標題: 帶字庫的LCD12864顯示屏單片機驅動程序 [打印本頁]
作者: anchengxiang    時間: 2018-9-4 19:13
p0-p7連接d0-d7,RS連接p1.0,RW連接p1.1,EN連接p1.2,CS1連接P1.3,CS2連接p1.4
如果顯示不出來或者亂碼,可能是cs1和cs2連反了,可能是p0-p7連反了,或者按下復位鍵試試
制作出來的實物圖如下:
單片機源碼:
  1. #include <reg52.h>
  2. #define DATA_PORT P0
  3. sbit LCD12864_EN   = P1^2;
  4. sbit LCD12864_RSET = P1^3;
  5. sbit LCD12864_RS   = P1^0;
  6. sbit LCD12864_RW   = P1^1;
  7. sbit LCD12864_PSB  = P1^4;
  8. void delay(int ms)                //延時ms
  9. {
  10.         while(ms--)
  11.         {
  12.                 int i;
  13.                 for(i=25;i>0;i-- );
  14.         }
  15. }
  16. bit LcdBusyCheck(){
  17.           bit result;
  18.           LCD12864_RS = 0;
  19.           LCD12864_RW = 1;
  20.           LCD12864_EN = 1;
  21.           result = (bit)(DATA_PORT&0x80);
  22.           LCD12864_EN = 0;
  23.           return result;
  24. }
  25. void WriteCmdToLCD(unsigned char cmd)
  26. {
  27.                 //        while(LcdBusyCheck());
  28.         delay(10);
  29.           LCD12864_RS = 0;
  30.           LCD12864_RW = 0;
  31.           LCD12864_EN = 1;
  32.           DATA_PORT = cmd;
  33.           delay(5);
  34.         LCD12864_EN = 0;
  35.         delay(5);
  36.         LCD12864_EN = 1;
  37. }
  38. void WriteDatToLcd(unsigned char dat)
  39. {
  40.                 //while(LcdBusyCheck());
  41.                 delay(10);
  42.                 LCD12864_RS = 1;
  43.           LCD12864_RW = 0;
  44.           LCD12864_EN = 1;
  45.           DATA_PORT = dat;
  46.           delay(5);
  47.         LCD12864_EN = 0;
  48.         delay(5);
  49.         LCD12864_EN = 1;
  50. }
  51. void WriteStrToLcd(unsigned char *str)
  52. {
  53.         while(*str != '\0')
  54.         {
  55.                 WriteDatToLcd(*str++);
  56.                 delay(5);
  57.         }
  58. }
  59. void LcdPos(unsigned char x,unsigned char y)
  60. {
  61.         unsigned char pos;
  62.         if(x == 1)
  63.         {
  64.                 x = 0x80;
  65.         }else if(x == 2)
  66.         {
  67.                 x = 0x90;
  68.         }else if(x == 3)
  69.         {
  70.                 x = 0x88;
  71.         }else if(x == 4)
  72.         {
  73.                 x = 0x98;
  74.         }
  75.         pos = x + y - 1;
  76.         WriteCmdToLCD(pos);
  77. }
  78. void LcdInit()
  79. {
  80.         LCD12864_PSB = 1;
  81.          LCD12864_RSET = 0;
  82.          delay(10);
  83.         LCD12864_RSET = 1;
  84.         WriteCmdToLCD(0x30);
  85.         delay(5);
  86.         WriteCmdToLCD(0x30);
  87.         delay(5);
  88.         WriteCmdToLCD(0x18);
  89.         delay(5);
  90.         WriteCmdToLCD(0x10);
  91.         delay(5);
  92.         WriteCmdToLCD(0x01);
  93.         delay(5);
  94.         WriteCmdToLCD(0x06);
  95.         delay(5);
  96.          WriteCmdToLCD(0x0c);
  97.         delay(5);
  98. }
  99. void Clr()
  100. {
  101.
  102.                                 P0 = 0xff;
  103.                                 LcdInit();
  104. }
  105. int main()
  106. {
  107.                 P0 = 0xff;
  108.                 P1 = 0xff;
  109.                    LcdInit();
  110.         LcdPos(1,1);
  111.                 WriteStrToLcd("智能小車");
  112.                 delay(5);
  113.                 LcdPos(2,1);
  114.                 WriteStrToLcd("張成祥");
  115.                 delay(5);
  116.                 LcdPos(3,1);
  117.                 WriteStrToLcd("1604012020");
  118.                 delay(5);
  119.                 LcdPos(4,1);
  120.                 WriteStrToLcd("16計科2");
  121.                                 delay(10000);
  122.                                 delay(10000);
  123.                                 delay(10000);
  124.                                 delay(10000);
  125.                                 delay(10000);
  126.                                 delay(10000);
  127.                                 delay(10000);
  128.                                 delay(10000);
  129.                                 Clr();
  130.                                 LcdPos(1,1);
  131.                 WriteStrToLcd("準備就緒");
  132.                 delay(5);
  133.            while(1)
  134.            {
  135.
  136.            }
  137. }
lcd.zip
28.37 KB, 下載次數: 75, 下載積分: 黑幣 -5
LCD源碼
作者: 小螞蟻123    時間: 2019-4-22 18:42
簡單  一目了然
作者: g'f'yeu'y    時間: 2021-4-21 10:28
請問附件里有仿真原理圖嗎?
