標(biāo)題: 步進(jìn)電機(jī)源碼 [打印本頁]
作者: Y文翟    時(shí)間: 2018-10-8 10:17
步進(jìn)電機(jī)源碼:#include <reg52.h>
#define KeyPort P3
#define DataPort P0 //定義數(shù)據(jù)端口 程序中遇到DataPort 則用P0 替換
sbit LATCH1=P2^6;//定義鎖存使能端口 段鎖存
sbit LATCH2=P2^7;//                 位鎖存
unsigned char code dofly_DuanMa[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};// 顯示段碼值0~9
unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//分別對(duì)應(yīng)相應(yīng)的數(shù)碼管點(diǎn)亮,即位碼
unsigned char TempData[8]; //存儲(chǔ)顯示值的全局變量
sbit A1=P1^0; //定義步進(jìn)電機(jī)連接端口
sbit B1=P1^1;
sbit C1=P1^2;
sbit D1=P1^3;
#define Coil_AB1 {A1=1;B1=1;C1=0;D1=0;}//AB相通電,其他相斷電
#define Coil_BC1 {A1=0;B1=1;C1=1;D1=0;}//BC相通電,其他相斷電
#define Coil_CD1 {A1=0;B1=0;C1=1;D1=1;}//CD相通電,其他相斷電
#define Coil_DA1 {A1=1;B1=0;C1=0;D1=1;}//D相通電,其他相斷電
#define Coil_A1 {A1=1;B1=0;C1=0;D1=0;}//A相通電,其他相斷電
#define Coil_B1 {A1=0;B1=1;C1=0;D1=0;}//B相通電,其他相斷電
#define Coil_C1 {A1=0;B1=0;C1=1;D1=0;}//C相通電,其他相斷電
#define Coil_D1 {A1=0;B1=0;C1=0;D1=1;}//D相通電,其他相斷電
#define Coil_OFF {A1=0;B1=0;C1=0;D1=0;}//全部斷電
unsigned char Speed=1;
bit StopFlag;
void Display(unsigned char FirstBit,unsigned char Num);
void Init_Timer0(void);
unsigned char KeyScan(void);
uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
unsigned char 是定義無符號(hào)字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時(shí)請(qǐng)使用匯編,大致延時(shí)
長(zhǎng)度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
mS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
void DelayMs(unsigned char t)
while(t--)
     //大致延時(shí)1mS
     DelayUs2x(245);
         DelayUs2x(245);
                    主函數(shù)
main()
unsigned int i=512;//旋轉(zhuǎn)一周時(shí)間
unsigned char num;
Init_Timer0();
Coil_OFF
while(1)  //正向
   num=KeyScan();    //循環(huán)調(diào)用按鍵掃描
   if(num==1)//第一個(gè)按鍵,速度等級(jí)增加
           if(Speed<18)
           Speed++;
   else if(num==2)//第二個(gè)按鍵,速度等級(jí)減小
           if(Speed>1)
           Speed--;
   else if(num==3)
      Coil_OFF
          StopFlag=1;
   else if(num==4)
          StopFlag=0;
  TempData[0]=dofly_DuanMa[Speed/10];//分解顯示信息,如要顯示68,則68/10=6  68%10=8
  TempData[1]=dofly_DuanMa[Speed%10];
顯示函數(shù),用于動(dòng)態(tài)掃描數(shù)碼管
輸入?yún)?shù) FirstBit 表示需要顯示的第一位,如賦值2表示從第三個(gè)數(shù)碼管開始顯示
如輸入0表示從第一個(gè)顯示。
Num表示需要顯示的位數(shù),如需要顯示99兩位數(shù)值則該值輸入2
      static unsigned char i=0;
           DataPort=0;   //清空數(shù)據(jù),防止有交替重影
       LATCH1=1;     //段鎖存
       LATCH1=0;
       DataPort=dofly_WeiMa[i+FirstBit]; //取位碼
       LATCH2=1;     //位鎖存
       LATCH2=0;
       DataPort=TempData[i]; //取顯示數(shù)據(jù),段碼
       LATCH1=1;     //段鎖存
       LATCH1=0;
           i++;
       if(i==Num)
              i=0;
                    定時(shí)器初始化子程序
TMOD |= 0x01;          //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
//TH0=0x00;              //給定初值
//TL0=0x00;
EA=1;            //總中斷打開
ET0=1;           //定時(shí)器中斷打開
TR0=1;           //定時(shí)器開關(guān)打開
PT0=1;           //優(yōu)先級(jí)打開
                 定時(shí)器中斷子程序
void Timer0_isr(void) interrupt 1
static unsigned char times,i;
TH0=(65536-1000)/256;                  //重新賦值 1ms
TL0=(65536-1000)%256;
Display(0,8);
if(!StopFlag)
  if(times==(20-Speed))//最大值18,所以最小間隔值20-18=2
   times=0;
   switch(i)
            case 0:Coil_A1;i++;break;
                case 1:Coil_B1;i++;break;
                case 2:Coil_C1;i++;break;
                case 3:Coil_D1;i++;break;
                case 4:i=0;break;
            default:break;
times++;
按鍵掃描函數(shù),返回掃描鍵值
unsigned char keyvalue;
if(KeyPort!=0xff)
    DelayMs(10);
    if(KeyPort!=0xff)
            keyvalue=KeyPort;
            while(KeyPort!=0xff);
                switch(keyvalue)
                 case 0xfe:return 1;break;
                 case 0xfd:return 2;break;
                 case 0xfb:return 3;break;
                 case 0xf7:return 4;break;
                 case 0xef:return 5;break;
                 case 0xdf:return 6;break;
                 case 0xbf:return 7;break;
                 case 0x7f:return 8;break;
                 default:return 0;break;
   return 0;
作者: admin    時(shí)間: 2018-10-8 12:44
補(bǔ)全原理圖或者詳細(xì)說明一下電路連接即可獲得100+黑幣
