUV422[][2]=
{0xFF, 0x00},/*選中DSP[寄存器bank選擇0--DSP, 1--Sensor]*/
{0x05, 0x00},/*bit0 = 0-->DSP處理采集圖像(非Bypass DSP直接將Sensor數(shù)據(jù)輸出)*/
{0xDA, 0x10},/*bit4=1-->JPEG輸出,bit3..2=0-->YUV422格式,bit1=0-->HREF與sensor相同,bit0=0-->High byte first YUYV(C2[4]=0復(fù)位缺省)*/
{0xD7, 0x03},/*芯片保留寄存器*/
{0xDF, 0x00},/*芯片保留寄存器*/
{0x33, 0x80},/*芯片保留寄存器*/
{0x3C, 0x40},/*芯片保留寄存器*/
{0xe1, 0x77},/*芯片保留寄存器*/
{0x00, 0x00},/*芯片保留寄存器*/
const unsigned char OV2640_RGB565[][2]=
{0xDA, 0x1C},/*bit4=1-->JPEG輸出,bit3..2=11-->RGB565格式,bit1=0-->HREF與sensor相同,bit0=0-->High byte first YUYV(C2[4]=0復(fù)位缺省)*/
const unsigned char OV2640_JPEG[][2]=
{0xe0, 0x14},/*芯片保留寄存器*/
{0xe5, 0x1f},/*芯片保留寄存器*/
{0xd7, 0x03},/*芯片保留寄存器*/
{0xda, 0x10},/*芯片保留寄存器*/
{0xe0, 0x00},/*芯片保留寄存器*/
{0xFF, 0x01},
{0x04, 0x08},
/* JPG 160x120 */
const unsigned char OV2640_160x120_JPEG[][2]=
{0xff, 0x01},
{0x12, 0x40},
{0x17, 0x11},
{0x18, 0x43},
{0x19, 0x00},
{0x1a, 0x4b},
{0x32, 0x09},
{0x4f, 0xca},
{0x50, 0xa8},
{0x5a, 0x23},
{0x6d, 0x00},
{0x39, 0x12},
{0x35, 0xda},
{0x22, 0x1a},
{0x37, 0xc3},
{0x23, 0x00},
{0x34, 0xc0},
{0x36, 0x1a},
{0x06, 0x88},
{0x07, 0xc0},
{0x0d, 0x87},
{0x0e, 0x41},
{0x4c, 0x00},
{0xff, 0x00},
{0xe0, 0x04},
{0xc0, 0x64},
{0xc1, 0x4b},
{0x86, 0x35},
{0x50, 0x92},
{0x51, 0xc8},
{0x52, 0x96},
{0x53, 0x00},
{0x54, 0x00},
{0x55, 0x00},
{0x57, 0x00},
{0x5a, 0x28},
{0x5b, 0x1e},
{0x5c, 0x00},
{0xe0, 0x00},
/* JPG 176x144 */
const unsigned char OV2640_176x144_JPEG[][2]=
{0xff, 0x01},
{0x11, 0x05},/*攝像頭晶振6MHz、主控MCU工作頻率16MHz時(shí),此寄存器可設(shè)為0x05(6分頻)、0x0B(12分頻)*/
{0x12, 0x00}, // Bit[6:4]: Resolution selection//0x02為彩條
{0x17, 0x11}, // HREFST[10:3]
{0x18, 0x75}, // HREFEND[10:3]
{0x32, 0x36}, // Bit[5:3]: HREFEND[2:0]; Bit[2:0]: HREFST[2:0]
{0x19, 0x01}, // VSTRT[9:2]
{0x1a, 0x97}, // VEND[9:2]
{0x03, 0x0f}, // Bit[3:2]: VEND[1:0]; Bit[1:0]: VSTRT[1:0]
{0x37, 0x40},
{0x4f, 0xbb},
{0x50, 0x9c},
{0x5a, 0x57},
{0x6d, 0x80},
{0x3d, 0x34},
{0x39, 0x02},
{0x35, 0x88},
{0x22, 0x0a},
{0x37, 0x40},
{0x34, 0xa0},
{0x06, 0x02},
{0x0d, 0xb7},
{0x0e, 0x01},
//176x144
{0xff, 0x00},
{0xc2, 0xcc},
{0xc0, 0xc8},
{0xc1, 0x96},
{0x8c, 0x00},
{0x86, 0x3d},
{0x50, 0x9b},
{0x51, 0x90},
{0x52, 0x2c},
{0x53, 0x00},
{0x54, 0x00},
{0x55, 0x88},
{0x5a, 0x2c},
{0x5b, 0x24},
{0x5c, 0x00},
{0xd3, 0x7F},
/* JPG 320x240 */
