在數(shù)碼管秒計(jì)時(shí)程序基礎(chǔ)上添加流水燈功能,演示二者如何同時(shí)工作
[打印本頁(yè)]
玉竹重生
時(shí)間:
2018-10-4 11:17
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code LedChar[] = { //數(shù)碼管顯示字符轉(zhuǎn)換表
0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[7] = { //數(shù)碼管+獨(dú)立LED顯示緩沖區(qū),初值0xFF確保啟動(dòng)時(shí)都不亮
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
bit flag200ms = 0; //200ms定時(shí)標(biāo)志
bit flag1s = 0; //1s定時(shí)標(biāo)志
void ShowCount();
void FlowingLight();
EA = 1; //使能總中斷
ENLED = 0; //使能U3
ADDR3 = 1; //因?yàn)樾枰獎(jiǎng)討B(tài)改變ADDR0-2的值,所以不需要再初始化了
TMOD = 0x01; //設(shè)置T0為模式1
TH0 = 0xFC; //為T0賦初值0xFC67,定時(shí)1ms
TL0 = 0x67;
ET0 = 1; //使能T0中斷
TR0 = 1; //啟動(dòng)T0
while (1)
if (flag200ms) //200ms刷新一次流水燈
flag200ms = 0;
FlowingLight();
if (flag1s) //1s刷新一次計(jì)數(shù)值
flag1s = 0;
ShowCount();
/* 流水燈實(shí)現(xiàn)函數(shù) */
void FlowingLight()
static unsigned char dir = 0; //移位方向變量dir,用于控制移位的方向
static unsigned char shift = 0x01; //循環(huán)移位變量shift,并賦初值0x01
LedBuff[6] = ~shift; //循環(huán)移位變量取反,控制8個(gè)LED
if (dir == 0) //移位方向變量為0時(shí),左移
shift = shift << 1; //循環(huán)移位變量左移1位
if (shift == 0x80) //左移到最左端后,改變移位方向
dir = 1;
else //移位方向變量不為0時(shí),右移
shift = shift >> 1; //循環(huán)移位變量右移1位
if (shift == 0x01) //右移到最右端后,改變移位方向
dir = 0;
/* 秒計(jì)數(shù)顯示函數(shù) */
void ShowCount()
char i; //循環(huán)變量
unsigned char buf[6]; //中間轉(zhuǎn)換緩沖區(qū)
static unsigned long sec = 0; //記錄經(jīng)過(guò)的秒數(shù)
sec++; //秒計(jì)數(shù)自加1
buf[0] = sec%10; //將sec按十進(jìn)制位從低到高依次提取到buf數(shù)組中
buf[1] = sec/10%10;
buf[2] = sec/100%10;
buf[3] = sec/1000%10;
buf[4] = sec/10000%10;
buf[5] = sec/100000%10;
for (i=5; i>=1; i--) //從最高為開始,遇到0不顯示,遇到非0退出循環(huán)
if (buf[i] == 0)
LedBuff[i] = 0xFF;
break;
for ( ; i>=0; i--) //將剩余的有效數(shù)字位如實(shí)轉(zhuǎn)換
LedBuff[i] = LedChar[buf[i]];
/* 定時(shí)器0中斷服務(wù)函數(shù) */
void InterruptTimer0() interrupt 1
static unsigned char i = 0; //動(dòng)態(tài)掃描的索引
static unsigned char cnt200 = 0; //200ms定時(shí)
static unsigned int cnt1000 = 0; //1000ms即1s定時(shí)
TH0 = 0xFC; //重新加載初值
TL0 = 0x67;
cnt200++; //200ms定時(shí)
if (cnt200 >= 200)
cnt200 = 0;
flag200ms = 1;
cnt1000++; //1s定時(shí)
if (cnt1000 >= 1000)
cnt1000 = 0;
flag1s = 1;
//以下代碼完成數(shù)碼管動(dòng)態(tài)掃描刷新
P0 = 0xFF; //顯示消隱
switch (i)
case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]; break;
case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]; break;
case 5: ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=LedBuff[5]; break;
case 6: ADDR2=1; ADDR1=1; ADDR0=0; i=0; P0=LedBuff[6]; break;
default: break;
admin
時(shí)間:
2018-10-6 20:57
補(bǔ)全原理圖或者詳細(xì)說(shuō)明一下電路連接即可獲得100+黑幣
51單片機(jī)1234
時(shí)間:
2018-10-7 00:39
學(xué)習(xí)中,謝謝!!
