標(biāo)題: 單片機(jī)矩陣數(shù)碼管顯示固定數(shù)值和對(duì)應(yīng)鍵值 [打印本頁(yè)]
作者: sabers    時(shí)間: 2018-9-21 15:17
#include<AT89X52.H>                  //包含AT89X52.H頭文件          /*定義0~9,A~F十六個(gè)字符的字型碼表*/
unsigned char table[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,
                                           0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void delay10ms(void)
        unsigned char i,j;
        for(i=20;i>0;i--)
                for(j=248;j>0;j--);
void delay()
        unsigned char i;
        for(i=0;i<255;i++);
unsigned char scan_key(void)
        unsigned char scan,col,rol,tmp;
        bit flag=0;
        scan=0xef;
        for(col=0;col<4;col++)
                P0=scan;
                tmp=P0;
                switch(tmp&0x0f)
                        case 0x0e:rol=0;flag=1;break;
                        case 0x0d:rol=1;flag=1;break;
                        case 0x0b:rol=2;flag=1;break;
                        case 0x07:rol=3;flag=1;break;
                if(flag==1)
                break;
                scan=(scan<<1)+1;
        while(tmp!=0x0f)
                P0=0x0f;
                tmp=P0;
        return(rol*4+col);
void scan()
        unsigned char tmp,key;
        while(tmp!=0x0f)
                P1=table[0];
                P2=0xfe;
                delay();
                P2=0xff;
                P1=table[6];
                P2=0xfd;
                delay();
                P2=0xff;
        P0=0x0f;
                while(tmp==0x0f)
                        P0=0x0f;
                        tmp=P0;
                delay10ms();
            P0=0x0f;
                tmp=P0;
                if(tmp==0x0f)
                continue;
                key=scan_key();
                P1=table[key];
                P2=0xf7;
                delay();
                scan();
作者: admin    時(shí)間: 2018-9-21 17:25
補(bǔ)全原理圖或者詳細(xì)說(shuō)明一下電路連接即可獲得100+黑幣
