51單片機彩屏圖片顯示
白科技
2018-10-12 19:12
51單片機彩屏圖片顯示
基于51單片機進行 彩屏圖片顯示
Copytight : Yihetech Co,.Ltd, All rightd reserved. 版權(quán)歸屬億和電子工作室
File Name : lcd.c
Description : LCD module operations
Date : 2009-7-19 21:17:45
Version : V1.0
Author : LiYong(李勇), yihe_liyong@126.com
Target device : C8051F340
Compiler : KeilC51 V8.16
Note : 轉(zhuǎn)載時務(wù)必保留此信息,否則無權(quán)以任何形式傳播本文件
#define _LCD_C_
#include "LCD.H"
#define LCDCOM 0
#define LCDDAT 1
sbit LED_RD = P2^5;
sbit LED_CS = P2^7;
sbit LED_WR = P2^4;
sbit LED_A0 = P2^3;
sbit BLACKLIGHT = P2^0;
sbit RESET = P2^6;
void _delay_ms(unsigned char del)
unsigned int i,j;
for(i=0; i<del; i++)
for(j=0; j<182; j++)
* Name : LCD_Init( )
* Description : Initialize the LCD module
* Input : None
* Output : None
* Note : None
void LCDWR( INT8U cmd_dt, INT8U value )
LED_RD = 1;
LED_CS = 1;
LED_WR = 1;
if(cmd_dt)
LED_A0 = 1;
LED_A0 = 0;
P0 = value;
LED_CS = 0;
LED_WR = 0;
LED_WR = 1;
LED_CS = 1;
* Input : None
* Output : None
* Note : None
void LCD_Init( void )
RESET=1;
_delay_ms(10); //Delay 1ms
RESET=0;
RESET=1;
_delay_ms(10); //Delay 120ms
LCDWR( LCDCOM, 0x01);//software reset
_delay_ms(50); //delay 150ms
LCDWR( LCDCOM, 0x11);//software reset
LCDWR( LCDCOM,0xB1); // Auto load set
LCDWR ( LCDDAT,0x02);//auto load disable//0x9f
LCDWR ( LCDDAT,0x35);
LCDWR ( LCDDAT,0x36);
LCDWR( LCDCOM,0xB2); //EE read/write mode
LCDWR ( LCDDAT,0x02); //set read mode
LCDWR( LCDCOM,0xB3); //EE read/write mode
LCDWR( LCDCOM,0xB4); //EE read/write mode
LCDWR ( LCDDAT,0x07); //set read mode
LCDWR( LCDCOM,0xb6);
LCDWR ( LCDDAT,0xb4);
LCDWR ( LCDDAT,0xf0);
LCDWR( LCDCOM,0xc0);
LCDWR ( LCDDAT,0xa2);
LCDWR ( LCDDAT,0x84);
LCDWR( LCDCOM,0xc1);
LCDWR ( LCDDAT,0x05);
//LCDWR( LCDCOM,0xc2);
//LCDWR ( LCDDAT,0x0a);
//LCDWR ( LCDDAT,0x00);
//LCDWR( LCDCOM,0xc3);
//LCDWR ( LCDDAT,0x8a);
//LCDWR ( LCDDAT,0x2a);
//LCDWR( LCDCOM,0xc4);
//LCDWR ( LCDDAT,0xee);
//LCDWR( LCDCOM,0xd9);
//LCDWR ( LCDDAT,0x40);
LCDWR( LCDCOM,0xc5);
LCDWR( LCDCOM,0xc7);
LCDWR( LCDCOM,0x36);
LCDWR ( LCDDAT,0xc8);
LCDWR( LCDCOM,0xe0); //write contrast for mobile
LCDWR ( LCDDAT,0x12);
LCDWR ( LCDDAT,0x1c);
LCDWR ( LCDDAT,0x10);
LCDWR ( LCDDAT,0x18);
LCDWR ( LCDDAT,0x33);
LCDWR ( LCDDAT,0x2c);
LCDWR ( LCDDAT,0x25);
LCDWR ( LCDDAT,0x28);
LCDWR ( LCDDAT,0x27);
LCDWR ( LCDDAT,0x2f);
LCDWR ( LCDDAT,0x3c);
LCDWR ( LCDDAT,0x03);
//-----------OTPB SET----------------------//
LCDWR( LCDCOM,0xe1);// bias set
LCDWR( LCDCOM,0x2a);// bias set
LCDWR ( LCDDAT,0x81);
LCDWR( LCDCOM,0x2b);// bias set
LCDWR ( LCDDAT,0x82);
LCDWR( LCDCOM,0xf0);// bias set
LCDWR ( LCDDAT,0x01);
LCDWR( LCDCOM,0xf6);// bias set
LCDWR( LCDCOM,0x3a);// bias set
_delay_ms(50);
LCDWR( LCDCOM,0x29); //booster set
_delay_ms(50);
//LCDWR( LCDCOM,0x2c); //booster efficiency set
Function: Draw a dollop at a special area
Input: 1. *dollop : The pointer of a DOLLOP struct
Output: None
Note: The value of the input structrue must be correct, This function does not check the parameters.
