標(biāo)題: stm32單片機(jī)解決控制5v的1602液晶 [打印本頁]
作者: 為了丶夢想    時間: 2018-10-23 22:30
本人學(xué)生菜鳥一枚,剛從51渡過。打算把51上實(shí)現(xiàn)的功能在stm32上面實(shí)現(xiàn)一遍, 遇到5v的1602 用了很長時間才搞定。目前所有的io口都是用的sn74h245來驅(qū)動的。 我遇到的問題就是 stm32 3.3v 驅(qū)動不了 還有就是延時的問題 ,有興趣的可以試試。
stm32單片機(jī)源程序如下:
  1. #include "stm32f10x.h"
  2. #include "delay.h"
  3. #define Set_RS  GPIO_SetBits(GPIOB,GPIO_Pin_15)
  4. //#define Set_RW  GPIO_SetBits(GPIOB,GPIO_Pin_3)
  5. #define Set_EN  GPIO_SetBits(GPIOB,GPIO_Pin_2)
  6. #define CLR_RS  GPIO_ResetBits(GPIOB,GPIO_Pin_15)
  7. #define CLR_RW  GPIO_ResetBits(GPIOB,GPIO_Pin_3)
  8. #define CLR_EN  GPIO_ResetBits(GPIOB,GPIO_Pin_2)
  9. GPIO_InitTypeDef GPIO_InitStructure;
  10. unsigned char table[]="You are big Pig";
  11. void Send_Com(unsigned char Send_Com)
  12. {
  13. CLR_RS;
  14. GPIO_Write(GPIOA,Send_Com);
  15. Delay_ms(10);
  16. Set_EN;
  17. Delay_ms(10);
  18. CLR_EN;
  19. }
  20. void Send_Dat(unsigned char Send_Dat)
  21. {
  22. Set_RS;
  23. GPIO_Write(GPIOA,Send_Dat);
  24. Delay_ms(10);
  25. Set_EN;
  26. Delay_ms(10);
  27. CLR_EN;
  28. }
  29. void init()
  30. {
  31. CLR_EN;
  32. Send_Com(0x38);
  33. Send_Com(0x0c);
  34.
  35. Send_Com(0x06);
  36.
  37. Send_Com(0x01);
  38. }
  39. void GPIO_Configuration(void)
  40. {
  41. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
  42.
  43. GPIO_InitStructure.GPIO_Pin=GPIO_Pin_15|GPIO_Pin_3|GPIO_Pin_2;
  44. GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  45. GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  46. GPIO_Init(GPIOB,&GPIO_InitStructure);
  47.
  48.
  49. GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  50. GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  51. GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  52. GPIO_Init(GPIOA,&GPIO_InitStructure);
  53. }
  54. int main(void)
  55. {
  56. unsigned char num;
  57. GPIO_Configuration();
  58. init();
  59. Send_Com(0x80);
  60. for(num=0;num<=14;num++)
  61. {
  62. Send_Dat(table[num]);
  63. Delay_ms(10);
  64. }
  65. while(1);
  66. }
1602液晶顯示.rar (216.63 KB, 下載次數(shù): 107)