const unsigned char OV2640_320x240_JPEG[][2]=
{0xff, 0x01},
{0x37, 0x40},
{0x4f, 0xbb},
{0x50, 0x9c},
{0x5a, 0x57},
{0x6d, 0x80},
{0x3d, 0x34},
{0x39, 0x02},
{0x35, 0x88},
{0x22, 0x0a},
{0x37, 0x40},
{0x34, 0xa0},
{0x06, 0x02},
{0x0d, 0xb7},
{0x0e, 0x01},
//320*240
{0xff, 0x00},
{0xe0, 0x04},
{0xc0, 0xc8},
{0xc1, 0x96},
{0x86, 0x3d},
{0x50, 0x92},
{0x51, 0x90},
{0x52, 0x2c},
{0x53, 0x00},
{0x54, 0x00},
{0x55, 0x88},
{0x57, 0x00},
{0x5a, 0x50},
{0x5b, 0x3c},
{0x5c, 0x00},
{0xd3, 0x7F},
{0xe0, 0x00}
/* JPG 352x288 */
const unsigned char OV2640_352x288_JPEG[][2]=
{0xff, 0x01},
{0x12, 0x40},
{0x17, 0x11},
{0x18, 0x43},
{0x19, 0x00},
{0x1a, 0x4b},
{0x32, 0x09},
{0x4f, 0xca},
{0x50, 0xa8},
{0x5a, 0x23},
{0x6d, 0x00},
{0x39, 0x12},
{0x35, 0xda},
{0x22, 0x1a},
{0x37, 0xc3},
{0x23, 0x00},
{0x34, 0xc0},
{0x36, 0x1a},
{0x06, 0x88},
{0x07, 0xc0},
{0x0d, 0x87},
{0x0e, 0x41},
{0x4c, 0x00},
{0xff, 0x00},
{0xe0, 0x04},
{0xc0, 0x64},
{0xc1, 0x4b},
{0x86, 0x35},
{0x50, 0x89},
{0x51, 0xc8},
{0x52, 0x96},
{0x53, 0x00},
{0x54, 0x00},
{0x55, 0x00},
{0x57, 0x00},
{0x5a, 0x58},
{0x5b, 0x48},
{0x5c, 0x00},
{0xe0, 0x00}
static int set_jpeg_img_format (sensor_t *sensor, image_format_e img_format)
uint32_t i;
reset(sensor);
HAL_Delay(200);
/* Initialize OV2640 */
for (i = 0; i < (sizeof(OV2640_JPEG_INIT) / 2); i++) {
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_JPEG_INIT[i][0], OV2640_JPEG_INIT[i][1]);
HAL_Delay(2);
/* Set to output OV2640_RGB565 (2560bytes size vs 3072 in YUV422 mode.) OV2640_YUV422 */
for (i = 0; i < (sizeof(OV2640_YUV422) / 2); i++) {
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_YUV422[i][0], OV2640_YUV422[i][1]);
HAL_Delay(2);
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0xff, 0x01); /*選中Sensor寄存器bank*/
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x15, 0x00); /*設(shè)置結(jié)果:bit5=0-->PCLK持續(xù)輸出;bit4=0-->數(shù)據(jù)在PCLK降沿時(shí)更新好;
bit3=0-->HRef正極性輸出;bit1=0-->VSYNC正極性輸出;*/
/* Set to output JPEG */
for (i = 0; i < (sizeof(OV2640_JPEG) / 2); i++) {
sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_JPEG[i][0], OV2640_JPEG[i][1]);
HAL_Delay(2);
HAL_Delay(100);
uint8_t data = 0;
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
下載:
ov2640.zip
(4.68 KB, 下載次數(shù): 32)
2018-10-28 20:32 上傳
點(diǎn)擊文件名下載附件