Author: LiYong
Date : 2008.08.09
void LCDSetArea( INT16U x1, INT16U y1, INT16U x2, INT16U y2 )
x1+=2;
x2+=2;
y1+=3;
y2+=3;
LCDWR ( LCDCOM, 0x2A);
LCDWR ( LCDDAT, x1>>8);
LCDWR ( LCDDAT, x1);
LCDWR ( LCDDAT, x2>>8);
LCDWR ( LCDDAT, x2 + 0);
LCDWR ( LCDCOM, 0x2B);
LCDWR ( LCDDAT, y1>>8);
LCDWR ( LCDDAT, y1);
LCDWR ( LCDDAT, y2>>8);
LCDWR ( LCDDAT, y2);
LCDWR ( LCDCOM, 0x2C);
void LCDDrawDollop( DOLLOP* dollop )
INT16U x,y;
LCDSetArea(dollop->xs, dollop->ys, dollop->xe, dollop->ye); //Set a area at the screen
for( x = 0; x < dollop->xe - dollop->xs + 1; x ++ ) //Display rows
for( y = 0; y < dollop->ye - dollop->ys + 1; y ++ ) //Display columns
LCDWR( LCDDAT, dollop->Color>>8 );
LCDWR( LCDDAT, dollop->Color );
Function: Draw a point
Input: -pPoint, A structure pointer
Output: None
void LCDDrawPoint( POINT* pPoint )
LCDSetArea( pPoint->x, pPoint->y, pPoint->x, pPoint->y );
LCDWR ( LCDDAT, ( pPoint->Color >> 8 ) & 0xff );
LCDWR ( LCDDAT, pPoint->Color & 0xff );
Function: Draw a line
Input: -pLine, A structure pointer to a line
Output: None
void LCDDrawHRLine( LINE* pLine )
INT8U x0, x1, y0, y1;
if( pLine->xs != pLine->xe && pLine->ys != pLine->ye ) return;
if( pLine->ys > pLine->ye )
y0 = pLine->ye;
y1 = pLine->ys;
y0 = pLine->ys;
y1 = pLine->ye;
if( pLine->xs > pLine->xe )
x0 = pLine->xe;
x1 = pLine->xs;
x0 = pLine->xs;
x1 = pLine->xe;
LCDSetArea( x0, y0, x1, y1 );
x0 = x1 - x0;
if( x0 == 0 ) x0 = y1 - y0;
for( y0 = 0; y0 < x0; y0 ++ )
LCDWR( LCDDAT, pLine->Color >> 8 );
LCDWR( LCDDAT, pLine->Color );
Function: Print a special block in the screen.
Input: pBitBlock: This is a pointer, It points to a block whitch contains informations of the block,
eg. height, width, and so on.
Output: None
Note: None
Author: LiYong
Date : 2008.08.09
void PrintBitBlock( BitBlock *pBitBlock )
INT8U Row, Column;
INT32U BytesAbs;
INT8U RowBytes;
LCDSetArea( pBitBlock->xs, pBitBlock->ys,
pBitBlock->xs + pBitBlock->Width - 1, pBitBlock->ys + pBitBlock->Height - 1 );
RowBytes = pBitBlock->Width >> 3;
if( pBitBlock->Width & 0x07 )
RowBytes ++;
for( Row = 0; Row < pBitBlock->Height; Row ++ )
for( Column = 0; Column < pBitBlock->Width; Column ++ )
BytesAbs = Row * RowBytes + ( Column >> 3 ) ;
if( *( pBitBlock->pData + BytesAbs ) & ( 1<<( Column & 0x07 )) )
LCDWR( LCDDAT, pBitBlock->Color >> 8 );
LCDWR( LCDDAT, pBitBlock->Color );
LCDWR( LCDDAT, pBitBlock->BackColor >> 8 );
LCDWR( LCDDAT, pBitBlock->BackColor );
Function: Print a image
Input: point to a struct which contains the informations of the image
Output: None
Note: None
Author: LiYong
Date : 2008.08.09
void GUI_Image( IMAGE *pImage )
INT16U x, y;
INT32U datacount = 0;
LCDSetArea( pImage->xs, pImage->ys, pImage->xs + pImage->length - 1, pImage->ys + pImage->height - 1 );
for( x = 0; x < pImage->length; x ++ )
for( y = 0; y < pImage->height; y ++ )
LCDWR( LCDDAT, *( pImage->pData + datacount++ ) );
-----------------------------------End of file----------------------------------
彩屏圖片顯示.rar
(208.52 KB, 下載次數(shù): 10)
2018-10-13 00:06 上傳
