標題: LM234引腳圖電路圖與pdf數據手冊下載 [打印本頁]
作者: byyddyh    時間: 2018-10-14 09:19
LM124/LM224/LM324/LM2902資料分享給大家學習
LM234引腳圖
LM234內部功能框圖:
LM234電路圖:
LM234數據手冊:
Low Power Quad Operational Amplifiers
General Description
The LM124 series consists of four independent, high gain,
internally frequency compensated operational amplifiers
which were designed specifically to operate from a single
power supply over a wide range of voltages. Operation from
split power supplies is also possible and the low power
supply current drain is independent of the magnitude of the
power supply voltage.
Application areas include transducer amplifiers, DC gain
blocks and all the conventional op amp circuits which now
can be more easily implemented in single power supply
systems. For example, the LM124 series can be directly
operated off of the standard +5V power supply voltage which
is used in digital systems and will easily provide the required
interface electronics without requiring the additional ±15V
power supplies.
完整的pdf格式文檔51黑下載地址:
LM324.pdf (529.93 KB, 下載次數: 13)
