急救,請高手協助
要求:
1、上電燈開始循環流水燈,
2、當按下按鍵K后燈全亮,且蜂鳴器開始唱生日快樂歌,放開按鍵后燈開始流水且蜂鳴器停止。
程序如下:
說明:P2.0接蜂鳴器,P2.1接按鍵K,P1口接8個燈
#include <reg52.h>
#include <intrins.h>
sbit beep=P2^0;
sbit down=P2^1;
uchar code table[]={400,400,650,650,650,1200,
400,400,650,650,650,650,1200,
400,400,650,650,650,1200} ;
uchar code table1[]={0xfd,0x79,0xfd,0x79,0xfd,0xc7,0xfd,0x79,0xfe,0x21,0xfe,0x05,
0xfd,0x79,0xfd,0x79,0xfd,0xc7,0xfd,0x79,0xfe,0x51,0xfe,0x21,
0xfd,0x79,0xfd,0x79,0xfe,0xc0,0xfe,0x84,0xfe,0x21,0xfe,0x05,0xfd,0xc7,
0xfe,0x99,0xfe,0x99,0xfe,0x90,0xfe,0x21,0xfe,0x51,0xfe,0x21
uchar temp,i,j,time1,time2;
void delay(uint z)
uint t,y;
for(t=z;t>0;t--)
for(y=125;y>0;y--);
TMOD=0x01;
TH0=0;
TL0=0;
EA=1;
ET0=1;
TR0=1;
temp=0xfe;
P1=temp;
temp=_crol_(temp,1);
delay(500);
P1=temp;
if(down==0)
P1=~P1;
beep=~beep;
time1=table[i++];
time2=table[i++];
if(i==50)
i=0;
delay(table1[j++]);
if(j==25)
j=0;
void timer0() interrupt 1
TR0=0;
TH0=time1;
TL0=time2;
TR0=1;
